Question about Samsung YP-K3 MP3 Player
MP3 has not been used for a long time, will not turn on, battery is fully charged from computer,have tried reset button and still nothing, any clues ?
After reading a couple of other problems and solutions, I held the 'reset' button in for approx 30 seconds. That fixed it.
Posted on Feb 06, 2010
Iriver mp3 player aa battery
Are you all sure the battery is fully charged? a lot of time I forget to shut my player off and run the battery dry. Should this not be the case then try the reset. If rest is not working try plugging into you pc if the unit shows it should be charging. You can reformat your unit Problem is you have to re-add your music. To reformat go to my computer right click your device and select format. Now unhook from pc and turn on unit. Should this fail them you may need to check for an update to the firmware. Otherwise if not under warranty still ,time for a new unit.
Apr 26, 2014 | iRiver H10 MP3 Player
I had my iPod (5th Generation Late 2006, 30gb) plugged into my computer yesterday and my computer went to sleep (with my iPod still plugged in). I woke my computer up and then all my iPod would say was: ...
Try a manual reset by holding the center button and the play button together for at least 10-15 seconds, this should reset your iPod and should refresh the battery,
In future do not let your battery run flat completely always keep a charge, and lastly charge through a wall charger and not from the usb port,
good luck
Aug 12, 2010 | Apple iPod MA446LL/A MP3 Player
It is stuck on creating library. I have pushed the reset button and nothing When I connect it to the computer it is not recognized either
Well, Is it fully charged?
See, when chargible stuff aren't fully charged, they tend to freeze or even tend to loose funton of their buttons. Try putting it on the charger and wait till it's fully charged
May 12, 2010 | Sony NWZ-E436F MP3 Player
I was just using my ipod, and the screen went white... I tried the menu/center button but nothing happened.
Turn the touch off and turn it on again.
If the iPod will not turn off, try to reset it. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPod touch until it is fully charged.
If this doesn't work, try restoring the iPod
Nov 25, 2009 | Apple iPod nano
Wont Turn ON
(1) Hit the reset button for 5 seconds.
(2) Hit the reset button, slide down the on/off slide, and have it plugged into the computer at the same time. Hold for 5 seconds.
(3) Hit the reset button again.
(4) Charge it for at least 10 hours in the port in the BACK of your computer.
(5) After 10 hours, unplug the player and press the + volume button. While still holding it, plug the player back in. Keep holding it for 5-50 seconds. (most likely nothing will pop up).
(6) Let the player sit UNPLUGGED for a good 3 hours.
(7) Plug the player back in (it should light up now). Let it charge the usual time it takes to charge for an empty battery, about 6 hours.
Sep 14, 2009 | Creative Labs ZEN V Plus MP3 Player
My mp3 isnt charging right
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Mar 25, 2009 | Philips SA3025/37 Flash MP3 Player
Fully charge sony walkman NWZ-E436F does not turn on power at all
well u might have gone wrong u should charge ur walkman for abt 3 hrs first use untill full appears and it is recommended that even if u dont plan to use u r walkman u should atlest charge the battery once a while for battery mentainance try to reset ur update the player firmware.or even then if it dont comes send it to sony or have a converstion with sony support
Jan 31, 2009 | Sony Walkman NWZ-S616F MP3 Player
Nothing works
Does it say Philips and then go dark? If so, try pushing the reset button. Mine did this yesterday, because I did a complete erase. I had to push the reset a couple of times, then it started working again. I'm back in business, and listening to my songs as I type this.
Is your battery charged fully? Did you let it charge via your computer?
Jun 29, 2008 | Philips GoGear SA3125/37 MP3 Player
Battery wont charge correctly
Probably a hardware issue that requires replacment, but:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 30, 2008 | iRiver H10 MP3 Player
Philips hdd070 MP3 player has gone dead
i think it's hanged. Let it be the way is it, once the battery is exhausted and at that time when u start it, it should be OK.
Aug 22, 2007 | Philips HDD070 MP3 Player
Samsung YP-K3 MP3 Player Logo
165 people viewed this question
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
