Question about HP Compaq nc4400 Notebook
Computer/laptop to wire up and display on tv
How do you get your computer/laptop to wire up and display on your tv
    Guru:
  • 194 Answers
For and LCD TV you can hook it up via a VGA cable. You can purchase a VGA cable at any electronics store.
Good Luck,
NOLA Tech
Posted on Feb 06, 2010
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
HDMI
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
DVI
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
S-Video
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
No video signal vga laptop to tv
Make sure you have the TV's input set to PC or Computer to receive the signal from the VGA.
Make sure the connections are snug on the computer and on the tv.
Reboot the computer and see if it automatically starts the display on the tv. If not, there are a sequence of keys that you can press to toggle the display between the tv and the computer.
Normally to toggle the display you will have to Press and Hold the FN function key located at the bottom left portion of your keyboard and then hit the corresponding key (F1 thru F12) that toggles the display. The correct F1 thru F12 key to hit will have the CRT/LCD on it or it might have the icon of a display.
Apr 22, 2012 | Toshiba Computers & Internet
I'm trying to connect laptop to Panasonic Viera TC-P46S30 using VGA-HDMI converter. I'm getting 'No signal. ...' box displayed on TV. How can I fix it.
on your computer, go into your vga graphics driver and hit properties, set it for dual and hit apply. close the box. then go to the graphics,options, look for dual. make sure the wire is tightly in your tv and computer. switch your tv to vga. it should be lit. then you should see your desktop on your tv screen.
Dec 11, 2011 | Televison & Video
Problem just started. Getting na signal on TV.
1. Remove the video/display cable from both TV & Laptop.
2. Again Connect the two devices properly.
3. Press "Function Key+F5" to connect to the TV (External Display)
4. Also put your TV in "TV/AV" mode.
tell me if it don't helps...tc! :)
Jan 05, 2010 | Toshiba Laptop Computer Battery PA2510,...
How do i get my laptop to play thru my hd tv. I
your computer must be set up to display images to another playback unit - i.e. tv. go into display proprerties and choose "another" video display. right now the laptop is only set to display to your laptop.
Oct 17, 2009 | Acer Televison & Video
No picture from computer to pc
Please check the following things:
(i) You're using an appropriate cable to connect the TV to the Computer.
(ii) The cable is connected to the out port on the Computer and the corresponding in-port on the TV.
(iii) You've selected the correct input on the TV.
(iv) Dual display is enabled on the Computer.
(v) The resolution of the video signal being transmitted from the Computer to the TV should map the display resolution support by the TV. In this case, you may try lowering down the resolution of the TV in the Display Settings window of the Computer after selecting the second display.
Aug 31, 2009 | Toshiba Computers & Internet
How to connect my compaq v2148ap laptop to tv using svideo??plss help fast....i dnt have the vga wire i have the 7 pin wire!!
Do not use a cheap cable !
Use a good quality cable
You also need to tell your computer that it has another display available to it
to do this RIGHT click on a blank area of your desktop then select properties.
Now click settings If you can see TWO screens with the number 1 and 2 on you are already part way there
Now click Advanced.
If you see a tab that is for your graphics card select it
From here you should be able to tell your laptop to use multiple displays
You should select Clone (if you have dual-view available then select that)
You may have to lower the screen resolution at first and maybe even adjust the two displays individually
If there is an option for "detect my tv" that would also be a good starting point.
It does vary from card to card and even computer to computer for the exact steps.
With any luck you should now have two displays and it would be just a matter of making minor alterations to make the two displays suit your taste.
Be aware however that not all computers with Svideo may work with a regular tv. This process works best with flat screen lcd and plasma tvs
Aug 22, 2009 | Compaq 389897-001 - HP/ Presario V2000...
Hooking up computer to philips 60pp935217 AV5 HDTV connector?
Hi Roger,
Initially, pls try lowering the screen resolution of your PC. This can be done at the Display Properties/Settings tab and then move the slider of the Screen resolution towards the left, Apply OK. In some instances, you need to also lower down the Screen refresh rates in the Monitor tab of the Advanced Properties.
If your concern has not been corrected after completion of the above procedures, then other methods can be considered.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 15, 2008 | Philips 60PP9202 60" Rear Projection...
Laptop to tv
The resolution setting on your pc must be in the acceptable range for the monitor to handle. Look in your tv owners guide to see the resolution range and make sure your pc is not over that range or it will not work. Good Luck
Apr 03, 2007 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
HP Compaq nc4400 Notebook Logo
81 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
