Question about Car Audio & Video
I have addzest monitor & dvd navigation unit, but it refuse to play all the dvd's.
  • 1,188 Answers
I assume that the DVDs are in good condition, clean and not scratched. I would normally say to clean the lens of the DVD navigation drive but if it is in a car, it may be too hard to clean the small lens with a q-tip and some rubbing alcohol, rub lightly and let dry. That is hopefully all the problem is.
If that isn't an option due to where the drive laser is or if you have it in a car, then you could purchase a CD that will clean the drive, but I would say if you cannot clean it with the rubbing alcohol, or if you do but that doesn't change anything, then you will need service, whether warranty or the dealer/manufacturer. If you can't clean the lens, of if cleaning it did nothing, it will definitely need to be looked at.
Good luck! EJ Kudelka ej@outlet3g.com
Posted on Feb 06, 2010
Thompson DVD DTH271E refuses to play HD DVDs but fine normal DVDS, cant seem to get any help via Thompson, & think may need "firmfare" update? New machine but in Spain & language...
Hello there.
Push "Play/Pause" and "DVD Rec" on the dvd recorder a few seconds to see the service menu. There you can find your firmware version.
Post back the version for us.
Hope this helps.
May 06, 2008 | Televison & Video
Addzest max540hd
Sorry I dn't have them
Jun 10, 2013 | Car Audio & Video
I need the location for the navigation system fuse for a 2006 licoln navigator
Before you get too involved in chasing fuses, please read this article: Where's The Fuse?
The navagation module shares a fuse with the Rear Control Unit, The DVD Player (If equipped) The Rear Integrated Control Panel (without DVD) It is fuse #4 (15 Amp) in the Central Junction Box (CJB)at the right kick panel. The Navigation Module also shares fuse #22 (10 Amp) with the Auto Dimming Interior Mirror and the Audio/Navigation Control Unit.
The Audio/Navigation Control Unit is also protected by fuse #31 (20 Amp) and fuse #7 (5 Amp) also in the CJB.
Apr 19, 2011 | Lincoln Navigator Cars & Trucks
I had the dvd player/radio /cd player replaced in my 2007 Yukon, the cd player would not read discs, the dealership ordered a new radio & now the dvd player reads disc region error & will not play...
If your using copies then some dvds wont read them even if the old one did, sometimes its a gamble if it reads or not, if your using a master then i would have them check it out, it may be bad or need programing, it funny because sometimes it will play a copy and sometimes not, thats what i've run into. hope this helps.
Aug 31, 2010 | GMC Yukon Cars & Trucks
DVD player car screen plays dvd in B/W , navigation in color
try checking the color system if its ntsc or pal
Jul 11, 2009 | Car Audio & Video
Hybrid navigation/tv package nva9400f
I might be able to help you with this. The Addzest Navigation system you have is similar to the Clarion NAX9500E. I have some bits off an Addzest NVA9400F and I bought a second-hand Clarion NAX9500E sat nav system. I have pdf's of the Clarion system that would enable you to get yours running.
I was able to get my Addzest system running but it is all in Japanese and I don't think you can change the language unless you know more than me. I hit the reset button but still in Japanes.
That's why I got the Clarion system instead and salvaged some of the Addzest leads.
My email is dazliggett@yahoo.co.uk if you want me to email you the user and wiring intructions for the similar Clarion Navigation unit.
It is a pitty that I wasn't able to use the Addzest navigation system but hopefully I can still use the
7" monitor.
If you still have the Addzest equipment I was wondering if you would sell me the lead that connects the 7" monitor to the Navigation sytems as I wanted to use that it as a rear monitor.
Hope to hear from you on what you decide as I haven't had much luck finding a lead for my monitor as the Clarion one is the same size but different pin configeration
thanks
Darren Liggett
Apr 05, 2009 | Clarion Car Audio & Video
Wiring diagram Max 2255 Addzest sound system
BE MORE SPECIFIC!
Why do you need to trace them? Is it a stock amp? If you know where the amp is....then tracing the wiring is a cinch....
The amp has to be powered, so there's most likely a power wire from your battery. If it's a stock amp, it's powered from behind your cd player. And be more specific, what speakers? There's like what, six?
They all go to one spot man, right behind the cd player.
What's spiking? The sound? As in it's loud, quiet, loud, quiet, loud? You might have a bad ground somewhere, so check grounds. Those are easy to find, behind the deck the ground is black. If it's an aftermarket amp, then the ground is going to be close by to it. It's most likely screwed to the steel part of your car.
It could be your deck to, it might have just got randomly defective. You do have a 96 after all.
If it's an aftermarket cd player...check your wiring harness. You have to cut the wires from the car to tie them into the harness for your cd player, so jiggle those around to see if you can hear a difference.
Jul 21, 2008 | 1996 Mitsubishi 3000GT
Disk error
if its a burned disk some pioneer units do not read burned movies or music
Feb 12, 2008 | Pioneer AVIC-N2 DVD/CD/navigation receiver...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
