Backlight comes on with powerup but goes off after half a second
  • gcsltd
    gcsltd May 11, 2010
    Have it replaced & check the inverter board as well
  • 11,361 Answers
Look for bad caps in the power supply first, the problem can also be abd inverter circuits or bad lamps, see example of failed monitors (most common) due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you further.
Posted on Feb 08, 2010
Screen comes on for less than a second and goes black
If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine and half Lakh viewers cannot be wrong.
May 11, 2013 | Televison & Video
What makes a computer monitor lose backlight
There are two reasons, the inverter transformer, "usually more than one" is the most likely to break down, the second issue that crops up is the backlight, "again more than one" do go on a occassion.
Apr 24, 2012 | AOC 22LVWK Monitor
Sound but no picture, has worked for 4 years and went black. Cycling power displays video for a half second then goes black again.
LCD inverter backlight board is dead.Replaced this LCD inverter backlight board will get the picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.It a long board in shape.
Feb 28, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
VP191B VIEWSONIC MONITOR POWER ON AND PICTURE SHOWS FOR HALF A SECOND THEN GOES BLANK, POWER OFF AND POWER ON PICTURE FOR HALF A SECOND AND GOES BLANK
More likely to have problem in either the backlight light inverter board or bad lamps due to poor solder connections, see http://s807.photobucket.com/home/budm/allalbums
You will need test lamp to narrow down the problem.
Feb 05, 2010 | Computers & Internet
I have an Acer AL1912 that when you plug in the ac, the green power light will blink for about a minute and a half then go solid. The backlight will come on and you can see a faint ghost of vertical lines...
If it is still in warranty call the manufacturer.
if not give more info elah4@zoominternet.net. May be somthing simple like a cable
shutdown computer unplug then disconnect the video cable on the computer from the monitor, plug monitor back in and turn it on, there should be a display that says no video source within a few seconds, if unit is working properly. shutdown and connect video again and then reboot computer. sometimes it just takes a compleat power disconect to reset things,
Jan 30, 2010 | Acer AL1912B 19" LCD Monitor
Lower half of monitor goes dim
Replace the backlight in this unit will bring you back in business.
Thanks please rate.
Aug 19, 2009 | Star Logic 17" LCD Monitor
Fdp2275w Gateway lcd monitor won't turn on. comes on for a second then goes black
Ok, I just got one last night, and it took a while to open the bugger. Why put screws when there are so many hidden clips to carefully pop? My poor Craftsman club card will never be the same! But, I digest...
There were two bad capacitors, the first and probably the main culprit was a 1000uF 25volt cap that had expanded and vented. I also found a 680uF 25volt cap that started to expand, and when tested it was low, about 550uF.
If you are so inclined, these can be obtained by mailorder (I use Parts Express), but Radio Shack parts can be used in a pinch, just expect to go back in there eventually. I didn't have the 105 degree low ESR caps, so I used regular ones and I had the monitor up and running in aobut 90 mins.
Check for any capacitors that are expanded at the top. Look for a dome shape or feel with your finger, it should be completely flat. Or look for the rubber bottom pushing out where it goes into the board. This is the third monitor I have repaired in the last six months, and each one needed one or two capacitors to fix a dark back-light problem.
Jan 15, 2009 | Gateway FPD2275W LCD Monitor
Tv immediately turns off
Four flashes indicates a problem with the backlight on the TV. It can be caused by the backlight inverter board (the power supply for the backlight) or by defective backlights in the panel It is USUALLY the backlight inverter board that is bad, but I have seen both components fail at various times. This set is fairly new and should still be withing the one year warranty, so you should contact Sony at 800-222-SONY to get it repaired. Be sure to rate this solution. Thanks!
Nov 16, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Lcd tv backlight prob
You need to replace the inverter board if you can find the spare part. Otherwise you need to replace the whole lcd panel.
Jan 01, 2008 | LG RZ-17LZ40 17 in. LCD Television
Computers & Internet Logo
412 people viewed this question
David Payne
David Payne
