To load window xp
If i have a preinstalled window vesta, i want to install window xp, in bios no sata option is available
  • 655 Answers
No, the above are not solutions.
u have to do alot of work if u have to install XP over vista on a SATA disk drive. b.coz XP need driver for SATA drive interface.
You have to provide this driver through a floppy or to add that these drivers in a new setup CD for XP.
after that u can install XP on a SATA drive.
m sorry that i can't xplain here.
for further details pleas mail me
at: iqbal_delphidev@yahoo.com
Posted on Mar 02, 2008
  • 97 Answers
So you want to remove the Vista? But you cant find the hard disk right? Try to change your setting from RAID to IDE in advanced setting.
PM me if it wont work:
Posted on Feb 21, 2008
    Sniper:
  • 56 Answers
Insert xp cd
when appears press any key to boot from cd.....
press ENTER
now follow the instructions...
I want to install Windows XP on Sony Vaio VGN CS15GN B instead of Windows Vista but it is not happening kindly help
---------------> Perform a clean install of Windows XP 1)- Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
2)- When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
3)- At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
4)- Read the Microsoft Software License Terms, and then press F8.
5)- Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
6)- Follow the instructions on the screen to complete the Windows XP Setup.
Note:- Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
May 25, 2011 | Computers & Internet
Hi..i have HP pavilion dv5 laptop with preloaded Windows Vista. i want to istall windows xp instead of vista. i tried installing it using xp bootable disc. but after loading the required installation files...
its very simple....
enter the bios setting...The BIOS settings menu is accessible by pressing the f2 or f10 or the f6 key on some computers.
if the BIOS provides an option to disable the native-SATA configuration in the BIOS, do the following steps to Disable the native-SATA in the BIOS
1. Use the cursor to navigate the Configuration options to locate the Native-SATA setting. 2. If there is a SATA setting, select the Disable option, and then press F10 to save the change and restart the computer.
if your system bios does not contain such option.... then find "Native SATA mode" or "SATA IDE"
then change "AHCI" to "ATA"
Jan 16, 2011 | Computers & Internet
Why the windows xp cannot be loaded for laptops.They are asking for raid drivers.Then how to collect the raid drivers,and how to load the window xp for laptops.I there windows xp available with raid...
Here is what you need to do to install XP on your laptop that came with Vista or Win 7.
If your hard drive is SATA (pretty much standard these days) you will need to search the manufacturer's site for a floppy disk SATA driver install package.* You will need a USB floppy drive for installing XP.
* Copy the SATA drivers (should be denoted as "F6 drivers" or similar) to a blank disk.
* Have the USB drive connected. It should automatically map as A:\.
* Go into BIOS and find a setting for ACPI Compatible and set on.
* Now install XP normally from the CDROM, and when it says "press F6 to install third-party drivers", press F6 and follow the options to get the SATA drivers from the disk.
* Complete setup as normal.
or
You can check the following link for more detailed info.
Thanks !!
Please rate the solution if it helps you.
Nov 23, 2010 | Computers & Internet
I have toshiba satellite L505-S5990 model.i have installed windows xp by changing the settings in Bios that is sata hard disk enabled as compatable mode from AHCI.if i change to AHCI i can't install...
If you would like to make use of the SATA controller's AHCI features, you should enable this BIOS feature. But please note that enabling this feature requires you to load the SATA controller driver during the Windows XP installation routine.
If you do not intend to use the AHCI features, it's recommended that you disable this BIOS feature. This allows you to use the native Windows XP driver. You won't need to load the SATA controller driver during the Windows XP installation routine.
Read more: http://www.techmetica.com/howto/sata-ahci-mode-bios-setting.-what-does-it-do/#ixzz0y5ObAtN8
Aug 30, 2010 | Toshiba Computers & Internet
To install xp over preinstall vista in Toshiba satellit A200, some soultaion is aviable 1. to disable sata but how to disable sata in toshiba no option is aviable in in toshiba Bios. plz help me
There are case where BIOS stting doesn't contain any point of configuration for SATA.,
Step 1 : Download SATA driver
Here is the link :
http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/12474/eng/iata621_enu.exe&agr=N&ProductID=2101&DwnldId=12474&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
Step 2 : Download a software called "nlite"
Here is the link :
http://home.midmaine.com/~nlite/nlite/nLite-1.4.9.1.installer.exe
Now you need to include SATA driver with Windows XP cd so that windows XP recognize your HARD DRIVE.it can't be include diectly so
Installed the nlite software and follow the instruction by going to the link below.
http://www.nliteos.com/guide/part1.html
Note : Microsoft dotnet framework 2.0 or later is needed to install nlite in Windows XP,but if you are making a bootable Windows XP cd with sata driver pre-install then,you don't need it.
This will 100% recognize your SATA HARD DRIVE.
Hope it will solve your problem.
Jan 02, 2010 | Toshiba Satellite A200-19501F Notebook
Do i need (s)ata drivers for toshiba satellite u400? or i can install xp without a problem?
Start your laptop and goto your BIOS and check if SATA setting is available.if available then configured it in IDE Mode or disable it, (if disable option is available).
Now, you should be able to installed windows XP without any problem;
Usually these days,Laptop BIOS comes with little or standard setting;if that is the case;then you will need SATA driver during installation in other to recognise your SATA hard drive.
Dec 14, 2009 | Toshiba Satellite Pro U400-S1001V Notebook...
Why not win xp load in compaq presario cq40
The notebook is preinstalled with a SATA hard drive which needs seperate drivers to be installed inorder to get the hard drive detected. The drivers for the SATA can be installed only by using a floppy drive. As the notebook does not have a floppy drive installed, we can either try disabling the SATA native support in BIOS or install the drivers with the help of a USB floppy drive.
Here is the link for SATA driver:
http://downloadmirror.intel.com/16759/eng/f6flpy32_85.zip
Check the following document to install SATA dirver without using the floppy drive:
http://www.scribd.com/doc/4864999/sata
Jan 22, 2009 | Microsoft Windows Vista Home Premium with...
How to install Widnows xp on HP Pavilion dv2000
Please help me, I bought a HP Pavillion dv2000 Laptop which came with a built-in Windows Vista. Thats cool, but the problem arises when I try to install windows XP. After inserting the Windows XP SP2 CD and after primary driver loading it is unable to detect my harddisk
May 07, 2008 | Computers & Internet
Hp dv6000
There is option in BIOS called something about automated SATA recognition or similar - disable it. It is under System configuration. And if you are putting new drive in then run full test from BIOS (Hard drive selftest - takes about 79min.)
I tried to reinstall Windows Media center on my HP dv6000 because my previous hdd crashed - When I put in installation cd - it said that it can't find hdd. I spent week to figuring that out. The thing is - as far as you haven't disabled that SATA thing in BIOS - PC doesn't recognize hdd. But only with Windows media center edition. With all other windows xp - there is no such problems. Strange.
Feb 11, 2008 | Computers & Internet
Computers & Internet Logo
247 people viewed this question
Alun Cox
David Payne
David Payne
