Question about True 598-TSSU6024MBSTADA Mega Top SandwichSalad Unit split top 155 cu ft (24) 4
Compressor Overload is bad. Bypassed it, everything works. I went to get the part MRT22AIN-34, was told to replace the coil, cap, and overload with ERP410. I get the fan to work but not the compressor. I'm losing the stock in the refrigerator due to 60degree temp. I wired S-C-R as indicated. The other two wires on the ERP says Power supply. I am not sure how to wire this.
  • firststreetc Feb 06, 2010
    Power supply turned out to be line AC. Compressor and fan now work. Compressor cycles, the fan stays on continuously (so far). The fan is wired to line and C. I am not sure if that's correct. I'm thinking it should be C and R, or C and S. Not sure.
  • 58 Answers
SOURCE: relay and overload on the compressor
the relay will be burnt up inside, shake it and little pieces will come out if its burnt out. the overload usually is never the problem
Posted on Mar 12, 2008
SOURCE: Box Not cooling
Jumping wires out is a good way to KILL SOMEBODY!!!!! You have no idea what you are doing, PLEASE unplug it and call a refer guy.
Posted on Aug 07, 2008
  • 66 Answers
SOURCE: The starter/overload and overload protector
The easiest way to find this out , is to check the condenser. Make sure that the condenser is not clogged up with dust and that the condenser fan is working. Replace the start relay. Turn it back on. If it starts right up then it probably overheated and melted the relay due to the condenser fan not working or the condenser clogged with dust. Air circulation through the condenser and air being circulated over the compressor in how it cools itself. If the compressor will not start or if it runs for a little while and then shuts off from overheating, then you have a bad compressor.
Posted on Nov 12, 2008
  • 163 Answers
SOURCE: Compressor non start, overload cycling
you may want to try a 3-n-1 hard start for your compressor.the 3-n-1 has overload,relay and capacitor in one unit.very easy to install.it is possible your compressor has froze up.but worth a try.you can pick one up a your local appliance parts store.directions are on the bag.
Posted on Mar 25, 2009
SOURCE: small refrigerator compressor overload relay cuts out
I am told if you measure two terminals and note the two with the highest resistance. Then measure each of the two terminals with the highest resistance to the common terminal they the two additional readings should read the same as the two terminals with the highest resistance when adding them together. If after adding the two there is more than 1/2 ohm difference one of the windings is shorted.
Posted on May 06, 2009
Kenmore freezer overload relay went out so i fixed it for about two days . why would it be blowing the overload relay, bad compressor maybe ??
is the relay side sensitive? installed upright? what's starting amps on compressor? verify all connections tight, obviously replace start kit first but possibly compressor going bad.
Apr 15, 2018 | Kenmore Heating & Cooling
When the compressor tries to come on, why does it click and hum, then clicks off?
Two causes for that situation. The compressor has a start relay and a overload mounted on the 3 prongs. When the relay/overload is bad, compressor will kick on, hum, then a click sound. The click is the overload. Or, the compressor is drawing too much power and the compressor is bad. 90% of time it's the relay/overload but you need to check and make sure fan is running by compressor and coils underneath are not clogged up. Poor air flow around compressor can cause overload to go bad.
Aug 19, 2015 | Refrigerators
My woods make up right fridge will not stay cold , what could be wrong with it? i was told it could be the compressor, relay/overload/contact block/temperture nub ,etc I tried calling the makers but the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Yes, you probably were told correctly...check the relay and cap first though...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 11, 2010 | Refrigerators
NOT COOLING ....CLICKING SOUND FROM COMPRESSOR
Compressor Start Relay/Overload or Compressor is bad. A bad compressor can cause Start Relay/Overload to go bad but the only way to know is to replace the Start Relay/Overload if you still have the same prob. or it works a week or so and it happens again the Compressor is bad or if luck is on your side it will work.
May 22, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Compressor kicks off on overload/relay. Even after replaceing overload/relay and cap. It will run ok for a week if you let it cool down.
This is often found in small compressors when they heat up too much or too often. check to be sure the condenser coil is clear and has good airflow. If so and it still trips on overload then the compressor is bad. Hope this helps. Good luck.
Mar 23, 2010 | Amana ARB8057CSR Bottom Freezer...
Frig keeps overloading circuit breaker, just repaced relay
I think the compressor has a problem with its internal running coil , or it's grounded.To check it you can disconect the power to the compressor and then turn on the breaker , and if doesn't tripped the breaker ,you know the compressor is bad.
Sep 06, 2009 | Refrigerators
Refrigerator not cold . Motor keeps clicking on
Sounds like it is cycling on overload. Condenser coils (may be on back, or under bottom of fridge) may need cleaning. If coils are under bottom, it could be the condenser fan not working, causing it (compressor) to overload. Possibly compressor start relay bad. Worse case, compressor may be bad. If you don't know much about electrical stuff (compressor, relay, etc...) you should have a repair tech check it for you. If coils are dirty, clean them with a vac and coil brush (gently). You can get coil brushes at most hardware stores (Lowes, Home Dep, Ace, etc...) Hope this helps.
RH
Jun 25, 2009 | Amana Refrigerators
Compressor gos to overlaod
sound like a bad start capacitor,if you have a capactance check on your multimeter,you can find the readings on the side of the cap.I always replace the relay,overload and capacitor at the same time. this usually keeps me from coming back and having to replace another part in a short amount of time. Also check and make sure your condensor coil is clean , let me know if you need more help
Mar 31, 2009 | Turbo Air 49 cu. ft. / 1388 liter...
Whirlpool side by side not cooling
wihtthe modle number you can look up a part, try replacing the overload/relay( starting device) for compressor, may be bad compressor( in which ase youll need a professional) but the overload relay you can do yourself for about 60-75 bucks
Mar 28, 2009 | Refrigerators
True 598-TSSU6024MBSTADA Mega Top SandwichSalad Unit split top 155 cu ft (24) 4 Logo
826 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
