Question about Roper RAX7244KQ Top Load Washer
I had recently moved the washer around a bit during a remodel. I had to hook it up in the garage to a hose so I could do laundry. All that happened was that water seemed to run straight through it. In from the hose and out through the drain. The timer knob stayed where I had set it but didn't start. It acted like it never filled. ?????????????????????
  • 129 Answers
Some washers need the hose to have an elevation. If te hose is lower than the water pump the water will free flow through the washer . The job of the pump is to carry the water up and out of the hose. The hose is the stopper for the tub.
Posted on Feb 06, 2010
I need a detailed diagram for my Amana Washer model #ALW540RAW
The pressure switch sends the signal that tub is full and agitation should begin. As a rule though pressure switches are long lasting parts. Usually the problem is in the tube that goes from the switch to a bulb or box on the side of the outer drum. The hose can become disconnected, for example if machine was recently moved, or even a severely unbalanced load. Sometimes a tiny piece of lint can obstruct the hose from the bulb end.
http://www.appliancepartspros.com/parts-for-amana-alw540raw-palw540raw.html
Hope this helps.
Jan 21, 2013 | Amana Clothes Washer / Washing Machine...
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore 500 top-loading washing machine that we just bought 1 year ago. We just had some remodeling done in our kitchen/laundry room and all appliances were removed. After re-installing the...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The easiest thing to check (and likely the problem) is the Lid Switch.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jan 10, 2011 | Kenmore Washing Machines
The washer is 2.5 years old. The Basket has no stability during the spin and wash cycle. The basket bangs against the side of the machine and the machine bounces around the laundry room moving sometimes...
they do dance well dont they? this is caused by the support springs coming off the drum holder and the drum will have droped a little as well,
take off the top of the washer and look down each side you should see the support springs if the off just hook them back on or fit new one's?
dont leave this as it will pull all the pipes off inside the washer
its an easy fix,
Aug 09, 2010 | GE Energy Star WCVH6260F Front Load Washer
I am trying to hook my washer up to a laundry room valve, but it keeps leaking and giving a "NF" code... Is the valve faulty or does my washer need a new hose to hook up to a brand new home's valve?
try changing the washers in the hoses / don't use red outside hose washers/ but hi pressure for fill hoses . home depot should have them . and ck the valve screens at the washer side . clean screens good washers . ( water flow's and washer should work .. mm
Dec 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Roper RAX7244EQ1 Vibrates during spin cycle
Dear customer
Please perform the following checks
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Nov 21, 2008 | Roper RAS8445KQ Top Load Washer
Wash cycle will not start
you may have leaned on lid and damaged the lid switch , so the washer thinks the lid is open all the time unit will fill then stop with lid up.
Apr 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine dance
I have the manual here please post your email and i will send it to you... The balance ring may have lost it water so yes it may need replaced.
Jan 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Roper RAX7244KQ Top Load Washer Logo
23 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
