Question about Honeywell Programmable Thermostat Heater
Honeywell th6000 thermostat installed. It shows only heat-or off- no cool. The fan doesn't show up as auto or on. Now air conditioner has turned on and it is -15
  • 98 Answers
If you just installed the stat, you need to enter installers programing to set it up. To do thi, press and hold "UP" and "FAN" until a number on the left and right show up. The left number is the function and the right number is the setting. You do not specify what type of system you have, so i cannot tell you exactly what settings. But here is a link to the installers manual. the installers program settings is about half way down. http://www.forwardthinking.honeywell.com/related_links/thermostats/focuspro_6000/install/69_1920es.pdf
Posted on May 09, 2010
Thermostat is set to HOLD. Why doesn't the air conditioner turn on?
You need to look at the mode setting. It should have a selection for heat, cool, and maybe auto. If it is set to heat the air will not turn on. I needs to be set to cool or auto if you have it.
May 12, 2015 | Honeywell Programmable Thermostat Heater
Honeywell thermostat blank screen on cool
I wonder if they shorted a wire a during install. That is where I would begin.
May 14, 2013 | Honeywell Rth2310b 5-2 Day Programmable...
I can not get the fan to turn off on my heating & cooling
Be sure the thermostat is set to "auto" for the fan. If this is not the problem then either the thermostat is bad or you have a bad fan relay in the air handler.
Hope this helps.
Sep 23, 2011 | Honeywell Heating & Cooling
To turn on the air conditioner, on the thermostat do you click it to Auto and then on the other side click to Cool? Or do you click on Fan and Cool?
If you put the fan to auto, the fan will run only when the compressor runs. the other position it will run untill you switch it back to auto. Then cool unless you require heat at night or in the morning, usaually when I start cooling season the heat stays off.
Jul 05, 2011 | Honeywell Heating & Cooling
I have an intertherm electric furnace FEH-A020, with multispeed blower installed when A/C added. My problem is blower operation. at the end of the cooling season with fan set to auto operation the fan ran...
The model of T-stat you gave comes up as a discontinued model on Honeywell's web site, but it looks to be a manual stat that type of stat would have to be wired with a summer winter switch with electric heat, allowing it to turn on the fan with a call for heat. If yours is a programmable T-stat you would need to select electric heat or in the installers set up change the default setting for fan from unit controls fan in heat to thermostat controls fan.
Oct 17, 2009 | Intertherm P3RA-048K Air Conditioner
Honeywell TH6000 series thermostat does not turn Fan on.
It's one of two issues; either the wiring to the thermostat is incorrect, or possibly you have an open ground. Depending on your system the wires at the thermostat end might have to pair up on one lead. go to where your unit is and look at the schematic for the control board, it will let you know what color you are looking for on the blower lead -- then make sure the corresponding color matches at the thermostat. Knowing the make and model of you unit and the board on it would allow me to be more specific, hope this helps you out some in the meantime.
Jun 17, 2009 | Honeywell Focus 6300B 5-2 Days...
Display is blank and furnace fan stays on
Remove wires at tstat Turn switch for furnace off than on.
touch the red wire to the white to simulate a call for heat.
Or Touhc red green and yellow to simulate a call for cool.
If that works get a new thermostat.
May 10, 2009 | Heating & Cooling
Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Nov 24, 2008 | Honeywell Electronic Programmable...
Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Sep 30, 2008 | Heating & Cooling
Heating & Cooling Logo
448 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
