Question about Philips Televison & Video
How do i remove base plate on phillips flat screen tv
5 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: how do i remove the stand/base off a panasonic
Place the TV on a flat bed preferably your mattress and look for the base mountings. The lock and base mount can be slid off and you can use a good wall mount that will support the weight to be fitted.
Please find the link below for help:
Wall mounting flat TV
Posted on Jan 07, 2011
  • 4234 Answers
SOURCE: phillips 42 inch tv
The stand base part number is 310430814621 and is available for $71.58 from tritronicsinc.com
Dan
Posted on Jul 30, 2008
SOURCE: Remove Base from Toshiba Regz 42RV530U
I bought this LG flat TV at Circuit City last week. TV is okay, but I was trying to hook up my portable DVD player and I can not make it work. I can hear the sound that coming out from the DVD but theres no picture from the screen. I believe my connection is correct, because there is the color coding which is red, yellow and white which you just connect at the back of the TV and at the DVD player.
Can anyone help me to figure out the problem. thanks a lot
Posted on Jan 31, 2009
  • 84 Answers
SOURCE: my phillips flat screen tv has been cracked and
You can have your plasma repaired using a TV Repair guy but often it costs as much as a brand new LCD. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
Posted on Jan 07, 2010
How to detach TV TH42PE30 from its stand TY-ST42PX20
There are four horizontal phillips screws (two at the end of the base plate directly above it and two a couple of inches above them) that are a slightly bigger diameter. Remove them completely and base plate slides right out.
Jun 30, 2011 | Televison & Video
I Have a Panasonic Veria TH37PX600B flat screen TV with no manual,what I would like to do is take it off it's stand to wall mount it.But how? I've tried removing various screws and plates but it...
Unscrew the base screws attaching the base to the TV set, once the four screws have been removed, the TV can be seperated from the base as shown below. The circles are where the screws were on mine before I removed the base.
Jun 12, 2011 | Televison & Video
How to install fan #1
Hello
Put on the work gloves. Turn the Samsung rear-projection television around so that the back is facing you. Use the Phillips screwdriver to remove the screws from the bottom left, the bottom right and across the bottom of the TV. Remove the screws that are directly above the ones on the bottom left, the bottom right and the bottom of the TV. Put the screws aside
Insert the flat-edged screwdriver into the seam between the bottom plate and the back of the TV. Wiggle the flat-edged screwdriver into the seam to loosen the bottom plate. Remove the bottom plate and put it aside.
Locate the fan assembly inside of the TV at the left corner. Use the Phillips screwdriver to remove the screws from around the fan assembly. Put the screws aside.
Mar 14, 2011 | Samsung LN40A630 40 in. LCD TV
Haw to remove the base from sharp LCD TV 56 in
I find this guide about how to remove the Base of an LG LCD TV. Things You'll Need:
* Table or other flat surface
* Soft cloth or towel
* Phillips screwdriver
Instructions:
1 Unplug your LG LCD TV from its power supply and unhook any other cables from the TV.
2 Lay a towel or a soft cloth onto a table or another flat, supportive surface.
3 Lay the LG LCD TV face down on the towel, which will protect the screen from being damaged.
4 Use the Phillips screwdriver to remove the four bolts that hold the base in place. The bolts are located in the center of the TV near the bottom.
5 Slide the stand out from the bottom of the TV.
6 Press the protection cover, which is supplied with the TV, into the spot on the TV where you removed the base until you hear it click into place.
7 Re-insert the four bolts you removed into the holes on the back of the TV and tighten them with the Phillips screwdriver.
I hope this help; remember to rate this answer. Good luck.
Sep 30, 2010 | Sharp LC-32SB24U 32 in. LCD TV
I am trying to wall mount my LG M197WDP - PZ 19'' TV but it has an ugly spigot that fixes to the free standing base. How can I remove this spigot? Thanks Dave
It's simple!
Step 1: Use a Phillips screwdriver to remove the screws holding the red plate off the bottom.
Step 2: Pop the red plate off (May need some persuasion! It should pop straight out, there is nothing else holding it in place, but be careful)
Step 3: Unscrew the four screws holding the spigot in place, and remove the spigot.
Step 4: Screw the 4 screws bach in place.
Step 5: Screw the red plate back into place.
Step 6: Enjoy!
Oct 22, 2009 | LG Televison & Video
Need to remove base from Proscan 32" TV
The stand can be removed by unscrewing six phillips-head screws from the back panel. A plastic insert plate is provided to cover the bottom hole that is left when removing the stand.
thats what i found from this site
http://www.crutchfield.com/p_68332LA30Q/Proscan-32LA30Q.html?tp=161
theres a manual on the left side of the screen just under recommended accessories
doesnt show how to remove it but might be helpfull for your settings
hope it helps
Mar 26, 2009 | Proscan 32LA30Q Television
Removing television base
You will need a phillips head screwdriver. There are four screws on the back of the TV that go into two rather long "legs" that go a few inches into the bottom of the TV. Just remove those screws and lift the TV off the stand. If you have your owner manual it will show you exactly where the screws are located otherwise just look for the heads of phillips head screws.
Mar 20, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
LN37A550 FLAT SCREEN TV
To remove the base stand, place the TV face down on a smooth surface. Place a cloth underneath it to protect the screen. Remove the 4 phillip screws from the stand. The stand can now be removed. The set can with a cover plate you can use to cover the opening.
See page #86 in the User Manual.
Mar 15, 2009 | Samsung LN37A530 37 in. LCD HDTV
I can not remove the bottom stand off the Proscan TV Model 26LB30QD to mount on wall. Any suggestions?
I have this model (ProScan 26LB30QD) and recently removed the base. There are 4 phillips head screws on the rear panel of the TV just above the base. Remove them, pull the TV from the base, and replace the screws in case you need to use the base in the future. I suspect the problem others are having is that they only removed 2 of the screws.
Nov 22, 2008 | Proscan 26LB30QD 26 in. LCD HDTV
Televison & Video Logo
392 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
