Question about Linksys Wireless-G WMP54G 802.11g/b
My card is not finding my 2WIRE conection it has its drivers but still wont work
  • 1 more comment
  • jangofett890 Feb 06, 2010
    i do not have a router i have a modem and its a desk top and i have tried it on a difrent computer right next to the modem and it did not conect now that computer is conected to the modem with ethernet now i want the other one wireless so i dont have to drill a hole under the house to conect to the modem with ethernet
    model 2701HG-d and my ps3 and psp can conect to it wireless my the one used to work with a usb abdapter but that broke also that usb abdapter would go online then off line and playing games online when the game was on internet off
  • 298 Answers
If everything is installed correctly, thing that you might want to check first are:
* Location of the desktop or laptop . It's possible that it might not be getting a strong signal from the router.
* If the wireless adapter has an antenna, make sure that it's in a spot where it will be able to get a good to excellent signal strength. Make sure there is nothing that can block the signal from the router like, walls, tables, and other furniture that can block the signal.
* Do you have other computers that can pick up a the signal of your 2wire router? If you have a laptop that can connect to the same router, bring it in the spot where the none working computer is, see if the laptop will have the same issue.
These are things that you can start checking before going to more technical stuff.
Posted on Feb 06, 2010
  • Jeffrey Pedimonte
    Jeffrey Pedimonte Feb 06, 2010
    Do you know if this modem has wireless capability? If this is just a regular modem, it will only allow one computer to get online through Ethernet connection, and most likely does not support wireless. Could yo provide me with the model no. of your 2wire modem so we could check if is support wireless connectivity?
  • Jeffrey Pedimonte
    Jeffrey Pedimonte Feb 07, 2010
    Alright, if there are other device that can connect to the 2wire modem via wireless I can say that we have already isolated the issue.
    Did you check if the desktop can pick up the signal of the wire modem? Since you have PSP, use it to test if it's signal . You can bring your PSP in the same room where the desktop is located. Then use the PSP to view the available wireless networks, by doing this we will know if the signal if getting in that room.
    If you're PSP will pick up the signal of the 2wire modem, the computer should also pick it up. Then you connect to it and put in the network key, if I am not mistaken there is default network key for a 2wire modem found at the bottom of the device, it says WEP key.
I can't get my computer to conect to my 2wire modem. how do i do it
you are going to have to use the driver cd that came with the modem also is this your first time hooking up there are instructions in the quick start guide that tells you where to find the drivers on the cd. i know because i use a 2wire modem i can help you, but if you just follow the guide you will be up and running.
Mar 24, 2010 | 2wire Computers & Internet
I lost the driver
This is always fun and a bit annoying.
You should be able to hook up to the internet using a wired connection and just download if that was setup. If it wasn't then you will need to get a friend to download the drivers and save them to a disk for you.
http://www.2wire.com for the main pages then click on support. Find your model of card and download the software drivers.
If you have used the card before it may still have the drivers. Insert the card and make sure one that it is detected and two that it doesn't find the drivers.
Jul 10, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Linksys wireless adapter won't auto connect to 2Wire router
Go into the wireless adapter settings and make your connection "default" and then it should connect automatically .. and if not then look for a "connect automatically setting
May 29, 2009 | 2wire HomePortal® 1800HW Router...
I have a 2wire 2700HG-B router and I've had a problem connecting on a wireless connection. While the wireless card finds the network and connects, it has limited or no connectivity because the router...
The 2wire is setup with a default network key. Change the network key on the 2wire to another key or type in what you think the default network key is on the 2wire.
Jan 07, 2009 | 2wire 2700HG-B Router (2700HGB)
2 Wire 802.11g wont stay connected
Hi, had the same prob. I was able to fix it. The file set you downloaded for the driver (TWWGPC_TEMP) has a file in it called Wireless Cfg, run that if you haven't already, that will configure the card. Then open the folder CMG and run the Setup file. This will install the Wireless Client Card Utility. In the utility add the network(s) you connect with to My networks. After I did that the intermittency of the connection went away. I hope it works for you too.
Dec 04, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
I need help installing my 2wire wireless adapter card.
I used this one:
Introduction
This document describes the procedure to install driver for the 2Wire Wireless USB Adapter under Microsoft Windows, and to run a wireless configuration program to configure your 2Wire Wireless USB Adapter to work with a 2Wire HomePortal or OfficePortal wireless gateway. These drivers work under Microsoft Windows 98SE, ME, 2000, and XP.
STEP 1 - Driver Installation
1. Make sure your 2Wire Wireless USB Adapter has not been connected to your computer USB port.
2. Double-click on the file to run WinZip Self-Extractor. The driver installation files will be placed in your hard disk in the C:\TWWUSB_TEMP directory
3. Connect your 2Wire Wireless USB Adapter to an available USB port in your computer. Windows Found New Hardware Wizard will startup.
4. Select the option to search for driver in specific location. Specify C:\TWWGUSB_TEMP as the location of driver.
5. Follow on-screen instruction to finish driver installation.
STEP 2 - Wireless Configuration
1. Run the program WirelessCfg.exe in the directory C:\TWWGUSB_TEMP. You can do so by clicking on the Windows Start button and select Run. The Windows Start button is typically at the lower left corner of the screen. Type in C:\TWWGUSB_TEMP\WirelessCfg.exe to launch the program.
2. Follow on-screen instruction to configure your wireless setting. Enter the serial number and encryption key as they are printed on the bottom of your 2Wire wireless gateway.
Sep 28, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Computer recognizes the card, but configuration utility does not?
Hi
Install the compactable drivers,You can find all the drivers and the manual for your Wireless Adapter here: http://www.2wire.com/?p=331
May 28, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
2Wire USB Remote NDIS Ethernet driver
There's only one driver listed at the bottom of the page.
Apr 16, 2008 | 2wire 1800HG Router (RG1800HG00)
Challenge please Help! Cant install the driver "code 10 problem with the installation"
you dont need a driver, open your web browser and type in the address bar 192.168.1.254 and you will get into the router and add your settings manually, so long as your router is set up correctly
Nov 05, 2007 | 2wire (1000-400108-001) Router
Linksys Wireless-G WMP54G 802.11g/b Logo
155 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
