Question about Cnet CNIG914 Router (NWCNIG914)
My Cnet CNIG-914 router doesn't give internet connection
  • 3 more comments
  • tbancute Feb 06, 2010
    only power and the LINK/ACT and the WAN are the ones that lights up
    i checked the LED's, only the power, LINK/ACT and the WAN's LED that lights up...
    nope...
    here is the situation...
    i tried to upgrade the firmware of my router, but maybe it's failure because I didn't see any successful notifications. And after wards, i restarted my pc, router (turned off and on for about 10-15 mins.), and then i still got the same result. ( only the power,LINK/ACT and the WAN were just the ones that lights up)
    nope...
  • april jerome espinosa
    april jerome espinosa May 11, 2010
    check th LED's..if power i on.. WLan is on... connection's of the pc are on... if they are all on..maybe your internet provider has the problem...
    Scholar:
  • 109 Answers
There are several possible problems. Do you receive an IP address from the router? To find out, open the command prompt (Start > Run, type in command , and at the prompt enter (without quotes) "ipconfig".
If you have an IP address, try unplugging the router and your modem for 2 minutes. Power on the modem first, and wait for alll lights to stop their startup flashing and testing pattern (1-2 minutes is usually good), then plug the router in.
If you do not recieve an IP address (if your IP address is 169.x.x.x that is most likely the case) then the router is not giving you one. reset it to factory defaults, and follow the instructions to set it up again.
Try those and let us know how it works out for you.
Posted on Feb 06, 2010
  • YourQInc Feb 06, 2010
    Are you connecting through a wired or wireless connection?
    Ahh, OK, a firmware update gone bad. Try resetting the router back to default (press the little teeny button inside the hole in the back with a paperclip for 30 seconds). See if that helps.
EdiMax Br-6482nS doesnt give internet
A router is only used to connect devices together in a LAN (local area network). In order to get out to the internet you also will need a modem (cable or dsl depending on your service) You will also need to pay for service through an ISP (Internet Service Provider)
May 02, 2013 | Edimax Computers & Internet
I cant connect to internet
There are lots of possibilities here since you didn't give us much info to go on. Some helpful information would be:
1. DSL, Cable Modem, Sat Modem, other ISP
2. Is the problem with the router, or the network connection
3. What are the model numbers on your router, and if that doesn't connect directly to the wall, what does it connect to.
4. are you connecting from a desktop or laptop
5. are you connected to the router over wireless, or Ethernet cable
6. are there any other devices in your house/apartment that can connect to the internet (is 1 device down, or are all the devices down)
With the little information we have, I would suggest unplugging your router for about 30 seconds, then plug it back in. It will take anywhere from 30 seconds to several minutes to reset and reconnect.
If this doesn't fix the issue, give some more details and I will give the next step.
Thanks,
John Vickers
Aug 12, 2011 | Computers & Internet
My girlfiend is the primary account holder on her internet account she is connected to the internet with her modem and lkinskys router i have my computer and cnet 914 broadband router how do i connect...
If you are trying to connect to her internet connection, you use her router.
You cant connect 2 routers to one modem, unless you set one up as a repeater.
Just ask her for the wifi password, and connect through her router
Oct 15, 2010 | Cnet CNIG914B 4-Port 10/100Mbps Router
What is it used for?
You can use this wireless router to connect different wireless devices together. Each device with a wireless network card (computer, phone, gaming system, printer, etc.) can connect to the router without a cable. This will form a network where information can be shared.
The main purpose people use this for is to connect their network to the internet. As long as the router is connected to your internet, every other wireless device can also connect.
Thanks,
Pat
May 24, 2010 | Cnet CWR-854 Router
How to setupmy router Cnet CNIG-914 for PLDT myDSL ISP
Plug your DSL cable in your router's WAN or DSL port and then you power ON your router.
Apr 04, 2010 | Cnet CNIG914 Router (NWCNIG914)
How to setup an adsl modem and a router
forget the router as it appears that it is messing with the connection
May 13, 2017 | Cnet CNIG914B 4-Port 10/100Mbps Router
CWR-854 router
Type in the address of your router - you say that is set to192.168.1.254 and you will see the config page( after logging in ) for your router. This is more usually 192.168.1.1 though .
Jan 18, 2008 | Cnet CWR-854 Router
Why its working with some ISP's and does not work with other ISP
ISP's have different requirements for connecting a router to their hardware. One required me to enter a static IP address, another requires acceptance of a dymanic IP address and a third uses dynamic IP addresses and requires a PPPoE logon from the router and a configuration change to their modem to switch it to a bridge, and a fourth I have read about require a reboot of their modem device to recognise changes in the MAC address (assigned to the network adapter) of the attached device (router). I am sure these are not all the variations possible, Requirements for router connections specifically the WAN side of the router are specific to your ISP. Often in their help or support areas they either have FAQ's or help pages to explain the requirements or an online technician available through chat who can tell you what is required. Often however it is up to you to be able to perform then necessary configuration tasks (especially on you hardware) to make this happen. I may be able to provide assistance of you identify you internet provider including local provider companies and geographic location (city / State) in some cases to determine their policies and requirements for attaching routers to their equipment.
Dec 08, 2007 | Cnet CNIG914 Router (NWCNIG914)
Cnet broadband cnig-914
Can you log into the Hub at the IP http://192.168.1.1/ when it is connected to the computer and the internet connection? Perhaps it is just a configuration issue. http://www.cnetusa.com/support/manuals/CNIG-914D.pdf is the link to the manual to setup your router. Without further information about your network and its configuration I can't give more specific information. If you will please post any specifics about your configuration I can hopefully assist further. Please tell me how many computers there are, how many are directly connected to the router and how many are wirelessly trying to connect. Another suggestion is check your boot up order. Often times you have to unplug everything, then plug in the internet router, give it time to full boot up and have all lights on, then plug in the additional router (in this case I am assuming that it would be the CNet Cnig914), again allowing all the lights to come on, then plug in or turn on any pc that is connected directly to the router, followed by any computer that is wireless. This allows each system to be assigned the IP address and recognize the previous equipment. Once it gets an IP and everything is working you shouldn't have to repeat this process.
Nov 09, 2006 | D-Link DI-704P Router
Computers & Internet Logo
159 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
ddalecki
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
