Question about HP Computers & Internet
I have a hp monitor that can change from horizontal to vertical but when i turn it it doesnt change screen postion. how do i fix this
    Scholar:
  • 109 Answers
If you go to the HP support website (hp.com/support) you can download the application for your monitor that automatically switches the resolution and orientation upon swiveling the monitor form horizontal to vertical or vice versa.
Posted on Feb 06, 2010
Thin black horizontal lines across bottom of screen
Hi there.
I suggest you see my tip on how to fix the lines on your monitor. The fix for horizontal lines is the same for vertical lines. You can read my tip here: http://www.fixya.com/support/r9352105-fix_colored_vertical_lines_lcd_display
Slasher_X
Jul 20, 2011 | HP w17e Monitor
We have a Hewlett Packard F1703 monitor...... Our cat sat on the keyboard and the monitor screen went from a horizontal view to a vertical one. We have to turn the monitor on it's side to view it. We have...
Press CTRL + ALT + Down Arrow Key It will Work if Not then Righ Click on Desktop Screen -> Graphic Properties -> Hot Keys ->Uncheck or Check the option it would be done
May 30, 2010 | HP Pavilion F1703 17" LCD Monitor
LG 700B SHAPE SIZE AND POSITION UPSET PLEASE HELP TO RESTORE
Push the button on the Monitor to activate the OSD (On Screen Display). With the OSD, one can "stretch" the picture (horizontally/vertically) and "move" the picture (horizontally/vertically) in order to "fill" the viewable area with your compueter's output.
May 09, 2010 | LG Flatron F700B 17" CRT Monitor
HP Pavilion ZD8000 vertical lines issue
In answer to your question. It may be a screen problem. as the screen has a Matrix of vertical and horizontal line configuration.
I,d suggest trying the laptop/computer on an external monitor or screen. if it works fine on an external. then it could be assumed that the TFT Panel or invertor has a fault.
if the picture/display still has vertical lines on an external monitor, then the fault may lie, with the Mainboard.
Process of elimination, before spending any Money :)
Mike @ compurepair.
Jun 09, 2008 | HP Pavilion zd8000 Notebook
Everything has gone vertical
What type of computer? which model? and which screen? is it a laptop or a tablet.
Check your screen settings if its a seperate screen there may be a button on the bezel for changing the layout.
Also the orientation can be changed in most video drivers. set the screen on its side so you can see and right click on your desktop and manuver to "properties" goto the last tab then click advanced. search around in there for orientation, sorry but exact step by step varies from there depending on which driver you are using.
if you try something in that menu that doesnt work, just cancel out or hit escape.
May 02, 2008 | Dell E173FP 17" LCD Monitor
Horizontal/Vertical Postion of Image on LCD Monitor
the controls for focus adjustment are on the flyback transformer, (that big black thing on the left hand side (usually) of the monitor with the thick red wire that goes to the CRT.) the flyback may have 1,2,3 or even 4 knobs on it. 3 of these would be labled SCREEN (bottom knob of flyback. handles brightness)
FOCUS 1 + FOCUS 2 (focus adjustments. these are what you need to play with) and the 4th knob (some old mitsubishi workstation monitors had these) i do not know, it wasnt labled and HV adjustment was on the deflection board
Apr 25, 2008 | Gateway FPD2275W LCD Monitor
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
On the monitor, only one straight horizontal line display on screen. How to fix it?
Sounds like it's not scanning vertically, probably not worth the money to have a monitor fixed. Time to get an LCD. :-)
Jan 11, 2008 | HP D2835 17 in. CRT Monitor
Monitor displays vertically
If you mean that your screen display became narrower, then there are usually buttons on the screen to fix this, among other adjustments of the screen. the setting you're looking for has a two way arrow going horizontally through the middle of an icon representing the screen. In case i'm misunderstanding your problem, or this does not help, you can also try to let the screen rest for a while(at least 30 minutes), and turn it back on, to allow it to degauss. Good luck
Mar 13, 2006 | HP A4033A 20 in. CRT Monitor
Computers & Internet Logo
63 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
