Ive just had a new valiant 28 pro boiler
Ive just had a new valiant 28 pro boiler fitted.The problem im experinceing is the hot water is not as hot as it should be. The installer explained to me that the bolier gives a rise of 35 degrees at max flow,which i have also read in the manual. When the tap is fully open it is flowing at 9 litres a minute at a temperature of 43 degrees.The incoming water temp was 8 degrees.The boilers max flow rate is 11.5 litres,because its only flowing at 9 litres shoudnt the temp be higher.
  • Heating & Co... Master
  • 2,519 Answers
The faster the flow the low the temp , the slower the flow the hotter the temp
Posted on Feb 06, 2010
Testimonial: "Not very helpful"
  • paulcarew Feb 07, 2010
    you can google your boiler and down load a manual or falling that if it is still unber warranty valliant might send one of there own techs out to you ,
    but the faster the flow through the heat excahger the cooler the temp so may be your water valve is not fully opening to obtain full flow or the heat senser is not working correctly on the hot water side .......
I have a vaillant eco pro 28 combi boiler. no constant hot water unless tap is on really low.
Oh some of these there was a small black heatexchanger just for hot water they some times block up . or it could be a blockage in the water section where it flows in .I know Valliant have a very good tech line and fitters who do house calls .
Mar 02, 2017 | Water Heaters
My valiant ecotec pro24 boiler wont heat the radiators up,i hav hot water.i just got new meter fitted 2nite+its been 10month since i last used my gas,my pressure is 1.6bar but just cant get heat from...
Have you checked automatic air bleeder on main supply line. I would make sure it is working and bleed each radiator if possible. If you haven't used heat for 10 months I would suspect a build up of air in system. I hope this helps you. Thanks
Nov 29, 2010 | Heating & Cooling
Hi my vaillant eco tec pro shut down last night showing fault f.28 and will not ignite today 08/01/2010 looked out side to see the condenser pipe was frozen i defrosted the pipe but boiler still wont...
Got exactly the same problem with mine. Manual says f28 = fault in gas supply, gas pressure too low. Boiler will ignite but goes out within minutes? HELP!
Jan 08, 2010 | KDS Valiant 6380iPTD-01 Notebook
Hi i get fault 28 on my vaillant boiler
F-28 is a common error for my vaillant. I have had this problem serviced at least 10 times (all under warranty). It is an ignition problem and can be connected to a number of things. I have had the starter electrodes cleaned only to later have them replaced(4 times). I just had the "panel" replaced yesterday (looks like a motherboard or electronics panel). This is the second time to have this replaced. All of these things can give you an F-28 error message. I have an atmotech pro and have had ongoing F-28 issues for two years. They are looking at venting/air issues as well to see if this is the problem. douglas
Dec 20, 2009 | KDS Valiant 6380iPTD-01 Notebook
Valliant ECOmax boiler is not giving me any hot water
My Valliant Ecotec Pro Combi Boiler (approx 4 years old) does not start up. The fault code showing is F.22. I would be grateful if you could let me know what the problem is and obv how it can be fixed. Thanks and regards, Joanne Byne
Jul 03, 2009 | KDS Valiant 6380iPTD-01 Notebook
Boiler overheating
the problem there a relay stuck or thermostat bring on the pump & you can lower your high limit aquastat!! also the flow valves can bypass hot hot water risers time to put in a seperate water heater domestic coil are not energy efficient !!!! aquastat high limit set @ 180f deg low limit set @ 140f deg!!!
good luck!!! tim
Oct 08, 2008 | Water Heaters
Boiler not working
necesito los controladores de sonido y de video de esta pc laptpn kds valiant 6380IPTD atte:herbac31@yahoo.es
Mar 11, 2008 | KDS Valiant 6380iPTD-01 Notebook
Heating & Cooling Logo
159 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
