Question about Zanussi WJS1265W Front Load Washer/Dryer
My hec washing machine wont drain help - Zanussi WJS1265W Front Load Washer/Dryer
  • Zanussi Master
  • 3,463 Answers
If you have not already done so, then remove and clean filter located at bottom front right of washer behind flap.
Unscrew anti-clockwise to remove and clean.
Posted on Feb 06, 2010
  • 3741 Answers
SOURCE: washing machine will not drain. water wont drain
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Aug 20, 2009
barkencoa
  • 3463 Answers
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Posted on Dec 09, 2009
parjee
  • 83 Answers
SOURCE: my hec washing machine is not spinning and the water wont empty
Try turning the spin basket, something may have jammed itself inside the tub. You can remove the front kick panel and remove the tub to pump hose to clean it out.
If ok, you might have other problems like a broken belt in the back.
Posted on Sep 28, 2009
SOURCE: Lost washing instructions for HEC
turn small left dial to 40.
Then turn right dial to the wash you desire:
(cotton)1. intense 2.prewash 3.normal 4.middle 5.delicate
(synthetic)6.normal 7.middle 8.delicate
(wool)9. normal 10. delicate
(silk) 11.normal 12.delicate
13 quick 14 rinse 15 spin 0 end
hope this helps
Posted on Jan 05, 2010
rickyrt441
  • 4399 Answers
SOURCE: My HEC 1050w washing machine
Thanks for choosing FixYa and welcome to the site. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging.
Posted on May 07, 2011
Hec 1050w
oh hec its a hec
have you cleaned the filter
Feb 03, 2014 | Washing Machines
Where can I get user manual for HEC 1005a washing machine. I can't seem to find it online.
go to the HAIER web site there you can find a manual for your HEC 1005a
Jan 22, 2013 | Washing Machines
Error 2 on the hec 1005a washing machine
i got HEC 1005A washing machine. there is ERROR 2 on it.please guide me how can i solve it
May 28, 2011 | Washing Machines
Manual for HEC washing machine model 1005A
i have hec 1005 washing machine how can i take dispenser drawer out
Oct 09, 2010 | Washing Machines
Not allowing water in, and not rinsing.....it is hec 1050w
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Aug 17, 2010 | Washing Machines
My hec washing machine is not spinning and the water wont empty
Sep 25, 2009 | Washing Machines
Zanussi WJS1265W Front Load Washer/Dryer Logo
814 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
