Question about Toshiba 27A33 27" TV
Sound ok but no picture - Toshiba 27A33 27" TV
  • Toshiba Master
  • 1,210 Answers
You have bad grounds on the solder side of the main board and maybe the crt board. If you can have someone pull the board out..do so carefully. Wait a few days to let the power drain from your tv before examining it. Look extremely close to any and all ICs with a heatsink attached. To the untrained eye it may look OK...but take a real effort and a magnifying glass and inspect closely. Look for cracked rings around the pins of these ICs. Resolder these and do not run solder between the pins. Use solder wick to correct this. Good Luck....you best effort may reward you...just remeber to be careful!
Posted on Feb 06, 2010
Check the high voltage on the picture tube it should be around 26 thousand volts. Check the back of the picture tube to see if its lit.
Rich
Feb 04, 2015 | Televison & Video
In Samsung tv complaint<br/>in first time tv working in normal and after sometime picture is blinking and slowly no pictre. that time sound is also ok.<br/>after that am am change the capa
Check its solder terminal at the CRT board [Filament voltage]. It sounds like the filament do not glow after some time due to a loose contact at the CRT base connector sockets. Check it.
If this does not help, check the ABL circuit for any open resistor.
Oct 25, 2014 | Televison & Video
Toshiba 42hl167 no picture sound ok
It sounds that the lamp-On signal doesn't comes from the main board. Check it. For more information go to http://electronicshelponline.blogspot.com/
Dec 03, 2013 | Televison & Video
Akai tv picture no sound
If picture is OK, sound should be there. Check the settings to sound first, ie, 'system' 'mute' etc, by entering the sound menu. If an improper system is selected, the sound will be either absent or distorted. If all the other settings are OK, and still there is no sound, you have to check the audio output section circuit, speakers etc?
Jul 19, 2013 | Televison & Video
No picture sound ok,osd ok.
LG 42pj350r this led tv sound ok but not cume picture
May 25, 2010 | Panasonic VIERA TH-42PX80B 42 in. Plasma...
Philips 32pw9617 crt no picture on analog channels but sound ok
this is your tuner board faulty replace tuner board hope this helps
Mar 26, 2010 | Televison & Video
Picture is ok hissing sound in rf connectoin
Yes, change the tuner and make sure that all ground are well connected.
Jun 16, 2009 | Samsung SlimFit TX-S3082WH 30" TV
NO PICTURE SOUND OK PICTURE COMS SLOWLY AFTER 1 OUR PHILIPS 50PF9966/12"
what do you mean..? be clear, so that many can help you...sir
Apr 27, 2009 | Computers & Internet
SANYO TV MODEL CM20SP8S CHASSIS AC3-A20
try to fine tune your tv using the remote control, or, if you had knowleged in electronics adjust the sound IF transformer using a wood stick or plastic don't use a metal in adjusting the IF
Sep 01, 2008 | Sanyo AVM-3259S TV
TOSHIBA IC DATA DISGRAM NO IS 8873CSCNG6PR6
EHT OK BUT NOT FUCTION NOLIGHT AND NO SOUND NO DISPLY
Jun 18, 2008 | Televison & Video
Toshiba 27A33 27" TV Logo
51 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
