Question about HP LaserJet 1022 Printer
My HP 1022 printer when trying to print a page it indicates that the local printer is not running. I have tried deleting temp files. I restarted the spooler system. I need some help fixing this issue.
    Problem Solver:
  • 12 Answers
By mistake pauge printing is activated ,deactivate the same
Posted on Feb 06, 2010
HP laser Jet 1022 only prints one page at a time
Jan 2013 Installed this new printer driver and all my HP 1022 problems disappeared; now printing perfectly back as usual!
HP Printer Drivers v.2.13 for OS X
Click on the link above or copy and paste the following address into your Web browser to view the article:<http://support.apple.com/kb/DL907?viewlocale=en_US>
Mar 05, 2012 | HP LaserJet 1022 Printer
The printer prints part of a page from some sites, some site the whole doc and some site a enpty page
solution 1>
click on start go to control panel go to pritners adn faxes or pritners in vista or win 7. then click on add a pritner. add a local pritner then hit next. choose existing port usb vertual pritner port. then hit next. under manufacturer select hp and under prtiners select deskjet 990c. hit next. do not share this pritner. finish add printer wizard. try pritning
solution 2>
click on start then click on run in open box type
%temp% hit enter. in vista enter %temp% in start search and hit enter it will open temp folder with lot of foledr optio0n find low folder adn delete it permanently then restart computer
Dec 16, 2009 | HP DeskJet 5550 InkJet Printer
Laserjet 1022 not printing on shared computers
on printer properties try to set on sharing tab check marks on : share this printer- render print jobs on client computers- list in the directory ..( all of this must be chacked).. on port tab see on what port is printer ..(tcp/ip - or virtual), on advance tab.. check alway available, spool print documents first., under security see if you have set group permission.. if you did not ,, add the computers to use this printer ( in most cases this is the problem).... if all of the above s set , and you can still not able to print .. enter in run...services.msc... find print spooler and restart it .. then try to print.
Dec 02, 2009 | HP LaserJet 1022 Printer
J6480 fatal error 2753 MSI.dot4wrp during full driver install. I tried uninstalling al related hp drivers, all the HP advice. Disabled firewall, services etc. Do you have a solution that works?
you can try with installing the windows installer 4.5 and then try.. otherwise reinstalling windows might work because the error you are getting is related to installer.. and its a service of windows itself which is responsible for all the software installation..
Oct 29, 2009 | HP DeskJet 648c InkJet Printer
Printer Not Woking In Network
1. check that not any firewall or antivirus software blocking your printer.
2. try to look in paper settings what format you sending to the printer. is it letter format or A4 or what ? it should be A4.
have you tried to connect the printer with USB? or have you connected the printer with a network cable.?
Jul 03, 2009 | HP LaserJet 1022 Printer
HP LaserJet 1022 changes the output order for checks, statements, invoices. Worked fine until 4-5 months ago (we switched over to a citrix server). Have tried reinstalling to citrix and local hard driver...
It sounds like a computer software issue. However to overcome the problem through the printer you can try this.
When the screen pop up comes up for printer selection, highlight the printer you will be using, then goto "Preferences". At the top tab click on "Advanced". Go to the bottom of the menu for "Layout Options" and change "Page Order". This should solve your problem, though you may have to change it back to print regularly printed materials.
May 18, 2009 | HP LaserJet 1022 Printer
HP LaserJet 1022 Printing Blank Pages
Aug 08, 2008 | HP LaserJet 1022 Printer
HP print spooler problem and error 1068. Want my printer back!!!
Just go to your Server or Desktop PC and enable the RPC service (Remote Procedure Call)
Right click in "My computer" icon, from the manu select "Manage" then go to "Services and Applications" and expand that, after that select "Services" you will find that services in the right pane, just click in "Start"
I hope this work for you, good luck!!!!
Jul 28, 2008 | HP LaserJet 1022 Printer
HP LaserJet 4240/4250/4350 PCL 6
I think its a virus infected....... run scanning software.. to detect virus... second you need to do is log in as a administrator then go to the printer property and delete pending print jobs...then restart your unit..
gudluck
Mar 25, 2008 | HP LaserJet 4250n Printer
HP PSC 1410 All-In-One printer speed is slow
Hello Sir,
I would like to provide you few workaround steps, you may try to improve the printing speed on the computer.
Delete all the Temporary files:
For Windows XP:
(1) Click Start >> In the Run window, type "%temp%" which opens temporary files folder.
(2) Delete all the files that are listed over there.
If Windows Vista:
(1) Click Start >> Programs >> Accessories >> In the Run window, type "%temp%" and press enter.
(2) Delete all the files listed under temporary files folder.
Another Workaround:
(1) Click Start >> Printer and Faxes.
(2) Right click on the Printer icon which is set as default and select properties.
(3) Click on Advance Tab.
(4) put a check mark on "Print Directly to printer" option.
(5) Click Apply and Ok.
Hope this solution would be helpful in resolving the issue that you are experiencing.
With Regards,
Ashesburn..
Feb 24, 2008 | HP PSC 1410 All-In-One InkJet Printer
HP LaserJet 1022 Printer Logo
160 people viewed this question
Seeker5211
Seeker5211
