On the monitor the picture is inilailly OK, however after a number of minutes a coloured bar (approx 75 mm wide) will appear on the right hand side of the screen and blank every thing out. although this happens and the cursor appears to diappear behing the blanked out area you can still click on icon that you know are under there and they will come up. also if you hit pint screen and dump onto a word doc then it will come up with the fully screen picture, minus the bar. Has anyone else had a similar problem.
    Scholar:
  • 109 Answers
The problem is with the monitor itself. It is time for a replacement.
Posted on Feb 06, 2010
I need a new SHENG BANG HD-1688 AA VOLT BATTERY MOVEMENT
Check on Amazon or Madeinchina .com, Tradetang may be a good place too
Nov 11, 2014 | Watches
Tip
How to set your Desktop Screen Resolution?
Greetings, Welcome to Fixya!
So you need to adjust your Desktop Screen Resolution ey!!! It's a good thing you visited as today we are going to discuss just that.
We will be using our monitor to it's full potential, which will ensure we see the best picture our monitor can provide.
Follow the steps below:
1.)Right click on your desktop screen.
2.)A rectangular menu box appears.
3.)Select Properties, found right at the bottom of the menu box.
4.)Select the Settings Tab, found on the top right hand side of the window.
5.)On the bottom left hand side you will notice a slider bar under the heading Screen Resolution.
6.)Move this slider to the left to decrease the Screen resolution, less detailed, move the slider to the right to increase the Screen Resolution, more detailed.
7.)Ensure that the colour quality is set to highest, to give a more detailed and clearer picture!
Below: The window, see the slider bar on the bottom left and the colour quality on the right!
That should do the trick!
Now you will enjoy all the detailed, crisp, goodness that your monitor has to offer.
Thanking you
Till next time!
damnor01
on Dec 14, 2010 | Computers & Internet
Pink color appearence when swith on tv for 1 minutes & wringles form on the screen
Hello
Pink colour denotes the absence of green colour dispay in your picture tube. I hereby gies an approximate voltages at the three cathodes of your picture tube socket solderings, and you just measure the voltages with reference to this. The voltages are approximate, and can chage up to 2% up or down.
Green Cathode = Pin number 9 [161VDC approx]; Blue Cathode = Pin number 8 [162VDC apprpx]; and Red cathode = Pin number 10 [157VDC approx]
If any of these voltage differes, the clolur related to that cahode will also rise or low, thath is if the cathode voltage goes very low, that clour will be prdominent, and if it goes high, that colour will not be there.
In your TVs case, the green cathode voltage now will be high. t may be due to a soldering loose to either to the picture tube base socket or at the terminals of the related transistor or Ic. It is best to resolder the suspected loose soldering points by applying a little more solder, as we in service field also do. It is very difficult to locate the exact loose soldering point and so I advice you to do so. If needs, replace the colour output transistors, of other devices if used. Just look at the voateg at pin number 9 at the picture tube base card. Resolder all the picture tube base socket pins. If you wants any more calrification, contact me through Fixya. Ok.
Nov 25, 2010 | Sony KV-T29CF1 TV
Faded section of screen
Is it an LCD or plasma monitor? If it's an LCD, it's possible that one of the fluorescent backlight tubes is bad. In some early ones, this is bonded to the LCD panel so it's not replaceable. Maybe it's under warranty?
Jul 18, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Black Bars each side of my new monitor wide screen
Right Click on an open spot on your desktop.
If your Operating System is Windows XP, choose Properties from the menu box that pops up when you right click.
A new window will open up. Click the Settings tab at the top right.
On this menu you should see a slider bar near the bottom left under "Screen Resolution". Left Click and hold the mouse button on the grey button and move it on the slider bar over to the right one spot. Then click the Apply button on the bottom right of the box. The screen may flicker for a second and your desktop will change size. If the screen covers the whole monitor and the black bars are gone, that may be the correct resolution. Click OK on the box that has a timer and is asking if you want to keep the screen that size. If the screen does not look correct, click No and you may need to slide the button one more spot over and try the next resolution and Apply until it looks correct.
Under the slider bar as you move it over a line at a time will be 2 numbers like this 1024 X 800, and when you move the bar over the numbers will change. I believe the optimal resolution setting numbers for the 20" monitor you have should be 1680 X 1050 for the widescreen. You may want to try that setting. If it looks too small, try sliding the bar to the left and try each resolution setting.
Here's a screetshot of what the Box with the slider bar looks like: http://technophobik.co.uk/vxp_control_panel/f007_settings.asp
If you have Windows Vista, (it is similiar to XP):
Click the Start Button and click Control Panel in the Start Menu
Click Appearance and Personalization in the new window that opens up.
Click Personalization, then click Display Settings at the bottom
A new box will pop up with the grey button on a slider bar near the bottom left under "Resolution" Slide the button to the right to the next line one spot over on the slider bar and then click the Apply button. The screen may flicker and change the size of your desktop. Click OK if the screen looks correct or click No if it doesn't look correct and try sliding the button over one more line.
Jan 21, 2009 | HP W2007 LCD Monitor
1inch black line down right hand of screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 15, 2008 | Computers & Internet
Screen split into 2 colours - vertical split
I think it is degaussing problem if any thing is lying which has magnet please remove it. &then put of monitor for 15 minutes & then put on again.do not move when it is on. please let me if it gets ok good luck
Sep 09, 2007 | Philips 170B4MG 17" LCD Monitor
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
