Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
Wd 250 passport
I sync'd my drive with trial software, now trial has xpired i cant acess info on drive. do i have to buy software now to retrieve my info ??
  • 1,006 Answers
Yess you have too..
Posted on Feb 21, 2008
Hi , I just copied my hard drives to my new Passport Essentials SE using the WD Smartware software, I do not like I have to manually switch between my two internal hard drives to back up so I would like to...
As far as I remember WD just copies the software into the PassPort drives and you don't have to install anything you can just run the software from the drive. If that is still the case then first take a backup of that software (basically copy that software folder to some place in your internal drives) then format the drive (make sure you select NTFS as the file system for the drive when formatting).
Formatting will erase all the files in the drive so make sure you have backup of you personal files also.
Formatting also resets the drive back to factory setting (if you want the WD software back then just copy it from the backup to the PassPort drive).
Sep 06, 2011 | Western Digital WD Passport 250GB Portable...
Tip
Western Digitial Passport Sync Software
WARNING: Do not think that theyourWD Passport, using the WD Sync software, is a backup drive; it is NOT !
As per the documentation with this device:
"synchronization software is intended to synchronize the data from a computer to the drive (WD Passport) and SHOULD NOT be used as backup software. To use this software properly, we advise that you do not wipe or
erase the data from the internal hard drive (computer) and resynchronize, as this will cause the data that WD Sync stored to the Passport to be deleted."
This is why you are hearing so many people saying that they are deleting the WD Sync software, reformatting, and using the WC Passport as a true backup drive where you can actually see the files that you are backing up, rather
than a bunch of unrecognizable sync files that likely don't have all the files that you thought you "backed up".
on Jan 18, 2009 | Western Digital Passport WDXML800UE...
Why wont my Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive work?
Several possibilities:
* bad USB port in your computer (try another USB port)
* messed-up copy of Windows (try connecting to a different computer)
* damaged USB cable between computer and the Passport (replace it)
* bad disk-drive inside the enclosure (replace it)
* bad USB-to-disk-drive adapter (buy a new "empty" enclosure)
Check the warranty on it, to see if W.D. will replace it, at minimal cost to you. If the warranty has expired, W.D. has a "Customer Loyalty" program -- buy a new Passport through their web-site, and you qualify for a discount on your purchase.
Oct 30, 2010 | Western Digital WD Passport 250GB Portable...
My WD wants to install syn software. None of the files look like the files originally pulled for backup. My hard drive crashed and I need to restore to a new Hard drive - what do I do?
When you connect the drive, ignore the sync option. Do note in your "my computer" WD will have two drive letters (one is a read only drive) that contains the sync software. The other drive letter will be where you data is stored. If you used the sync software to backup your files; you need to install to get your data back. If you simply copied your data from one drive to another; the files should be there in their original form.
Oct 18, 2010 | Western Digital WD Passport 250GB Portable...
I reformatted the wd my passport hd. now my computer won't recognize it. I need the installation softare
Here is the WD page, pick your Passport type, on the next page download the software you need:
Select the software to download: http://support.wdc.com/product/download.asp?level1=2&lang=en
If I could be of further assistance, let me know. If it answers your post, please be kind to rate it.
Joe
Mar 15, 2009 | Western Digital WD Passport 250GB Portable...
Getting an old Dell Dimension to recognize a WD Passport
In the end, I assigned a different drive letter to the device and it worked.
There's a lot of info out there on how to assign a letter. Here's one link:
http://lifehacker.com/software/windows/change-windows-drive-letters-167525.php
Feb 17, 2009 | Western Digital WD Passport 250GB Portable...
I don't know how to check the files on my WD passport. I'm looking just for pictures and itunes. Can you tell me how this is done?
you plug the drive into a usb port.... if it doesn't automatically pop up to allow you to access the drive... go to my computer (or computer on vista) and go in there... it should appear as another drive. double click and you are in the drive.
Robert
Jan 16, 2009 | Western Digital Passport WDXML800UE...
My passport "removes" my files!
Recover western digital passport "sync-data"
You need to have the WD Sync program on your computer; you can get it from your WD Passport, or, over the Internet. Once you have the software on your computer, you can synchronize. WARNING: Do not think that theyourWD Passport, using the WD Sync software, is a
Dec 24, 2008 | Western Digital Passport WDXML800UE...
Can I use my passport essential 2.0 to backup my work computer as well as my home computer?
You can use your WD Passport to sychronize data on multiple computers, you just need to set up the other computer name (e.g. "Work computer")using the software.
Aug 03, 2008 | Western Digital Passport WDXML800UE...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
