Question about kawasaki Full Suspension Mountain Bike Men
How do you remove the rocker arm on an 87 kx 250 dirt bike
A KX250 doesn't have rocker arms it's a 2 stroke not a 4 stroke.
Posted on Feb 15, 2010
Does anybody know where I can get a head cylinder for a 2007 kymco venox 250cc
Try eBay or a motorcycle part finder site
And on the problem of it reoccurring difficult to say as need to know what damage was caused to piston and valves
Was it just one rocker arm that broke or is the other damaged did the timing jump and piston hit open valves driving them up and breaking arm and damaging cam shaft lobes
You really need to find out why and how it happened
As it may require a complete timing system replacement on that cylinder cam shafts , rocker arms , valves ,drive sprockets top and bottom , drive chain and a piston
Sep 01, 2015 | 2007 Kymco Venox 250
Why dose my rear shock on my 250 dirt bike make a cracking noise
try each suspension bolt in turn just so they are loose and move suspension up and down , as i think that one of the bushes could be dry of grease! when was the last time the rear suspension system and the swing arm pivot spindle was removed and greased up ?? some pivot points mite have a grease nipple , but i suggest if this is the problem to remove and clean bolts and the holes then grease up so to last ! depends how much you use the bike in wet or sandy conditions as when to repeat this also !!
Feb 18, 2014 | 1988 Honda XR 250 R
How do i change clutch release arm
I believe the arm is on top of the case on the left hand side attached to a shaft that goes into the case. It also may have a bolt in the side of the case below the arm that has a machined shoulder on it to retain the shaft from pulling out. If it does, remove it.If this is the way it's set up, it actuates the clutch thru a rod that goes all the way across the motor inside the hollow shaft that the clutch is mounted on. I don't have specific experience to the 250 KX, but I've been in the little ones and that's the way they're set up. So here's what you do-
Drain the gear oil and remove the round clutch cover on the right side of the bike. Remove the 5 or 6 washered bolts and the springs from the clutch pressure plate. Remove the pressure plate and you'll see the clutch lifter-it's a short rod with a flat bearing on it located in the middle of the clutch shaft. Remove it and using a small magnet tool go inside the hollow shaft and retrieve the actuating rod. There may be a ball bearing with it as well, although I don't think there is in that bike. Anyway, don't lose it if it has one and pay attention to which end of the shaft goes to the clutch arm. You can now replace the arm. When your putting it back together, rotate the arm with your fingers and make sure the lifter is moving up and down before you put the pressure plate and springs back in. Good luck!
Jun 13, 2011 | 2003 kawasaki KX 250
How do i change kickstarter spring on 2000 kx 250 motorcycle
Just remove the right side cover to expose the kick start mechanism. Remove the bolt on the end of the shaft, tow washers and guide then the spring. It has been awhile since I worked on the KX 250, but as I recall, the clutch does not need to be removed in the process of replacing the spring. I could be wrong on that. Below is the kick mechanism on your bike. Please rate my answer. Thanks. tombones49_146.gif
May 29, 2011 | 2003 kawasaki KX 250
How do i no wo model my bike is
Well if it looks like that picture, it's a dirt bike, not legal for street use. If it has head lights and blinkers, it is a dual sport. The engine size is stamped into the head. Like .125 liter or .250 liter. I think the dual sport is a KZ and the dirt bike is KX. That is Kawasaki.
Feb 20, 2010 | 2003 kawasaki KX 125
49cc dirt bike 4 strokes needs a rocker arms both...where i can get it...the easier way to install it
sadly if this bike is a chinese import you may hve trouble finding the part you need best bet is to go to a main dealer
Oct 16, 2009 | 2007 Bajaj Bajaj Avenger
87 cbx250 not firing
you probally need to retime it find top dead center on copression stroke and aline your cam then put your chain on that shoul do it did you take the cam chain off or loosen your tensener? if so you need to re time it
Jun 20, 2009 | 1987 Honda CBX 250
Why is my kick starter ceasing? I just changed the oil in my 2004 kxf 250, and went to ride it and it would just die and the kick starter ceased. Please help..
I have same bike and know some about it. and i race a lot. your bike has a crank or rod whatever you want to call it but it could be cracked, broke, or even could have dirt on it.
Apr 23, 2009 | 2004 kawasaki KX 250 F
Dont know the year or size of my dirt bike
usually on the front fork area where the forks pivot there should be a manufacter sticker with the brand and year and most times the size also. Just a guess but my bikes have them.
Mar 31, 2009 | 2003 kawasaki KX 250
kawasaki Full Suspension Mountain Bike Men Logo
118 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Phillip Edwin
Level 1 Expert
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
