Try a new set of batteries for your camera and try to switch it on.
If that doesn't help then try these,
A stuck automatic lens cover may be your problem, but it is normally easy to fix.
Try these:
1) Try blowing lots of compressed air around the lens cover to clean
the mechanism. Or use a hair dryer for a few seconds (don't want to
heat up the camera). Use no heat mode if possible.
2) Slide a thin
strip of paper between the lens cover shutters and the outer support
ring. Work it around 360 degres to clear out any debris that may be in
there.
3) With the lens barrel extended and pointed downward, tap the
lens barrel with a pencil while you extend and retract the lens by
powering the camera on and off.But this step may not be a option since your camera is in a dead state.
Repeat the above steps several
times. If repeated tries don't work (keeping in mind that it usually
does),
it then may be necessary to open the lens barrel to access the
lens cover mechanism.
But if you still got the warranty , you better leave this repair work to the panasonic service center.
Refer to this site for support.
www2.panasonic.com/consumer-electronics/support/Supplies-Accessories/Cameras-Camcorders/Digital-Camera-Accessories.75681This is just initial help, tell me how things turned up, so that i can follow you up,
Waiting for your comments.
Hope my info helps you,
Thanx for using fixya,
