Question about Garden
Lawn mower Tecumesh Centura xl/c Elite Lawn Mower Engine running rough then stopping. Good fuel and oil. PLug replaced. Stripped the carby, found lots of gunk, washed it out and cleaned it. BLEW COMPRESSED AIR INTO FULE INLET OF CARBY. Heard a noise like a blockage clearing, felt happy. Re-assembled. Fuel now leaks continuously from carby out of hole that air inlet bolts onto, as well as the 2-3mm next to that inside the venturi as soon as fuel line is connected. What is going on with that? Thanks, ben
  • 474 Answers
Sounds like you unseated your needle valve. pull the bowl off the carb and ensure that the float is contacting the valve and shutting off the fuel when you push lightly up on it.
Posted on Feb 06, 2010
Toro Model 20070 lawn mower starts and runs, just does not seam to have a lot pf power does anyone have a lack of power issue with their Toro 20070 Pace Lawn mower. Runs fine just no balls
could be dirt in the carby , blocked fuel filter or lack of adjustment in the accelerator cable
I will go for a cable adjustment as they slip under the clamp on the carby bracket when the throttle is pull wide open
May 30, 2016 | Toro Power Lawn Mower
Starts fine and runs but why do rpms go up and down with some loss of power?
Could be the valve in the carby. Had a similar problem with my Victa. Have a look on the internet for briggs and Stratton engine carby service. It was really helpful. Your carby may be different but the info I found was very helpful and explains how the power valve operates and what to do to prevent surges and power loss.
Sep 17, 2015 | Toro Lawnmower 20099 Mower Mowers Lawn
Mower runs when cold but loses power and finally stops appears to be blowing back oil through add spout
crank case pressure on engine will usually splash oil up spout on most stationary engines we just don't usually remove them when running . , I would not look at that as huge problem .I would think your carby main jet needs cleaning , if runs on choke this usually is good sign is blocked.
Apr 21, 2014 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Mower will start but runs rough & stops
Is the carb flooding?is there black smoke coming from exhaust when running, if so it could be the carb over filling with fuel. Is there petrol leaking out of the carb? If not check the fuel pipe is in good condition
Jul 22, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Blowing oil out of the engine
check oil level fuel could have flooded through into the engine oil which will cause it to blow out if so clean out carby and check that needle in the carby is sealing
Jun 11, 2013 | Toro 52" 27hp Z Master Zero Turn Lawn...
Type your problem for a solution...mowing for 10 minintes stoped to ceck blades started mower blue smokeout exhust. stoped mower checked oil will not start checked plug ,filter carbie and control lever
to check blade you tilted the mower and got oil where it should not be.
exhaust will clear out, check all controls to see if the spark is still there, allso a compression test check out a lot of problems. if it is low ,under 60 ,
just check the basic the three things needed to run- compression,spark,and fuel. always check things with the spark plug wire pulled of the spark plug. good luck
Jan 03, 2012 | Garden
Lawn mower running rough
adjust the carby. also u might want to replace the diaphragm in the carby. might work wonders
Mar 31, 2010 | Mtd LAWN MOWER PART # 791-180705 Assembly,...
Lots of smoke and oil comming out the exaust . only 1 and a half year old
Has fuel with oil accidentally been mixed to the fuel for this mower? We have had mix oil accident get added it to this lawn mower and it will smoke a lot with 2 cycle oil.
Unless you are certain no oil is mixed with the fuel I would drain and clean the fuel system.
Replaced the spark plug with the new and replace the air filter In addition ensure you do and oil change every 30 hours using a high grade 30 wt oil to include make sure it is not over full.
Hope this tip helps.
r/
David
Feb 06, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
I have a mountfield classic 35. It struggles to run smoothly until it is almost out of fuel. The plug gets very oily. If the mower is tipped backwards the fuel flow is restricted and the mower runs well....
replace the carby diaphram between the tank and carby that will fix it (diaphram controls the fuel pump and when faulty can make engine rich or lean with revs impossible to control)
Jul 13, 2009 | Garden
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
