Question about Refrigerators
The freezer stopped working and so did thr refrigerator, but you can here the fan running.
  • 572 Answers
Check fpr the compressor runs. if not check the stat relay on it
Posted on Feb 06, 2010
Frost free power trip
Defrost heater element short circuiting is my guess. Call Bosch service if under warranty.
Nov 21, 2013 | Bosch Refrigerators
The freezer fan runs continuosly
It may be because there is some air leak into the freezer. Check if it is closed air tight. Also try defrosting the freezer. Check the fan after that. It may stop working continuously.
Apr 21, 2010 | Kenmore 57029 Side by Side Refrigerator
Freezer not freezing nor ice maker
Is the refrigerator still working? Is there any cold air in the freezer? If your compressor stopped working it would cause the refrigerator to be warm also. I had a problem with my amana refrigerator where the freezer wasn't getting cold enough and it was due to a condenser fan running intermittently. i replaced the fan and was back in business. i would check to make sure both your fan and your compressor are operating...
Mar 03, 2010 | Amana ABB1927DE Bottom Freezer...
Side by side freezer refrigerator. will stop start
Listen for a fan motor in the freezer running. if freezer fan is not running either the fan or a small thermostat that controls it maybe bad. model # might help.
Jan 05, 2010 | Amana Refrigerators
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer fan running non-stop+freezer icing up
very likely that either the defrost timer is not working or the defrost heater is not working.
May 04, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
GE model GTST2BPLWW
they all have fans the freezer does all the cooling for the whole unit there is nothing in the bottom unit that cools the freezer fan blowes air from the freezer down to the bottom and draws air to the top if you dont hear the freezer fan running and there would be no doubt in your mind if it was then pull the fan cover and see why and let my know hold my rating till we are done please
Feb 11, 2008 | GE (GTS16BCS) Top Freezer Refrigerator
Whirlpool top freezer problem
Check for frost build-up behind back wall in freezer. If there is a heavy frost build-up, it's not defrosting. This will restrict airflow to refigerator section and can stop fan. If fan is stuck again and it's not because of frost, replace evaporator fan motor.
Nov 12, 2007 | Whirlpool ET1FHTXM Top Freezer...
Evaporator fan
These can be easily fixed. Take the back cover out of the freezer and tap on the fan shaft (you wont hurt it) and squirt a dab or two of oil on the shaft next to the motor. If it loosens up let it run for a few hours and reoil. If its frozen up totally and you cant turn it at all then the motor needs to be replaced. Let me know :-)
Sep 15, 2007 | Magic Chef CTB1722 Top Freezer...
Refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
