Call your mobile phone service provider. they will provide you the PUK code.
This is just so common... here is whats what.
PUKs, or personal unblocking keys, are used to unblock a mobile phone which becomes blocked. Mobile phones may become blocked when a PIN (personal identification number) is entered incorrectly on three consecutive occasions. In some instances, the phone may become blocked, which requires a PUK to unblock it, and in other instances, the SIM (Subscriber Identity Module) card itself becomes blocked and again will require a PUK to unblock it.
Mobile phones are also blocked when they are reported stolen and if there is an outstanding payment on the account.
It is important to differentiate between unblocking phones (using a PUK) and unlocking mobile phones (using another type of code). More information on unlocking phones will be available here in the very near future.
NOTE: It is a criminal offence for anyone to attempt to unblock a mobile phone, other than the network provider who put the block on the phone.
If your phone has become blocked by mistake, for example you have entered the PIN incorrectly on three consecutive occasions, then you need to contact the mobile phone network operator with your details. To explain a little more, specific to your mobile phone network, use the links above to navigate your way to the specific PUK details for your mobile phone network operator.
SOURCE: pin code blocked
Hi everyone
Every PUK code is unique so nobody can tell you your PUK number, but i will tell you what you can do!
1)
If you still have your packet that your Sim Card came in, you should
find your PUK number in there, if you don't have the packet, please
read bellow.
2) You must get a phone that is on the same network
as your phone and call the networks Customer Care and ask them for your
PUK number, they will ask you for your phone number, then they will
tell you your PUK number. Once you have done this, you will be able to
reset your Pin number so you will be able to go into your phone again.
Please also remember to give this solution a FixYa! rating if it helps you.
Kind regards
Dustin Ellse
SOURCE: I've tired to set the PIN code for my Nokia 6085 phone but I cannot.
HOLD ON!
You may enter wrong PIN three (3) times only. After that your PIN will be blocked!
To unblock, you need PUK. You can only enter wrong PUK ten (10) times. (This is as documented)
After entering correct PUK, you will be asked for NEW PIN.
So, when it says "PIN blocked. Enter PUK code", you must enter the PUK.
If you correctly enter the PUK, it will asked for new PIN, by asking "Enter new PIN code:". Enter anything you want as your PIN. You will be asked to enter it twice (two times).
From what I read from your post, you have done correctly, but you don't want to enter new PIN. There is no way SIM card/phone will use old PIN. The device doesn't know your PIN. So, you have to enter new PIN.
SOURCE: sim card blocked
Because its PUK (pin unblocking key) that is provided from u r Cellular service provide they set the security for sim if u enter wrong puk more that 10 time u r sim will be block That not able to use again u need to contact u r Cellular service provide they will gime u new sim with same no.
SOURCE: nokia e71x pin code blocked , enter puk code
Service Provider will give the PUK Code....You can call them..
