Car Audio & Video Logo
Posted on Feb 06, 2010
No power and protection light clicks on and off
Anonymous
Level 1:
New Friend:
  • Contributor 63 Answers
  • Posted on Mar 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
63
Questions
0
Helped
11662
Points
76
Check your battery wire fuse. And check your fuse on your amplifier
2answers
Hi;my Yamaha receiver RX-V 373 will not turn on. No power. No display. It may be that the unit went into protection mode. Can anyone there, help me, restart my unit back to factory condition?
If you have power it should click before protection mode and have a light showing it's in protection mode.
After the transformer there's some resistors that have failed if it's in protection mode normally it's one or two that have failed, you can get the reading of what they should be by testing them
2answers
Akai model ws-p28ntf-sf-d-gb (s) tv/dvd combo
Disconnect it from power cable 30 mins, see if this reset works, for the rest sounds like you have a problem with the power unit.
Does anyone know what kind of transformer is in a soundcraftsmen class H power amp
Your Soundcraftsmen's transformer is ok. The protection circuit is kicking in and clicking because there's a problem on the outputs or else where.
Go to this link and read the last page for possible solutions. WARNING: Do not perform the reapir yourself if you do not have proper experience with high voltages!!!
The lamp indicator turns on
The clicking noise is the protection switch that keep shutting down the unit. This happens when an internal fault had been detected.
Do the following:
Unplug the unit from power for some time.
Remove the bulp and refit it in place.
Restart the unit.
If still in protect mode (clicking , lamp light and no start), then there is a fault.
When the problem is the lamp, the lamp light will come on, but usually protection does not click.
Before buying a new lamp that is expensive, have the projector checked, testing with particular attention the high voltage board that will supply power to the lamp. That may be the fault.
If you have a replacement lamp in storage replace the lamp first.
2helpful
Power switch wont turn on,keeps clicking
The fault is not a relay, the clicking sound is just the protection circuit that prevents the TV from starting because a fault had been detected.
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
2helpful
2answers
Continued from no picture no sound just clicking
The TV is on protect mode. The clicking sound is the protection switch that keep turning the TV off to prevent further damage, this happens when a fault had been detected.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
SONY TA-N77ES POWERS ON BUT PROTECTION LIGHT STAYS
dry joints are common in sony (and others), needs a tech repair\visit
Alternate red light blinking of ink and paper botton
saw this on the internet too...
http://www.sscllg.com/epsone.shtml
2. In Configuration tab of the SSC window, select your installed Epson printer and Printer Model
3. Plug-in the printer to your PC and turn the Power On.
4. In your tray, right-click SSC Service Utility, go to Protection Counter, then click Reset Protection Counter.
5. A dialog box will appear, just click Yes.
6. Right-click SSC again in your tray, go to Extra, click Soft Reset. Then say Goodbye to the annoying alternating red & green lights.
1helpful
42pf7321d/37
relay clicking is a power board failure --- part of the board still works to supply power to the flashing lights--- the lights are related to an error code while in protection mode
1helpful
Clicking sound!
Top Kicker Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
