Canon Image Class M370 did say ''waste ink near full'' now it says 'Check Printer #343'. Please help
    Scholar:
  • 109 Answers
I cannot take credit for this one, but i bookmarked this a while back after a client had this problem. It's not the exact model, but i have used it on 3 different Canons and it worked.
1. Go to menu by pressing the > button
2. press [copy] and then #
3. go to 'test mode' by pressing > several times
when "test mode" is on the screen press the "ok" button.
4. now press 8 then 3 then 0
5. After that press the on/off button, everything should be fine now.
Posted on Feb 06, 2010
Waste ink tank full almost full on the canon mp730
These reset procedure will clear the error 343 or waste ink tank full.
1. Press the Menu key
2. Press the Copy key
3. Press the " # " key
4. Sroll from the menu option until you come to " counter ", then press OK.
5. Press Menu and select "clear all"
6. When the message "please wait" appear, press the Menu two times.
7. Restart the printer.
Let me know if this one solve your problem.
Please comeback and do rate this solution.
Thanks for using Fixya.
Aug 25, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
I have a Canonmp390 printer & a message keeps
Error "Waste Ink Near Full"
Cause : The waste ink tank (which holds the ink used for print head cleaning) is nearly full.
Action : Contact the Canon Customer Care - Center.
Have a good day.
Dec 03, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
It keeps coming up with Printer Check and then flashes ##343 FAX TYPE: CANON IMAGE CLASS MP390
The ink absorber for ink test is full of waste ink.
The waste ink absorber will need replacing, and the detection value needs to be set at '0' in Service Mode.
Nov 19, 2009 | Canon Office Equipment & Supplies
My Canon MP830 Printer will mot work. Alarm blinking and copy light blinking . How do i FIX? Dr.s' office...help!!
Canon MP750, MP760, MP780, MP830
The Unset mistake:
##341. Maintenance jet waste ink capacity full
##342. Cleaning absorption waste ink capacity full
##343. Ink detection waste ink capacity full
1. Include the printer.
2. Press button Menu , then Scan , Copy and once again Scan (entry in service mode, on дисплее will appear #1 SSSW)
3. The Arrow to choose 7. Printer test , press Ok .
4. The Arrow to choose 5. Ink abs capa , press Ok , install importance 0 .
5. Switch off the printer.
Sep 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP36 error ##343
The error code means "Ink Detection Waste Ink Tank Full". This means that the ink pad needs to be replaced. Also, dont forget to set the eepron counter to 0. Please follow the steps:
Press
ADITIONAL FUNCTIONS
SCAN
COPY
SCAN
scroll to TESTMODE
scroll to PRINTER TEST
scroll to EEPROM CLEAR
and the press the numeric key 3 or and keys.
Select INK COUNT, and then press the
numeric key 0 or and keys to reset the waste ink capacity.
Press the [Stop/Reset] key and then the
[ON/OFF] key to end the test mode.
I tries to replicate this error in my printer and I was able to aolve it with the above mentioned steps.
Hope this helps!
Rehards,
HP
Aug 28, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Can not print media
Basically ##343 means the waste ink absorber needs replacing (soaks the spilt ink up under the cartridges).
http://www.tradebit.com/filedetail.php/3901083-canon-pixma-mp780-service-manual
Link to an official Canon service manual. That should tell you how to change it.
Nov 07, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Error code printer check ** 343
the error is "Waste Ink Tank Full" error
This error occurs after a set number of nozzle activations, and it's to protect you from having ink start leaking out of your printer.
The waste ink tank is actually a large cotton pad in the bottom of the machine which absorbs the waste ink, and if this pad becomes full, the ink will pool and, like water, seek the path of least resistance, which could be where the case parts connect, and then leaking out onto your desk or carpet...
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu Copy Copy Copy Scan
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [Set] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
hope it works for your model
Hope it helps.
goodluck pls dont forget to rate this
Sep 21, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Error ##343 and it didn't print anything Orange light below screen has been flashing, screen message "Waste Ink Nearly Full". No idea where waste ink container is kept? Have changed cartridges. Now saying...
Manual Reset procedure Waste Ink Tank for Canon MP390:
  1. Start with printer on, press additional functions, Scan, Copy, Scan. Now you should be in service mode.
  2. Select Test mode (must be the last available selection).
  3. Select #8 Printer Test, it will start cleaning then it will come up with some other option: push the + or - button until it says 8-3 then hit the select button
  4. The menu will now say EEPROM Clear
  5. Select Ink count which is option (0) and press set
  6. Press Stop/Reset Followed by the power button and then wait for it to restart.
hope it helps
cheers
Jun 09, 2008 | Canon SmartBase MP390 All-In-One InkJet...
CANON MP730 ERROR MESSAGE 343 WASTE INK FULL
1-press the "menu" key
2-press the"copy" key
3-press the"#" key
scroll thru the menu heading until you come to "counter"
press "ok"
press "menu"
and select "clear all" it will ask you to "please wait"
then press menu two times
restart your printer
it will work
Feb 22, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
63 people viewed this question
k24674
jasbo
jasbo
