Question about LG LSC121PMA Split System Air Conditioner
Samsung split systim leaks water from inside unite
Samsung 21/2 hrsp split systim leaks water from inside unit, what is causing this please. Thanks you.
  • farfett43 Feb 07, 2010
    Thank you for the answer, but we got a technision and he said he tested the drain pipe and it was opened, and he charged us $100 dollars, when we called him back to let him know that it is worse than before he touched it, he wanted another $70 to come again.
    Problem Solver:
  • 13 Answers
When ambient air goes across your evaporater it causes it to condense check your drain hose it may be clogged up not allowing the water to drain properly
Posted on Feb 07, 2010
  • stone09eric Feb 11, 2010
    something has to be clogged up he might have to pull the a-coil out and check the pan.
What would be causing Reverse cycle Inverter split system to leak? I have checked filters are clean and that there is no blockages of outdoor drainage hose?
The accumulated water has no drain to flow through, and is backing up in the indoor unit. Find the source of the clogged drain, and your problem will disappear. If you are lucky, you can pour a little bleach or peroxide in the indoor unit's cooling coil and the chemical will eat your clog. Otherwise, mechanical cleaning may be necessary. Check your installation manual to see how your unit is supposed to be plumbed.
Feb 22, 2015 | Inverter Heating & Cooling
Why does my split ac unit leak inside the house?
This happens when the drain pipe is too high, or kinked. The pipe must be lower then the drain pan in order for the water to drain. This is a common problem.
Jul 27, 2014 | Sanyo Heating & Cooling
Fridge leaking water inside.
Check frosting over would have clogged the drain pan. Unplug unit and wait for sometimes until defrost is over. Then run the unit. Please confirm, defrost timer,thermostat and heater are working properly to get auto defrosting time to time.Thanks.
Jan 30, 2011 | Samsung RS2534 Side by Side Refrigerator
Leaks water into the house from the inside unit serial no: 106KA02427
condensation problem may have t-stat set to low do not set unit more then 20 degrees lower then the outside air temp may also need the line set checked for complete insulation missing insulation can cause water leakage from condensation also
Jan 03, 2011 | LG LS-K2430HL Heat Cool Mini Split Air...
Hi, I have a samsung aqv18ja series split type air conditioner (cooling and heating) wall unit. the unit was install in 02/12/2009. By "one hour heating and air conditioning". In this short...
Simple, check in your remote. There is an option button "Blow". Just press it. Your unit gets completely off. Please write back if helpful?
Dec 26, 2010 | Samsung Heating & Cooling
Our Mitsubishi Mr. Slim split a/c unit is wall mounted and is leaking badly from the bottom left side inside our home. We have to use a bucket underneath the unit to catch the leak. Please help us to fix...
Reason for water leaking.
1. Filter block. 2. Cooling coil block. 3. Alignment of indoor a/c unit is sloping downwards. 4. Drain pan block. It's advisable to service your unit first.
Dec 06, 2010 | Heating & Cooling
Split HVAC does not achieve requested temperature
If is heating on outside temp must bee max 5 degree
Celsius.If leak inside unit then check drain hose.
Feb 15, 2009 | Mitsubishi MS-A09WA Split System Air...
Leaking water from inside samsung split sytem
if your indoor unit is leaking water down the wall,it is from one of two things.First, is possibly the insulkation on the copper lines is coming loose and the suction line is condesated,with no way to drain,it drips down the unit.The other possiblity is that the drain hose is coming loose from vibration and leaking a little.
Dec 31, 2008 | Heating & Cooling
GE SPLIT UNIT
I would check the unit to ensure that it is draining towards the pan assy. should be 1/4" per foot.
May 29, 2008 | GE Quiet-Aire Ductless Heat Pump Split...
Heating & Cooling Logo
741 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
