Question about LG Refrigerators
My new iluminator refrigerator (GN-422FS) keeps beeping - I've just turned it on - why is it doing this?
My GN9330 headset keeps giving me repeated 3-beep descending sound sequence and will not allow me to talk. I need Help!!
I have three GN9330e all doing that. It's a pairing failure, and probably why Jabra discontinued the product. Jabra will tell you to work with your retailer/distributor if you're even within warranty. They wouldn't provide me any other help.
Aug 18, 2011 | GN Netcom GN 9330 Wireless Headset
I have a GN Netcom 8000 and I hear a beep in the headset every 12 seconds. Any ideas why?
Had the same problem with mine did not realise that there are batterys in the unit and they are going flat. Open the top and look on the right side, there are 2 aaa's inside. Replace those and you should be fine
Sep 16, 2010 | GN Netcom GN 8000 MPA Mulitpurpose...
The fridge keeps beeping. Door is closed. Different beep than door beep. Tried turning off and turning on again, keeps beeping.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 22, 2010 | Fisher and Paykel Active Smart E522B...
Hi, We have a GN 6210 wireless headset and it doesn't seem to want to hold a charge anymore. It's good for about 1 hour and then starts beeping and goes out. Is there a battery or something that I need to...
When I used this model in the past, it appears that the battery wasn't holding a charge after a year of use. I called them about it and told me that the battery wouldn't hold a charge anymore, there wasn't a battery replacement for it, and that I would have to replace it.
I believe Jabra is currently doing the support for GN. Support can be reached at this link:
http://www.jabra.com/Sites/Jabra/na-us/pages/Support.aspx
Dec 02, 2008 | GN Netcom GN-6210 Consumer Headset
GN 9120 beeps constantly
Are you using the GN1000 Handset Lifter? And if so, are you playing music/radio through the speaker of your telephone? If this is the case the Lifter will be picking up the sound of the music coming from the telephone and interpreting it as an incoming call, hence sending a signal to the earpiece in the form of beeps. Just stop the music coming from the telephone and the beeps should stop.
If you are not playing music through the telephone, you may need to turn down the sensitivity adjustment on the back of the Lifter. Just turn the knob anti-clockwise a little bit and see if that eliminates the beeping. If the sensitivity adjustment is too high it will pick up every little noise that goes on around your desk and interpet them as the phone ringing.
If you are not using the GN1000 Handset Lifter, then the beeping may be the result of a sticking/stuck volume button on the earpiece. If you adjust the volume on the GN9120 it gives a beep when you reach the maximum or minimum volume. If a button is stuck down it will result in a constant beeping. A stuck button is generally not a user servicable problem, however a little bit of tinkering with the button may get it unstuck.
Nov 19, 2008 | GN Netcom GN 9120 Professional Headset
GN Netcom 9120 unexplained beeping
Actually what she was hearing was the ring tone in her headset when a incoming call comes in. The sensitivity on the handset lifter that picks up the ringing on a incoming call was set all the way up and was picking up interferance from the headset base as they have the tendency to buzz when placed right next to the phone. I just turned down the ringer sensitivity with the adjustment on the handset lifter and that took care of the problem. Thanks for your time.
Nov 06, 2008 | GN Netcom (9120-48) Wireless Headset
GN Netcom GN 6210 - headset, no worky
Not sure what you mean by won't turn on.
If you mean no dial tone when you take it out of the cradle, I have run into this. The solution is to unplug the power cord and then plug it back in which resets the unit.
May 27, 2008 | GN Netcom GN-6210 Consumer Headset
Pairing GN Netcom GN 6210 with my iphone
Press the talk button on the 6210 Device and hold it until you here (2) faint beeps. Walla! (poor design and documentation?)
Mar 08, 2008 | GN Netcom GN-6210 Consumer Headset
GN 9120 Headset
Hold down the middle button on your headset for 6 seconds until you hear a series of beeps. Then hit the + sign about 2-3 times and then press the middle button again to disconnect. This should fix the issue. Make sure to call someone to test this as you may have just turned the volume up way to high. If that is the case, then you need to repeat this process using the - button instead of the + button.
Nov 27, 2007 | GN Netcom GN 9120 Professional Headset
Refrigerators Logo
83 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
