Question about Logitech S 510 (967555) (DH967555) Keyboard and Mouse
Insertion of letter "s" in typing
When I type, the letter "s" keeps appearing in words, although I do not touch the key - any solutions?
    Scholar:
  • 109 Answers
That's a bit iffy. Have you spilled anything on the keyboard? It sounds like the key is a little sticky. I'd replace it personally, but if your so inclined, try popping the key off and use a q-tip with some rubbing alcohol to clean it up a bit. Then pop the key back on.
Usually you can pretty easily pop a key off a keyboard, although they all vary. I reccomend using a thin piece of flat rigid plastic to do it (the MacGuyver method would be something like the corner of a plastic putty knife - it's amazing how much tension they can put on a key without damaging it), a srewdriver tends to gouge the key and cause different sticking problems. Of course you do that at your own risk, some keyboards have retaining clips on the keys (especially low-profile and laptop keyboards). You alway run the risk of not being able to get the key to snap back on, or on some models the key comes off and a little spring goes flying and you never find it again. But again, that's up to you. The worst that can happen is you need to get a new keyboard.
Posted on Feb 06, 2010
How to remove code KYBD099
Take a look at the "L" key, if it has the word "lang" in green print at the bottom of the key, try holding down the "code" key while pressing the "L" key. This will take it out of language mode. This mode is only used if you have a foreign language keyboard.
Mar 08, 2016 | Lexmark Wheelwriter 30 Series II...
The "v" key is malfunctional. It does not input if I key it alone. The letter appears when I type a word with the letter v in it, but the spelling is wrong. It shows up after three letters or so. Sometimes...
Is this a laptop, phone, or a pc keyboard?
If it's a PC keyboard you might be able to pop the key out and clean under it. I have went as far to clean PC keyboards in the dishwasher. (low heat, no soap, no high temp dry... and then shake all excess water out... and let dry for a week or two.. before you plug it back up.) But do this at your own risk.
If this is a phone, and it is on a touch screen, then try going into settings and changing from samsung keyboard to default android keyboard.. or vice versa.
Sep 25, 2017 | Samsung Computers & Internet
My Electronic crossword puzzles by RadioShack comes on but will not do anything. I just put in new batteries. I do not have my manual.
Adjusting The Display
To increase or decrease the display's contrast so it is easier to read,
hold down FUNCTION, then press /\ or \/ on the cursor pad.
Playing The Game
1. Press ON/OFF to turn on the game.
If you have not worked a puzzle since installing or replacing the
batteries, CROSSWORD MASTER appears. Otherwise, the display is as it
was when the game was turned off.
2. To start a new puzzle at any time, press FUNCTION and 1 (I), 2 (O), or
3 (P) at the same time. 1 is for beginner-type games, and 2 and 3
increase in difficulty. NEW GAME LEVEL 1, 2, OR 3 Y/N appears.
3. Press Y to start a new puzzle. A crossword grid with flashing cursor
appears (O).
Otherwise, press N. The display appears as it was when you pressed
FUNCTION and 1, 2, or 3.
4. Press (or hold down) /\, \/, <, or > on the cursor pad to move the
cursor around the puzzle.
5. With the flashing cursor in the desired location, press ? to see the
clue(s) for the word(s) in that location.
Any letters you already entered appear, along with a dash for each
missing letter. The number of letters appears in parentheses - for
example, (5) for a solution with 5 letters. If the solution includes
more than one word, the number of letters for each word appears in the
format - for example, (5, 3, 4) for a solution with three words.
If the flashing cursor appears at the junction of two words (across
and down), both clues appear, across first, then down.
6. Press ? again to return to the crossword display, then use the letter
keys to type your answer.
If the flashing cursor was at the junction of two words and you enter
the first letter of your answer, two small arrows appear in the
adjacent across and down squares. Before typing the rest of your
answer, press > or \/ (across or down) on the cursor pad to indicate
which word you are entering.
Press /\ on the keyboard to erase the letter just above, and < to
erase the letter to the left of, the flashing cursor.
To erase a word, hold down FUNCTION and press WORD DELETE (Z).
To spell check the puzzle at any time, hold down FUNCTION and press
SPELL (T). The [+] symbol indicates the location of each incorrect
letter.
When you complete a crossword correctly, GAME COMPLETED appears.
7. Press ON/OFF to turn off the game. The current puzzle is saved.
(EB 12/08/98)
Privacy Policy
Mar 30, 2011 | Computers & Internet
Numbers appear w7hen i type certain words 7how do i solve t7his
You probably have the Num Lock on. The letters affected by the Num Lock are u, i, o,j,k,k,l,m.
The Num Lock should be located at the top right of the keyboard and is usually in blue letters although with some keyboards its lettered white. Hit the Num Lock key and that should resolve the issue for you.
Regards.
May 26, 2010 | Sony VAIO PCV-W600G PC Desktop
How to update my yahoo mail?
above the yahoo search toolbar there this word that says "All-New Mail" click on that and it updates it to the new yahoo mail.
Apr 24, 2010 | Yahoo Mail
What does the insert key do?
Press and the text you type will over write what ever you have on the screen. This is typically used in most applications to "type over" existing text without moving the other letters/numbers/characters around.
This is my example of how the insert key works.
hit the insert key and position your cursor at the "w" in works.
Now type WOW!!.
You should now have:
This is my example of how the insert key WOW!!.
Clever these programmers. :)
Keep in mind it depends on the application you are running also.
Have fun!
Oct 03, 2009 | Logitech Cordless Desktop EX110...
Need to disable touch pad because when i type letters go all over the place...on different lines and between word i already typed
Yes, this happens when you have a mouse connected to a laptop. I had the same problem .... was worried I had a serious problem. But when I disabled the touch pad, everything was fine!
May 18, 2009 | Averatec 3200 Notebook
MSI keyboard does weird things
I have a MSi laptop, and whenever I am typing, my cursr ejumps all over the place! Onto different lines, in the middle of other words. Why?? Please help!
May 15, 2009 | Intel Motherboard
When trying to text incorrect letters appear
There should be an option somewhere when you are in the message menu on how to switch from the text mode that tries to finish your words for you to the text mode where you have to push the button however many times to get the the single letter you want. Although if you are in the auto finish mode you can simply ignore what it's suggesting and continue spelling out the word yourself if you want. example: hit 9 6 8 one time each to spell the word "you"..buy if your trying to be able to short hand text like "thk u" your gonna have to look around in your text mode settings.
Jan 02, 2009 | Nokia 6126 Cellular Phone
Rt7d40 dell keyboard is non responsive
probably need to clean your keyboard
check keyboard settings in control panel
Nov 13, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Logitech S 510 (967555) (DH967555) Keyboard and Mouse Logo
130 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
