Question about Jet Equipment Slt 660F;Folding Handle; Quick Lif #140777
Causes of jet pump overheating
Motor runs and turns off within a minute
    Problem Solver:
  • 19 Answers
Improper voltage/ wiring connection on motor. Pump is binding for some reason, sand, debris. Most likely its the elctrical connection
Posted on May 18, 2010
Would like to know why my convertible well jet pump is over heating and shutting off
Only guessing but think it is a rough bearing in the motor. Pump should run relatively quiet but there is a possibility that the plastic impeller is binding if it ever ran dry as it could have overheated and melted.
Oct 20, 2014 | Plumbing
How to fix a wayne pump ycb 139-3/4-2b2 from over heating?
Dirt will cause overheating.
Lack of lubrication. Bad bearings. Temperature where the motor sits They are not to sit in high temperatures.
Sometimes the electrical wiring is not heavy enough to carry the electrical load and causes over heating. Worn electrical components in the motor will cause over heating. Sometimes if a motor is over worked will do it as well.
Oct 20, 2014 | Wayne 3/4 HP Cast-Iron Convertible Well...
Car overheated and antifreze was boiling and spewing over until engine cooled. 2004 jeep liberty 2wd. Thanks!
Need to know what caused the overheating, possible broken serpentine belt, thermostat, water pump, radiator, fan clutch, cooling fan motor. After motor has cooled down fill radiator with water till full, look make sure serpentine belt not broke, start engine run about 5 minutes, turn off, let sit 3 minutes, start engine look at temperture gauge is it over half way of gauge, Do you have a fan blade driven by water pump or electric fans?
Feb 10, 2010 | 2004 Jeep Liberty
Foltec 4012-10 motor get hots and kicks off
Sounds like a seized bearing. Many times the motor boosts its torque output to get over the initial inertia. and if the bearing seized, the motor running at normal capacity would not be strong enough to rotate. thus causing the rotor to stall and hence the motor getting overheated.
Aug 10, 2009 | Flotec Corrosion Resistant Shallow Well...
Hayward Swimpro Sand filter shuts off after approx 2 minutes
It sounds like the pump is either overheating or the thermal protection switch that senses the overheating situation is defective. If nothing else changed like running on an extension cord, etc, a small motor repair shop can get you back up and running fairly inexpensively.
May 23, 2009 | Hayward SAND FILTER, PRO SERIES
The motor keeps turning on & off like it is overheating
it sounds as if it is overheating. there is a sensor inside all motors that shuts the motor down if it reaches a certain temperature.
If your motor shuts down after running for a while then 15 minutes or so just comes back on then that is what is happening.
Could be the result of not enough air around the motor to keep it cool, or something inside the motor making it work harder than it should like the bearings going out.
Feb 23, 2009 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Jet Pump stops after three starts of 20 minutes each and it doesnt want to start back again until the next day or after a few hours
check motor with hand after it stops for excessive heat. Thermo coupler shuts motor off if overheating, to protect windings. Bad motor bearing can cause overheating, if so should hear bearing noise when running.
Also check start capacitor, by removing and checking with ohm meter, or plug in oposite terminals of capacitor to charge. Place rubber glove on hand, and contact two oposite terminals with screwdriver should produce a small spark.
Nov 15, 2008 | Hayward EC-40 DE Pool Filter with pump
Jet Equipment Slt 660F;Folding Handle; Quick Lif #140777 Logo
512 people viewed this question
Top Jet Plumbing Experts
Lawrence Oravetz
bobalix
Are you a Jet Plumbing Expert? Answer questions, earn points and help others
