Question about Toshiba 51H93 51" Rear Projection HDTV
Power out, will not reset - Toshiba 51H93 51" Rear Projection HDTV
Reset canon printer MP500
The reset method for Canon Pixma MP500 All-In-One Photo Printer
1. Entering into Service Mode
  1. Start with printer connected to power cord (electric source)
  2. Press and hold STOP/RESET button.
  3. Press and hold POWER button.
  4. Release STOP/RESET button without releasing power button.
  5. Click STOP/RESET two times and then release power button.
2. Reset the Canon Pixma MP500 All-In-One Photo Printer
  • After the printer entering into service mode, prepare paper on the printer paper tray
  • Press Stop/reset button for 1 times and then press power button, await till printer finished print.
  • Press Stop/reset button for 2 times and then press power button, The printer will print again. Await till printer finished print again.
  • Press Stop/reset button for 3 times then press power button to reset EEPROM.
  • Press Stop/reset button for 4 times then press power button to reset Waste Ink Counter.
  • Switch off the printer. if printer doesn't turn off, press button power until printer off
Jul 26, 2014 | Canon Pixma MP500 All-In-One InkJet...
Tip
Reset Canon Pixma MP140
first you must know this information before starting:mabroukmedal_17.jpg
  1. Plug the printer to the power source
  2. press and hold the stop/reset button
  3. press the power button
  4. if the power led light, press two times the stop/reset button
  5. release the Power button and the stop/reset button
  6. wait, when the power led is green, press the stop/reset button 4times to reset wase ink counter.
  7. unplug the printer from the power source
  8. plug the printer again to the power source and power it on
  9. the counter is set to zero.
on Nov 30, 2010 | Office Equipment & Supplies
Hard reset button
Go for hard reset
  • With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
  • When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
  • When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
  • When the LED lights in green, press the Stop/Reset button 4 times
Oct 23, 2013 | Canon MG5250 Printer
How do I reset my SMC barricade g router?
hi Eric,
To Reset the newer Barricade Router, use the RESET button on the Router. It is found on the rear panel (except 7004ABR/7008ABR, where it is found in the front). It's a small pinhole blue button. Use a paperclip / pen / pencil to hold in. Reset can be done in following ways. If you find Power LED blinking, then it indicates a successful RESET......
Procedure 1 -
Unplug all the cables except the power cord.
While the Barricade is powered ON, Hold the RESET button for 30 seconds or as long as you find the Power LED blinks.
Procedure 2 -
1 - Unplug all the cables except the power cord.
2 - While the Barricade is powered ON, Hold the RESET button for 5 seconds.
3- While holding the RESET, turn OFF the power to the Router.
4- Continue to hold it for 5 seconds, then turn ON the power to the Router.
5- Wait for another 5 seconds and then release the RESET button.
Procedure 3 -
1 - Unplug all the cables except the power cord and Power ON the Router.
2 - Hold the RESET button for 3 seconds.
3 - Release the RESET button for 2 seconds.
4 - Continue Steps 2 and 3 for Four more times.
Sep 03, 2012 | SMC Barricade g SMC2804WBRP-G Wireless...
Canon MP145 error E27
  1. plug off power cable
  2. press and hold stop/reset button
  3. plug on power cable
  4. press and hold power button(still hold stop/reset buttn)
  5. still hod power button, loose stop/reset button
  6. press stop/reset 2X then loose power button, wait until 0 displayed
  7. press stop/reset 1X
  8. press power button 1X, printer will print 1 time
  9. press stop/reset 2X
  10. press power button 1X,printer will print 1 time
  11. press stop/reset button 3X
  12. press power button 1X ( no print proses)
  13. press stop/reset 4X
  14. press power button longer than before for turn off printer, if print not turn off plug off power cable
  15. turn on printer and error 27 will disappear
i hope this helpfull
thanks for using fixya
Jan 25, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Power light blinking not working cannot re set
Was there any power flicker before it happened?
1. Reset the router by pressing the reset button of the router for 15 seconds while the power cord is plugged in and while the router is powered on.
2. Release Reset button after 15 seconds and unplug the power cord of the router then press the reset button again for 15 seconds.
3. After 15 seconds release the reset button and replug the power cord then press the reset button again for 15 seconds.
If this didn't work.
1. Plug the power cord to the router, and unplug it do this 7 times then reset for 15 seconds while it's unplugged and plug it back it and press the reset button for 15 seconds and release it. Try to check if there's any changes.
Jan 09, 2010 | Linksys Wireless-N WRT150N Router
Waste ink absorver is full
kindly follow this steps to fix the error
Reset manual "Ink Absorber Full" for pixma
Steps by steps how to reset :
1. Turn off the printer but still connected to a power source
2. Press stop/reset button, and then press power button to restart
3. Press power again and then press twice the stop/reset button.
4. Press power & Stop/reset button together, to enter
the repair status and power lights will be green,
5. Press stop/reset button
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
6. Turn off the printer
7. Unplug the power cable.
8. Plug the power cable and then turn it on again.
Nov 12, 2009 | Canon PIXMA MP170 All-In-One InkJet...
How do I fix or reset ink absober full problem on canon ip4600
Reset procedure
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
Mar 13, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
How to reset low ink warning in mp145
Following is the procedure to reset waste ink counter Canon Pixma MP145 :
  • Connected Printer to a Power source, Turn off the printer if printer on
  • With the Printer power off, press the Power button while press and hold Stop/Reset button.
  • When the Power led is light, press Stop/Reset button two times while pressing and holding the Power button.
  • When releasing the Power button and the Stop/Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
  • When the on/off lights in green, press the Stop/Reset button four times to reset wase ink counter. For other specified number pressed function listed in the table below. (Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange).
  • Unplug cable power from a power source.
The number of the Reset button pressing LED Function Remarks 0 time Green Power off 1 time Orange Service pattern print 2 times Green EEPROM print 3 times Orange EEPROM reset 4 times Green Waste ink counter reset
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 20, 2008 | Canon PIXMA MP150 All-In-One InkJet...
HP office jet 7310
Please goto the HP website and see if there is a firmware update for this machine. Download and you can also download the procedure.
It seems to be that it's a controller issue and reinstalling the firmware will usually resolve the problem.
Hope can be some help
J
Dec 11, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Toshiba 51H93 51" Rear Projection HDTV Logo
21 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
