Question about Samsung SC-D363 Mini DV Digital Camcorder
I charged battery for 1 day but my camcoder no power. if the battery is bad how do i know? please helps.
  • 583 Answers
If the camcorder will power up with the charger plugged in, it is most likely the battery. Depending on use, rechargeable batteries can go out in as little as 6 months.
Posted on Feb 06, 2010
New battery charging very slowly?
Power off your Laptop, unplug the power cable from the laptop as well, take the battery out and wait for about 5 minutes. Put the battery back in, make sure it is seated properly. Plug the laptop back in and power it on an see if that charges the battery quicker. If it doesn't you may have a bad battery, and I would contact the place you bought it and ask for an exchange.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/brandon_f3a03ecb14f80b8d
Oct 16, 2012 | Compaq Presario CQ61-310US Laptop
The battery in AC power does not charge but it says in the tray icon that it is charging but still displays 1% available power and does not progress...
Check for a bad DC connection:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it's still under warranty, it would be fixed at no charge to you.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 20, 2010 | Computers & Internet
Canon zr 200 camcorder won't turn on unless plug into electrical outlet.
Hi, Please charge your battery ( with camcoder Off) for at least 1 hour. Then unplug your charger and turn On your camcoder. If it can not turn on, it is apparently you have flat battery and need replacement.
Dec 03, 2010 | Canon ZR200 Mini DV Digital Camcorder
The vision is blury and it keeps flashing E:61:10
E:61:10 is a lens error code. Could be a connection issue between the lens and the main board or a bad lens. You will need to have this looked at by an experienced technician. www.austintelstarservices.com
Aug 29, 2010 | Sony DCR-SR47 Camcorder
It powers off even when the battery indicator level is full. i have replaced the battery but the problem remains. when it powers off, the only way to get it back on is to put back on charge.
please check your ampire such as 1024 mah? if not please change your battery? for use many days then mobile battery become weak day by day. and another tips is please recharge your battery when the battery indicator come 1 level. and don't try short circuit of your battery. never charge from DC current. thanks
Jan 10, 2010 | Nokia E71 Smartphone
Garmin Nuvi 265W just will not switch on!
Bad or very low battery
Replace at Garmin
But first know this:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sounds like a bad or low battery. Do you have the Garmin approved charger / car charger?? You may have to send your 265 in for battery replacement or try this:
There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F respectively) then it will not charge. When connected to external power it will only be operating off of external power.
2 - The Quest® and Quest® 2 will not charge using a USB cable.
Aug 06, 2009 | Garmin nuvi 265 Car GPS Receiver
Battery not charging
its a bad battery, you need a new one.
Mar 02, 2009 | LG LW20-EV Notebook
DCR HC48 not working on battery
see the contacts on the both side are they rusty current is not passing thru the terminal properly try cleaning them with some rust removing liquid on a cloth and then try it
Feb 23, 2009 | Sony Handycam DCR-HC48 Mini DV Digital...
Charging problem
how long have you had the phone? usually the longer you have the phone the more it uses battery. the same with cameras, laptops, etc... my guess would be that the battery is going bad. ive had a few phones for just a few months and the battery would barely hold a charge for a day. so try getting a new battery and hopefully that will solve the problem :). also make sure there arent any games or programs constantly running on the phone as that can also drain the power pretty quick. hope this helps!
Nov 04, 2008 | Lands Phones
Toshiba satelitte adapter went bad ordered new one it wont work
If the old one works you have another power supply or wrong one.
Check the properties of your power supply.
Related to your issue you also may consider this:
1.- Computer AC / DC cable is bad not allowing the computer battery to charge.
2.- Battery is bad.
3.- Battery charger board is bad.
Solutions:
Verify that the AC and or DC cable is not bad by testing the computer only with the power plug connected and the battery out of the laptop.
2.- Battery is bad
It is possible that if the power plug is good that the computer battery is bad. Leave the computer connected to the power with the battery connected in the computer for at least one hour; if the battery does not charge, consider having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty consider just replacing the battery as it is very likely that it is just a bad battery.
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It is recommended that the laptop be serviced or repaired.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 15, 2008 | Toshiba Computers & Internet
Samsung SC-D363 Mini DV Digital Camcorder Logo
102 people viewed this question
Top Samsung Video Cameras Experts
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
