Question about Refrigerators
Water isn't coming out It stopped working and I changed the filter and it started working and now it just quit again.
  • 572 Answers
Check water supply and the water valve
Posted on Feb 06, 2010
The water and ice dispensers do not operate after changing out the water filter. Tried resetting per the instructions to no avail. Help please!!
I would try another filter. It is not uncommon for new filters to not function.Espcially if you bought generic filter. If you haven’t tossed the old one put it back in and see if it works again. You can always use another filter if that isn’t the cause.
I only buy OEM filters not generics when it comes to water filters.
Sep 28, 2017 | Refrigerators
Water temp gauge works for about 30 seconds and then drops to zero
Most likely have a bad DIM. You may start to see the SRS light start coming on and the speedometer may stop working.
Nov 29, 2015 | 2002 Volvo S60
Water does not flow
Sounds like air in the line.....the filter may be cracked/damaged, or not quite seated...?
since you've tried 2 new ones....I'm gonna bet they are not quite the correct ones for your fridge.
Sep 07, 2012 | GE GSHF5KGXBB (254 cu ft) Side by Side...
I've a 7+yrs super4 spec2. The problem is, after travelling for a short journey, the bike engine dies off as if the petrol is not going into the carburettor or the carb is not feeding fuel into the...
here is 2 things that comes to mind 1 . fuel system has filter problem . if you let your bike set
the filter settles back . that is why it starts again . replace all fuel filter and line if possible .
2. coils have been known to get hot and quit , and cool and work and stop . have coils checked
and replaced .
if this does not help ? I have other solutions........
Oct 19, 2010 | 1999 Honda Cb 400 Super Four
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I changed the filter for the water dispenser and after purging the water for awhile, the dispenser stopped working. What needs to be done to get the water dispenser to work again
Put the old filter back on , if water was fine . You never change filter just because a light comes on telling you to . The change filter light comes on after time or usage of dispensor .( Good way for manufacturers to make extra money ) . Change the filter only when water flow slows from dispensor .
Aug 13, 2009 | Sub-Zero 690 Side by Side Refrigerator
When driving engine just quits starts again after
Could be a defective plug wire or plug or clogged fuel filter. Change these out.
Jul 30, 2009 | 1999 GMC Safari
Front load washer wcvh6260fww
The problem may the pump filter which is hidden behind the lower front panel. To access the filter, unscrew three screws at the bottom of the panel and carefully remove the lower front panel. Make sure to unplug the machine. With the panel removed you will see the pump filter. Get a bucket and some towels ready, because when you open the filter, you may get a gallon plus of water coming out. GE failed to put this in the use and care manual for the 6260. But low an behold, GE put an access door and explicit instructions on cleaning the pump filter in the updated 6400.
You may have burned out your washer pump. That is what happened to me. The machine would not drain or spin properly and so I kept pushing the blinking start/pause button to get it going again. Then it finally did not drain at all. I installed a new pump and with the cleaned filter, the machine worked like new. For some, simply cleaning the filter allows the pump to work properly. As the filter gets clogged the pump has to work harder and harder to pump out the water. When this happens the cycle times get extended . One symptom of a clogged filter is the final minute (spin cycle) takes much longer. Obviously this is a "design flaw" that GE "fixed" in the recent version of the 6260.
Mar 25, 2008 | GE Energy Star WCVH6260F Front Load Washer
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
