Question about Maws Baby Gear
A friend has lent me a maws sangenic nappy disposal unit but i dont know how to put the cassette in properly there was a plastic round cassette type thing in there already but i dont know whether that is an old used one or is part of the unit
  • 90 Answers
SOURCE: Garbage Disposal problem
Best just to replace it.
Posted on Jan 05, 2008
SOURCE: Fabricate or not?
OK, can you provide a bit more info. What make and model is your HVAC...if you can give me the serial that would help too. What size tents are you using and what is the average ambient temp during the day?
Posted on Apr 30, 2009
Dplumber
  • 119 Answers
SOURCE: My InSinkErator Badger1 garbage disposal has
Your drain is probably OK. The disposal is going bad. You can temporarily repair the disposal by using plumber's epoxy putty ( found at most home centers for about 5 bucks) to seal the hole. Sand the area around the hole first, and then dust it off. Use about a golf-ball size section of putty to seal the hole. This is not a permanent fix, but it will get you by for a while. Replacing the garbage disposal will be the ultimate fix.
If after repairing the hole the sink stands full of water, then you know for sure that the drain is backed up.
Posted on Sep 09, 2010
Testimonial: "Plumbing, wisdom, and wit -- hard to beat that combination! Thanks!"
heatman101
  • 43501 Answers
SOURCE: in sink erater model 444 - 3/4hp disposal. keeps
Check the reset button..
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
Posted on Sep 29, 2010
  • 250 Answers
SOURCE: i dont know the MSL code to my BOOST SCP2700 QWERTY
YOU can get your MSL code here this site.
hope this will help you.
Posted on Feb 16, 2012
Spring latch stihl sg17
you need pawls the pawls are two small plastic units that wear
you can simply turn them over and swap them round
this will double the lifespan of the pawls
they are located on the rip cord cassette
or just replace them
the older type is nylon and the newer black one seem to be made of some carbon plastic
Mar 10, 2014 | Stihl Leaf Blower Starter Rewind Cover Bg...
What is the best way to dispose of feminine sanitary products and disposable nappies when out camping?
The best thing is to take it with you in a sealable bag and dispose of it when you get home. Some campsites have amenities that would involve a disposal bin for those types of things but often you will have to take it.
Jul 09, 2012 | Camping, Backpacking & Hiking
I lent my wagan Powerdome to a friend and he lost the charger, where can I get one
raido shack they have all types look on the back to find out what the (amp) (voltage)and
you must no what the center of the plug is (posative) or (negative) if they dont have one
in the store they can order the wright one for that unit
i hope this helps you
bob
Aug 23, 2011 | Wagan 400 Watt Power Dome
My InSinkErator Badger1 garbage disposal has started leaking from a small hole (round, ~1/8") about 2/3 of the way up the back of the case. It's particularly messy when the disposal is running. Is this...
Sep 09, 2010 | Plumbing
How do you get the mildew smell out of a clothes dryer?
Very unusual problem with a dryer as it gets hot and would normally evaporate moisture causing mildew!
Try the following:
  • Unplug the power point of the dryer.
  • Gently clean the interior (and exterior) with a super absorbent cloth/non-scracth sponge lighty soaked in a mild bleach soapy mixture to kill off and remove the (blackish) mildew (Nappy wash is not a bad mixture). Weat rubber gloves for protection.
  • Let the unit wet for a few minutes and then using clean warm water and sponge, remove all trace of the bleachy soap on the unit as it is corrosive. Additional drying off with disposable paper towel will help remove any trace of bleach.
  • Put a wet clean bathroom towel lightly soaking with material conditioner mixture at double the normal recommended ratio, power the dryer and dry off the towel as per normal: the fabric conditioner is also a freshner.
  • Musty milldew odour should be gone!
Hope it helps! Please let me know how you go!
Aug 05, 2010 | Hotpoint Dryers
Lent my glue gun to a friend and she left it on its side and now the glue is stuck in the inside. how do i get it out. i took it apart. my wife says put it in the freezer
metal or plastic part? If metal, put it in the oven on some foil until it melts off. If it's the plastic try nail polish remover.
Dec 17, 2009 | Crafts & Hobbies
The brushes on the unit do not spin.
try to clean the filter under the machine or the filter behind the clear plastic, were you see the hypnotic disc sprin that lets you know that the brushes are spinning. To remove : the plastic piece that looks like a triangle, ( were the indicator is that lets you know the brushes are turning ) remove by pulling from top, clean lent from screen and reverse your steps to put back on.
Jul 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Dell Wireless Keyboard
THE KB BOARD NEEDS TO BE SERVICED, BY REMOVING THE SCREWS OR SNAP CLIPS THAT HOLD THE KB TOGETHER, CLEAN THE CURCIUT BOARD OR PLASTIC FILM WITH SOME ACOLAHOL AND LENT FREE TOWEL,
USE A CAN OF COMPRESSED AIR TO REMOVE THE DIRT FROM THE KEY SWITCHS.
PUT IT BACK TOGETHER,
GO INGO CONTROL PANEL OPEN DEVICE MANAGER, GO DOWN TO KEYBOARD AND CHECK FOR ANY TYPE OF UPDATES OR AND CHANGES TO THE PROGRAM.
IF YOU CAN FIND THE KEYBOARD TEST THAN TEST THE KEYBOARD TO MAKE SURE ALL KEYS ARE WORKING PROPERLY.
RODGANDYSR
Mar 07, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Problem with sony ccd tvr208
CCD-TRV208E is analog Sony Handycam and I think tape was recorder on Digital Handycam.
Digital handyacam model starts with letters DCR-xxx so locate a digital handycam to get tape recordings.
I got this idea when you said, only getting crackling noise and blue screen.
Jan 31, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Popcorn popper motor base broken
you will need the manufacturer's name, model number of the unit and its serial number. You may contact any appliance repair shop in your area with that information and they should be able to help you. or you could go online to partstown dot com, and order the part directly.
Dec 18, 2017 | Paragon Theater Pop 4 Popcorn Maker
Baby Gear Logo
254 people viewed this question
Top Maws Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Maws Baby Gear Expert? Answer questions, earn points and help others
