Question about Sony Video Game Consoles & Games
PSP Screen goes dim, gets bright when unit is twisted
OK, I suspect one of the boards or ribbons is damaged. The PSP starts OK, runs well, but intermittently the screen will go dark/dim. If I twist the PSP in my hand (yeah I know) it comes good for a period.
I bleieve it was originally caused thorugh my kids playing with it and twisting the PSP thinking that would make it turn a corner more or something?
Is it the LCD/it's ribbons or one of the boards?
I can source most parts (Ebay) and have no probs in fitting, just need to isolate what part it is.
Sorted it by bodgying with a piece of cardboard to apply pressure to the button bar.
A solution, crude, but a solution none the less.
Posted on Feb 07, 2010
Powers up,shows time/date not set but no buttons work.screen also dim.
2 possibilities that I can think of for your camera are;
1) The ribbons for your keypad and screen are slightly out of their sockets causing the problems and just need fitting back correctly.
2) The ribbons are damaged and will need to be replaced.
The buttons on the back are all run from the same membrane and connected to the main board. The on/off and picture/zoom functions run from a different ribbon.
If the screen is dim then the back light is either set too low or as I said ubove it is either damaged or not in it's socket correctly.
Only way to know for sure is to open it up and have a look.
Sep 23, 2009 | Fuji FinePix F40fd Digital Camera
The on off button on front doesn?t turn the unit off and on
Same here, your light went out if you put a VERY bright light on you'll be able to see something on the screen if you plug it up to your computer, if you are getting a new one go dell its worth it becase they last and are durable.
Jul 03, 2009 | Gateway FPD2275W LCD Monitor
My monitor goes dim after a few minutes. When you switch it off and on again the dsplay is ok then becomes so dark
How dim is dim? If the picture is still visible just like half as bright then your have backlight tube problem and unit LCD needs to be replaced, not worth repair price. If the picture goes out almost to a black screen where you can just bairly see a faint image then you hold the screen just right then you have a backlight inverter issue. If the problem is the inverter then you should be able to replace a few parts and get your unit back going. If you think you can open the unit up and maybe solder a few parts then I would open the case and look for bad capacitors on the power supply board. I can send you pictures of what to look for if you are interested. We also have a repair service for those units, most power issues run $15.00 plus shipping. Let me know if you need help opening the unit and checking parts.
Jun 17, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Laptop screen flashes... i.e.... goes bright then dim
Check your power supply. Maybe its wire is broken then intermitently making contact every now and then. Its my first suspect. Its like disconnecting and reattaching its power supply only in much faster way. Or test it with a good similar power supply if this will be the same.
Hope this one helps already.
Apr 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
The screen on my Apple Powerbook G4 goes dim and sometimes out.
How long before it goes dim?
Does it start strong, then dims right away?
Feb 27, 2009 | Apple iMac G4 Desktop
Back light does not work on board
All You Need To Do Is Press The Small Square On The Bottom Of The PsP
Feb 24, 2009 | Sony PlayStation Portable (PSP) Console
Dark screen
If you are unable to change the contrast with the 'fn' key and the brightness controls, usually represented in the top row of keys as a sun icons, one brightens, one dims. You may have a bad brightness/contrast inverter in your display. It's a small circuit board in the display that controls the brightness. They do fail. You can find them for most models but depending on your technical ability, they can be a little tricky to change.
Jul 26, 2008 | Compaq Presario V4000 Notebook
Screen seems to be too birght
It could be the mother board or more likley the battery pack is starting to wear out.
I would suggest trying the playstation support website:
http://uk.playstation.com/help-support/psp/
If you can't find anything there than try buying a new battery pack.
Jan 14, 2008 | Sony PlayStation Portable (PSP) Console
Nintendo DS Lite
Well something more appropriate i guess would be my ongoing issue with DS's that have had screens replaced.
if you could describe something for me
as the unit will not power ,,, plug in the charger, if it is as i suspect you will get an orange light illuminate for 1 second, after it goes off the unit is unresponsive until you unplug and replug the charger.
if this describes your problem i would be most interested to hear weather you used the ORIGINAL screen or if it is a replacement screen
thanx
Nov 14, 2007 | Nintendo DS Lite Console
Video Game Consoles & Games Logo
99 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
