Keyboard is there any other way to type at as the at key does not work
    Scholar:
  • 86 Answers
You can use the ASCII code, here is the table.
http://www.asciitable.com/
Most of the keys on the keyboard refer to an ASCII code. Like if you want to type the letter "A", just hold down the "Alt" key and type "65", then release the "Alt" key. Try it in notepad. I have used this trick a few times. Look at the extended ASCII codes.
ASCII stands for American Standard Code for Information Interchange.
¥ ω £ ½ π σ
Posted on Feb 21, 2008
  • Nathan Galloway Feb 21, 2008
    You can always get another keyboard.
    I get them cheap at microcenter.
    http://tinyurl.com/33tmnb
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Delete key not working
    Instead of relying on the physical keyboard to type and enter data, you can use On-Screen Keyboard. On-Screen Keyboard displays a visual keyboard with all the standard keys. You can select keys using the mouse or another pointing device, or you can use a single key or group of keys to cycle through the keys on the screen.
    To type without using the keyboard
    • Open On-Screen Keyboard by clicking the Start button clicking All Programs, clicking Accessories, clicking Ease of Access, and then clicking On-Screen Keyboard.
    or
    Type "osk" no quotes on run...
    Hope it will help you....
    Sep 06, 2014 | Toshiba Satellite Computers & Internet
    Do i have a faulty "A" key or a faulty keyboard?
    You will need to purchase a keyboard replacement. Thanks for using FixYa! You can purchase them rather cheap at Amazon.com
    Feb 06, 2012 | Dell Inspiron Computers & Internet
    I type j and it comes out 1. can't fix.
    Try this.
    Press the Start key + R.
    type osk in that box and hit enter
    On this keyboard, try toggling numlock scrolllock and capslock a few times. does it help?
    I think your numlock might be stuck on and your keyboard "num lock" key isnt working
    Jan 04, 2011 | Computers & Internet
    2 letters get typed while pressing one key for some characters. There are some keys in pairs in which if i type any of the key, both the letters gets typed. i.e. if I type s, sd gets typed or evens if I...
    try other keyboard if the problem don't appear that's hardware problem, may be the rubber under the key responding each other, it is easy to open the keyboard casing then you can check the problem inside
    May 13, 2010 | Computers & Internet
    My keyboard letter types wrongly to type @ I have to press shift and 2
    UK keyboards use a different key for @.
    If you wish to change the keyboard layout, you can do this by right clicking on your taskbar and select "language bar". When this is done, right click on the keyboard symbol and select "settings". Change the default language (to UK) and your keyboard will type correctly.
    Jul 18, 2009 | Gateway 7001433 Keyboard
    Dell laptop keyboard and a not working
    Your have a problem with your alt key you have replace the keyboard because one of your may be alt key is pressed from inside
    Jun 26, 2009 | Gateway 2520915 Keyboard
    Keyboard is not responding to every letter I type
    see if your keyboard have powder, do you need to clean it, if is not resolved this, see the keyboard in the control panel.
    Jan 03, 2009 | Microsoft Multimedia Keyboard/Wireless...
    Acer aspire 3003wcli keyboard stopped responding
    You probably activated the "Num Lock" accidently. Just hold down the FN and look for the key that says "num lock" Now you should have your keyboard back and the numbers will just type when you hit the numbers key. I did this to myself yesterday!
    Dec 06, 2008 | Computers & Internet
    Keyboard & Mouse Problem
    Seems like you Ctrl-key is pressed all the time somehow.
    Make sure that none of the Ctrl-keys is stuck.
    If you try another keyboard, everything should work fine, so just check your keyboard. Maybe you need to replace it.
    Apr 14, 2008 | Dell Wireless Keyboard Optical Mouse w0147
    Computers & Internet Logo
    883 people viewed this question
    Alun Cox
    David Payne
    David Payne
