Question about Kenmore Elite 45986 Front Load Washer
The letters hf are flashing not alowing the machine to wash the clothes
  • 572 Answers
Check water preassure. or clean the valve screens
Posted on Feb 06, 2010
Kenmore he4t code hf
hf error stands for hot water not being detected, make sure both hot and cold water are open and not reversed. if unit overfilled and flooded garage, the is if with you pressure switch or pressure hose. remove to lid of machine and you will find pressure switch and hose to the right side, inspect hose for any pin holes, if ok, order pressure switch
Apr 03, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Sometimes on the wash cycle the machine stops and the lettering ue appears on screen and flashes
Two possible problems too much weight (pieces of clothing) and second you need to redistribute the load to make it even, and re-engage the wash cycle again. Good Luck
Jan 06, 2011 | Washing Machines
Washer stops and on screen has a letter H then a leter F
HF is lack of water in the washer. Check all hoses and filters and clean them out and it should work.
Mar 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Direct Drive Kenmore Washing Machine will not spin a full load of clothes during rinse or spin but will spin a small load. Agitates fine. Replaced drive coupler, clutch and basket drive...no luck. What...
its possible the ears on the top of the drive tube have worn alowing the basket drive block to slip and not turn the clothes basket with authority, or the basket drive block has just worn from overloading and needs replacing.. is easy to verify by looking..
best of luck,
ttfn
Oct 25, 2009 | Whirlpool LSR7333 Top Load Washer
Small cloths are going between washing drum and
you nead to be aware that when you put clothes in your washer you have to understand that you only put cloth's in that you do not have push down.if yopu over load your washer,the water will come in and the cloth's will rise faster than the water come's in,that will alow cloth's to get into the outer tube and block your water pump.
Oct 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Door was leaking and now it shows error code H F
hf means no water entering unit,,,make sure that there not water in unit already..make sure your pump is not clogged,,if need be post question how to clean pump or just contact me,,also make sure theres no kinked inlet hose,,and or drain hoses..check and see if your inlet screens are clogged..onthejob
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
HF signal code
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Height of exit hose should be approx 3 feet from ground level.
Rate me pl.....if helped.
Oct 21, 2007 | Kenmore 44832 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
131 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
