Question about Refrigerators
My fridge keeps freezing up and so does all the food in it
  • 4,793 Answers
Replace thermostat sensor .....easy diy ????? replace item as you remove it,simples ssstt
Posted on Feb 06, 2010
meBNme
  • 334 Answers
SOURCE: fridge keeps freezing food
Have you turned the thermostat up?
If yes, then you have a problem with the temp sensor or thermostat.
Make sure the sensor is not touching any warm surface.
each part usually costs less than 40 bucks if you DIY.
Posted on Dec 27, 2008
Sea Breeze
  • 4654 Answers
SOURCE: food in bottom drawer of fridge freezes. what is the problem?
Try adjusting the food compartment temp. There are many possible reasons that will cause this. Look for exact model number located inside food compartment bottom door when opened. For example 91.802574 This will give us the exact diagram to work with to help you solve this. Below is a link with Q&A that you also can use to resolve this problem.
Let me Know and Thanks, Sea Breeze
http://www.applianceaid.com/refrigerator.html#freezing
Posted on Feb 01, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
  • 400 Answers
SOURCE: Liebherr fridge 3150 keeps freezing
The problem is the thermostat, not the drainhole. The thermostat should stop the compressor when a setpoint temperature has been reached, this gives the unit a chance for a small defrost.
Posted on Mar 05, 2009
  • 5 Answers
SOURCE: Freezer not freezing properly, ice on back wall
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
Posted on May 29, 2009
My refrigerator keeps freezing things...,.changed the gaskets around door and still have the freezing probkem
Most fridges have a cooling vent above or on the side of the top shelf. This is where most of the cold air comes from, so keeping food away from here may preventfreezing. ... Some side-by-side refrigerators (particularly older models) feature a vent that funnels cold air from the freezer into the fridge.4 Aug 2015
How to Prevent Your Refrigerator From Accidentally Freezing Food ...
refrigerators.reviewed.com/features/how-to-prevent-accidental-food-freezing-in-fridge...or try this link... refrigerator keeps freezing things Google Search
Oct 23, 2017 | Refrigerators
My Lg fridge Model # LFX25980ST is freezing my food in the lower portion of the fridge
Lower the number on the temp dial or replace the thermostat.
Jan 03, 2017 | LG Refrigerators
My Samsung RL39WBMS fridge on m fridge freezer keeps freezing food. Why is this happening all the time and how can I prevent it?
maybe the fridge is set on a colder setting and if that's not it then stick it on the lower shelves and that might help from not freezing because are fridge is the same way when it is stuck by the coolant fan
Nov 02, 2014 | Refrigerators
My whirlpool fridge is freezing the food in the fridge. What is causing that?
adjust the temperature settings.change from coldest to colder
Jul 15, 2014 | Refrigerators
My beko fridge freezers fridge keeps freezing
Your t'stat is probably bad. Should be easy to fix. At least it is freezing and not ruining your food from being too warm.
Feb 03, 2013 | Refrigerators
Idesit BAAN134 PSUK fridge keeps freezing food . The fridge part of my tower f/f keeps freezing food even though I have turned the dial down to the minimum the temperature regularly drops to below...
If it is an electronic thermostat it could be that the engineer has changed the board but not the sensor which reads the temp. If it is a mechanical thermostat it may be hes fitted the wrong type.It could also be that the system is short of refrigerant and the actual refrigerant charge is not getting all the way to the thermoststs sensor to switch it off, the back wall of the fridge should be frosted at least 3/4 of the way down and not just forming in a small part of the fridge.
Jan 05, 2010 | Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Freezer not freezing food and fridge not staying cold enough
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Food is freezing
usually there is an adjustment at the back for the difference between the fridge and freezer compartment. Often is just a vane that blocks freezer air, too much air would freeze the food. Normally you set the fridge thermostat for a normal food temp, then adjust the air to keep the food warmer than the freezer.
Jan 28, 2008 | Arctic Air R22CW Refrigerator
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
