Question about Lexmark X2500 All-In-One Printer
Lexmark reset ink cartridges ?
The link doesn't exist any longer.
Posted on Feb 17, 2010
    Genius:
  • 2,035 Answers
Use this link to reset the ink levels:::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:593:0:0&framed=&docid=ENUS28290&relevance=1
Posted on Mar 25, 2008
fredycruger
  • 322 Answers
SOURCE: Lexmark 29 ink cartridge
yes you can go to printer and scanners bring them up and right click on printer and go through the menue you get ?
Posted on Feb 07, 2008
SOURCE: x5470 Lexmark printer
Just unplug the printer from the back and plug it back in. Problem solved. I did this on my mother's printer and it worked like a charm for this same error msg and issue.
Posted on Jul 07, 2008
  • 6 Answers
SOURCE: lexmark x5495
Lexmark advertises the cartridges supplied with this printer as cart. #28 and #29. They claim these are nonrefillable. The refillable cartridges are #28a,29a, 34 and 35, the last two being the high yield carts. Make sure you have one of these.
Posted on Aug 08, 2008
  • 15 Answers
SOURCE: ink cartridge reset.
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
-Mustafa
Posted on Jul 13, 2009
ghassun
  • 499 Answers
SOURCE: how to reset lexmark36 ink cartridge
try to reset ur printer
press and hold on power button for about 20 sec then press hte power button again
Posted on Jul 25, 2009
How do I reset the ink level on my lexmark x8350?
http://support.lexmark.com/index?locale=en&segment=SUPPORT&startover=y&userlocale=EN_US&question=x8350+ink+level&productCode=LEXMARK_X8350&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X8350&searchid=1280474419390#1
The above is the description page for you Lexmark printer.
Solution
Some menus on the X8310 and X8350 are repeated in the Copy Mode, Scan Mode, Fax Mode and Photo Card menus.
If you press the Menu button while in any of the above menus, two ancillary menus will be listed, Maintenance and Device Defaults.
To select either of these menus, press the check mark pattlnk_442006_155-selects.gif at the center of the navigation keys on the printer.
Maintenance Menu options View Ink Levels Clean Cartridges Align Cartridges Print Test Page Reset Defaults
Device Defaults Menu options Set Date and Time Language Country Copy Paper Photo Paper Photo Size Button Beep Power Save Timeout Caller ID Pattern
The ink levels should reset when the ink jet cartridge is installed.
Jul 30, 2010 | Lexmark X8350 All-In-One InkJet Printer
Can one reset the Lexmark P6250 printer refilled cartridge?
No, you can usually tell your printer to "ignore ink levels" when it gives the ink low warning on your computer screen. As long as they print just keep printing until they run out.
Dec 28, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Can't reset ink level on my z605 lexmark printer
Go to "Lexmark solution center", then go to maintenance, then "install new cartridges".Check "No, this is new" option on cartridges and ink level will reset.
Oct 30, 2009 | Lexmark JetPrinter Z605 Color InkJet...
Refill inkcartridge 17 of lexmark x2250 don't work
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 28, 2009 | Lexmark X2500 All-In-One Printer
RResetting Cartridges after refilling
Can't be reset. The Lexmark 32 & 33 (and porbably som others) contain a low ink sensor in the cartridge that once activated can NOT be reset. The key would be you have to refill before the low ink sensor gets activated. Don't know at what ink level that is, probably around 1/4 remaining.
Apr 15, 2009 | Lexmark X5250 All-In-One InkJet Printer
Using a refilled ink cartridge on a Lexmark x4850
Yes, most Lexmark cartridges as well as many other manufactures use something called 'Smart' Chips in the bottom of the ink cartridge. Usually unplugging your (about 10 seconds) printer resets the memory in the printer. Hope this helps!
Mar 20, 2009 | Lexmark Wireless X4850 All-In-One Inkjet...
How to reset lexmark x4580 ink cartridge after refill.please help
http://images.lexmark.com/publications/pdfs/2007/3500/v2103618_en.pdf
Page 99-100
Jan 15, 2009 | Lexmark X4580 InkJet Printer
X5470 Lexmark printer
Lexmark and Dell use a sensor in the cartridge to sense a low ink level. Once the sensor has been activated, you cannot reset it. The printer should work fine except for the fact that you'll have to override the "low ink" message on your computer.
Manufacurers don't make money on printer hardware. All the money is made from ink replacement, so they make it as difficult as possible to use anything other than the stuff you buy from them. Some (HP) put in chips for an "expiration" of the ink/toner. Go beyond the expiration date, the thing won't work.
May 13, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Ink level reset
if you are useing a refilled cartridge , ink cartridge has a chip built in that must be reset, if you look on line you can purchase a reseter. if you use a new ink cartridge it will show a full ink level
Jan 15, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark X2500 All-In-One Printer Logo
4,058 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
