Question about Microsoft Zune JS8-00001 Digital Media Player
I have a 30 gb zune. Got all the updates loaded, turns on, charges everything works, but the music plays then there's a long pause and starts playing again. this is continuous.
  • 80 Answers
I think you need to scan for virus with a good anti virus, then if possible, format it(but see if you could remove the songs that you already have to avoid the stress of getting them back).
Posted on Feb 06, 2010
My Zune player 8gb not charaged.
Just press the play/pause and the back button at same time for a while.. The player will then restart, and the problem is solved (hopefully)
Jul 23, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune 80 GB - Won't Charge
i lost my drivers microsoft lifecam vx-1000
Feb 07, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
I can see my songs playing but I can not hear them.
i had the same problem the hardrive is jacked i tried everything but the best thing to do is just get a new zune.or a i pod but zune is better.a 8 gb is good go get that one.but,you can try and erase everything on it and restart it and see where ur getting at
Jan 15, 2009 | Microsoft Zune JS8-00001 Digital Media...
My 30 gb zune is frozen
There's a fix:
Your zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connecter. Your zune should start up immediately. Press the backing of the zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
It's an easy process but if you're unsure don't attempt it.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
goto step 4 only remove clip for battery wait ten seconds. It worked for me!
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune 30 gb space
I'm afraid not, because the zune or any other mp3 player has an operating system which it plays music, if you were to format it would have 30, but DO NOT FORMAT, because if you do, chances are you will lose everything and have to install the operating system for it or send it in to get repaired. I just thought I would let you know that the 1 GB is used for the operating sytem (files, folders, core components)
Hope this helps
Apr 02, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune keeps freezing up...
JUST HOLD THE BACK BUTTON AND THE UP BUTTON FOR 30 SEC. AND YOU WILL BE GOOD DON'T WORRY PEOPLE.... ALSO WHEN I FREZZE ALOT THAT MEANS YOU DATA ON THE ZUNE IS COUPPORTED AND YOU WILL NEED TO RESET THE WHOLE DEVICE OK.
Feb 19, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune won't charge
now what you do is if the zune just has a black screen with a battery symbol and it stays that way forever when on the charger. you, take the zune off the charger and press the play/pause button and if it turns on for a second with the low battery symbol then turns off, your in luck, just hold the play/pause button for 10 - 20 minutes. the zune will have turned on and off alot agitating the battery. once you hold it for 10 - 20 minutes put it on the charger, then presto it works. let charge fully then die completly for every time you use it for a bout a month to let the battery get back into it's normal cycle. ~Dan herzberg~ Thank you*
Feb 18, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Music stops and zune freezes up
uhm i think i may have found your solution, that is if your using limewire or some client of the sort, i synced my zune while the program (limewire) was on and downloading music and i had the same problelm you did so i simply deleted all my music and put it back on the zune while limewire was off and now it works fine, i have an 80 gig btw if that matters
Feb 10, 2008 | Microsoft Zune JS8-00001 Digital Media...
My Zune is Not responding
after much research on this matter in the past few hours. To resolve this situation don't shut the zune down by holding play/pause button it does not shut down properly that way.
Hold down the down & back button down until shuts off....zune recommends as the best way to turn off your zune. Also if you are having problems holding charge, a lot of people replaced the original charge plug and found that it worked again. these cables usually become faulty from previous models and 30gigs. So buy a new cable & shut it down correctly.
Still no worky??? Call zune, within 1 year they will accept it for repairs. They may even send you a new refurbished zune...since they no longer are making the 30 gig...probably for those reasons.
I hope this advice not only helps you but myself. Who wants an expensive paperweight...not I!
Dec 11, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft Zune JS8-00001 Digital Media Player Logo
41 people viewed this question
Top Microsoft Audio Players & Recorders Experts
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
