Question about Canon imageCLASS MF4150 All-In-One Laser Printer
Printer only print first paper. when I print a 1+ pages document (or more than one copy) it only prints the first page and then gives red led faulty alarm. then to reoperate I have to switch it off and on again
    President:
  • Canon Master
  • 2,017 Answers
This is the toner problem may be it is low or faulty kindly refill it ir replace it.
Have a nice day and do not forget to rate please...!
Posted on Feb 06, 2010
How do I reduce a page being copied?
scan a copy to pc documents , save to word , use photo shop and reduce in size
print page and then re-scan
Sep 17, 2017 | Office Equipment & Supplies
I have a hp 1320 laseret printer.when I order to print. this printer prints two pages. I could not solve this problem. would you please help me?
What document you are trying to print?
If it is Excel or Word document you have created a second blank page, reopen the document and delete the second empty page.
Nov 17, 2014 | HP LaserJet 1320 Printer
How to copy 2 sided
If your printer does not have a duplex unit then the printer cannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn the page upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for the rest of the document.
I suggest you try a test page first, to get the printing the right way up on both sides of the page so it reads correctly.
Mar 31, 2013 | HP Office Equipment & Supplies
How can i print both sides of paper on my magiccolor5550
IF you have the optional duplex unit installed on your printer then when you go to print something, your printer setup screen should have a duplex/2 sided printing box you can check. This will be under printing preferences or properties. If you do NOT have the optional duplex option then you have to manually duplex. That means on say a 2 page document that you want 10 copies of you have to print 10 copies of page 1. Then take those 10 copies and place them back into the paper tray and print 10 copies of page 2 onto the backs of page 1.
Those are you 2 choices for duplex printing.
Good Luck and Thank You for using Fixya.
Nov 17, 2010 | Konica Minolta Magicolor 5450 Printer
The orange lights are flashing, is there something wrong?
Try:
1 Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
2 PPM print speeds are based on the highest speed printer driver mode. Photo print speeds are based on the default mode driver setting using Canon Photo Paper Plus Glossy paper. Print speeds will vary depending on system configuration, interface, software, document complexity, print mode, types of paper used and page coverage. CPM copy speeds based on fast mode setting using plain paper. Copy speeds may vary based on document complexity, copy mode, page coverage and number of copies.
3 USB 2.0 Hi-Speed requires Windows XP, 2000 or Mac OS X operating systems. For Windows 98, Me and Mac OS X v.10.2 to 10.2.6 operating systems, the printer will operate at USB 1.1 specifications.
Oct 22, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My Brother HL-2040 paper led light won't stop flashing, the paper's not jammed or anything, I just put in a new toner, too. I tried doing what someone else said about opening the cover and holding Go until...
Hi. The reasons listed in the manual that cause the LED to flash normally are:
Front cover is open
Close the front cover of the printer.
Back cover is open
Close the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 6-5.
If the printer does not start printing, press the Go button.
No paper fed manual feed slot
Put the paper in the manual feed slot. See Printing on plain paper, bond paper
or transparencies from the manual feed slot on page 1-10 or Printing on thick
paper, labels and envelopes from the manual feed slot on page 1-13.
Memory full
The printer memory is full and the printer cannot print full pages of a
document. See Solving print problems on page 6-15.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document.
Drum Error
The corona wire needs to be cleaned. See Cleaning the corona wire on page 5-14.
If you check out page 6-5 it tells how to clear the paper jam from the rear of the machine! A point often missed.
Check out the website below if you don’t have a copy of the instruction manual =
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002089/US_Eur.pdf
If all else fails, try a reset of the printer Drum & Page counter:
  1. With printer tuned on.
  2. Press and hold the “internal button” behind front cover, until all LEDs illuminate.
  3. Make sure Drum light is off, then release and close front cover.
Hope some of this helps………..Please post a response back here and let us all know if it works?............Regards, Cornwellnet (UK)
Jul 12, 2009 | Brother HL-2040 Laser Printer
Only prints 1/4 of the page, then ejects the paper.
Hi donlyn941,
I have exactly this problem. I am using Windows Vista. I had this printer installed automatically by Vista, without any CD.
What I did to resolve this:
  1. Power down the printer first by holding down the "Power Save" button
  2. When the LED screen is off, wait for 5 seconds.
  3. Power up the printer by pressing the "Power Save" button.
  4. During Step 3, we will hear a "dun-dun" sound, which means the printer is connected.
  5. I started printing, without the 1/4 page. :)
Hope this helps.
Let me know if you have any problems.
Jan 07, 2009 | Brother MFC 420CN All-In-One InkJet...
Why do all pages print onto one page when i hit the print button in a multipage document
I guess you are using word. In that case the default driver you use and comes standard with windows is flawed. Download a new one from HP.
Oct 24, 2007 | HP LaserJet 1150 Printer
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
64 people viewed this question
old marine
old marine
