Question about Acer AL1916W 19" LCD Monitor
Low resolution of monitor - Acer AL1916W 19" LCD Monitor
    Scholar:
  • 109 Answers
Right click on your desktop and select Properties (win XP or older), or Personalize (vista and windows 7), and select a higher screen resolution on the settings tab (XP), or by clicking "display settings" (windows vista or 7). If your slider is all the way to the right, make sure you have the latest drivers for your video card, or if the PC is older, you may need a new one that supports the resolution of the monitor.
Posted on Feb 06, 2010
How fix computer monitor stuck in low resolution
If your resolution is too low, you can change that by clicking on the Start button and then clicking on Control Panel. From the Control Panel window, click on Adjust screen resolution from beneath the Appearance and Personalization section. From the Resolution drop-down, select the highest resolution by moving the slider to the top. Your resolution should be just fine now.
To change your font size, go back to Control Panel, search for "window color" in the search box, and then click on Change window colors and metrics". You can adjust font sizes from here.
Jun 08, 2014 | Microsoft Windows 7 Ultimate for PC
My monitor is fuzzy in internet
Fuzzy on the internet and everything else or fuzzy just on the internet? check for monitor resolution and see if you have the screen resolution set right. If you have the resolution set too low, the screen can appear more fuzzy if the aspect ratio is not set right.
Jun 04, 2014 | Samsung SyncMaster 2333SW 23" LCD Monitor
What dose it mean when screen says out of frequency
This error indicates that your video card resolution is set igher than the monitor can display. Try booting into safemode and changing the resolution.
Here is a link to the Gateway site spec page for that monitor.
http://support.gateway.com/s/MONITOR/7003943/700394318.shtml
The maximum resolution it will display is 1024 X 768 which is very low for current video cards, your card may not go that low. Check it if it does not go then you will need to get a new monitor that supports the resolution that your computer can put out.
Feb 19, 2012 | Gateway FPD 1520 15" Flat Panel LCD...
Windows 7 screen goes to large resolution and needs reset on startup.
Turn on the PC. Press F8 at booting into windows 7. It will display  many options
Select the Enable low resolution video(640x480) then login to system.
then change the resolution as required
Right click on a empty space on the desktop and click on Screen Resolution.
Enable low resolution video (640 × 480)
Jun 08, 2011 | AOC 718Swag-1 LCD Monitor
My system is workin properly but the screen resolution is very dim it seems to be very light ..... even we can't read any thing on that. i checked my monitor with another cpu its working properly can...
IT IS NOT HARDWARE PROBLEM
Change screen resolution
Screen resolution refers to the clarity of the text and images on your screen. At higher resolutions, items appear sharper. They also appear smaller, so more items fit on the screen. At lower resolutions, fewer items fit on the screen, but they are larger and easier to see. At very low resolutions, however, images might have jagged edges.
For example, 640 × 480 is a lower screen resolution, and 1600 × 1200 is a higher one. CRT monitors generally display a resolution of 800 × 600 or 1024 × 768. LCD monitors can better support the higher resolutions. Whether you can increase your screen resolution depends on the size and capability of your monitor and the type of video card you have.
21b7b862-a70d-43aa-a281-e00c38a8078d.pngText and images are sharper and smaller at high screen resolutions
2aca9658-0ee7-4b8d-a582-cac335550f26.pngText is larger and easier to read at low screen resolutions, but images are blocky and fewer items fit on the screen
  1. Open Display Settings by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
  2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Nov 13, 2010 | Intel D945GCCR Motherboard
I add graphics card my computer then connecet to the monitor not coming display may be not supporting resalution how can i fix the probelam plese help me
In the past I had to use or brow a monitor that can do the resolution. Login then set the resolution to a low number like 800x600 which monitor will run then put my monitor o and work up the resolution or know the resolution of the monitor click on it and go. Yo and 15 sec window to say OK or it will come back to the lower resolution.
Jun 27, 2010 | Samsung T220HD LCD Monitor
My compaq computersceen says input not supported
i think your cpu settings you changed to high resolution. That resolution is not supporting by your monitor. If you have another monitor connect to that monitor to your cpu and change lo some low resolution. If monitor is not there try to boot in vga mode for that mode you need to press "F8" button on booting. It show you some modes select vga mode and boot and change the resolution and restart your system
Jul 05, 2010 | Computers & Internet
Screeen Resolution too low
600x800 for printer.
go to control panel display properties settings tab
click on advanced. click on monitor tab and uncheck hide monitors
uncheck hide modes
click ok. change resolution to 800x600.
Nov 25, 2009 | HP Mini 1000 Netbook
Hp f2105 monitor goes immediately to sleep mode
Sounds like your monitor is not processing the resolution signal from the graphics card. Reboot the computer in "safe mode with networking", from there you can play around with the resolution, start low resolution and work your way up to test the monitor.
Sep 07, 2009 | HP f2105 21" LCD Monitor
Out of frequency range set low resolution or refer monitor manual
TO RESET IT START YOUR COMPUTER IN SAFE MODE AND GO TO DISPLY SEETTINGS SET YOUR MONITOR AT VERY LOW 32BIT 800 BY 600 PIXELS IT WILL SOLVE THE PROBLEM THAN RESTART THE COMPUTER
Feb 06, 2009 | Compaq CV 7500 17" CRT Monitor
Acer AL1916W 19" LCD Monitor Logo
152 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
