Question about Exercise & Fitness
Treadmill causes electrical fuse to keep tripping and cutting off
Has started to cause the fuse to blow out the electricity in the room it is in. Have had problem free ownership for 3 yrs. Have aready tried cleaning the motor and belt and also plugging it in a different outlet.
    Sergeant:
    Champion:
  • 204 Answers
Check to see if theres other loads on in that room(s). Usually if youre running something, and something else is turned on, the load can be more than the circuit breaker is able to carry. If possible, try using the treadmill in another area where there is little activity or not using so many things at the same time.
Posted on Feb 06, 2010
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
Fuse keeps blowing immediately when switching on the treadmill, why does this keep happening?
A fuse is designed to prevent excessive current from flowing into a circuit. If the latter is not protected by the fuse, the excessive current can either cause some serious damage or the excessive current can overheat parts and perhaps result in a fire.
So, you are drawing too much current and that explains the small plume of smoke you experienced. If an electric motor runs slow because of excessive friction or load, it will use too much current, overheat and burn out the windings. Disconnect the motor and attempt to run the unit with the motor disencumbered. If the new fuse does not blow, then the problem is with the drive mechanism. If fuse blows, the problem is with the electronics and not the motor.
Aug 26, 2015 | Exercise & Fitness
My portable ge air contioner 8000 btu keeps blowing fuses, even when it is the only thing plugged into that fuse
The reason you are blowing fuses is 'high amp draw,' which is most always caused by a 'electrical short,' and the most common things to cause such a short are the 'compressor and fan motor(s).
I would say you need a serviceperson to determine exactly what is causing your short.
Jun 09, 2011 | GE APN08AA Portable Room Air Conditioner
Treadmill electical issue: My Spirit SR275 Programmable treadmill blows the panel electrical fuse for our workout room when I start the belt. I can operate other treadmill control functions without blowing...
A treadmill has a high current draw -- it should be on a dedicated 15 amp-circuit -- if sharing a cricuit, it's not unusual, from time to time, for it to trip a breaker or blow a fuse in the main panel.
Charlie
Jan 12, 2011 | Kitchen Ranges
I have a Weslo Cadence M5 treadmill. When i used it, it tended to trip out the electrics when the treadmill was started, but worked when I put the trip switch back up again and tried again. However, it has...
hi, firstly change the fuse in the plug to a higher voltage, then if you are using an extention wire make sure all the wire is unrolled. i had the same problem with my m5. i was using an extention wire on a roll that was shorting out the trip on the treadmill and cutting the electric off. so just by putting a higher amp in the plug and i am now using a 2m extention alot safer and much better,
Nov 18, 2010 | Cadence Weslo 5.0A Treadmill Walking Belt
Blowing 25 amp fuses
In that case the outlet your using is pushing out too much electricity. Try calling your local electric company for help or a professional electric repair man.
May 21, 2009 | Emerson Black Microwave Oven
Treadmill trips electrics
Check to see that the treadmill does not draw more amp than stated in the owners manual. If you are, then the problem is in treadmill. If not try another circuit in the house (not just another receptacle).
Jan 09, 2009 | Proform 380 CS Treadmill !
Candy cic 60 keeps tripping electric
take cover off fan and see if there is signs of water there. a common cause of tripping is that water is thrown up from the fan onto the element.
get back to me if you find this
Aug 13, 2008 | Candy CDC266 Dryer
My dryer keeps causing my fuse box to blow! causing all electrical appliances in the appartment to switch off. I have tried to change the fuse in the plug but it still want work.
the heating element is probably broken and touching against the back part of the drum casing, causing a direct short circuit, causing the breakers to trip. don't try it anymore untill you check the element first.
Apr 27, 2008 | Dryers
Exercise & Fitness Logo
466 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
