Question about IBM Lenovo ThinkPad R61i Notebook
I Press The power Butten the lights Blink once then it just has this light That looks like a circle with a Z in it stay on and battery light and plugged in light stay on nothing else happens doesn't go any further Please Help
  • 35 Answers
I suggest you try a manual reset. Please remove battery and AC Adapter and hold down power button for 30 sec. and then put battery back in and AC adapter and try starting.
Posted on Feb 06, 2010
I need remote control code for Dawin TV
If you do not know the code, you can use the code search function to program the remote control.
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Apr 04, 2016 | Televison & Video
Have lost instructions to Emerson universal jumbo remote
Using Code Search:
Program a Manual Code:
1. First turn on the device that you want to program such as your TV or DVD player.
2. Point your remote control at the device.
3. Press the button on the remote that corresponds to the device. If you want to program the TV, press the TV button.
4. Press the "Code Search" button for about 3 seconds until the light stays on.
5. Enter the code for your device using the number pad. The light will blink each time you push a button. If the code works, the light will turn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work, start from the beginning by holding down code search until the light stays on and use a new code.
6. Press the power button to test if your device turns off. It it does not turn off, repeat the process with a new code.
Retrieving the Code for your Device:
If you used the code search function to program your device and want to know the code for future reference, you can retrieve the code from the remote. To do this:
1. Press and hold the Code Search for 3 seconds until the light stays on.
2. Press the device button for the code you want to retrieve. Press TV to get the TV code, etc. The light will blink once and stay on.
3. Press the number buttons from 0 to 9. When the light blinks once, that signals the first number of the code.
4. Repeat for the 2nd and 3rd digits of the code. The light will turn off after you retrieve the 3rd digit.
Programming the Sleep Setting:
1. Press and hold the "SLEEP" button until the light stays on.
2. Use the number pad to enter 2 digits for how many minutes to use for the timer (01 to 99 minutes). The light will turn off and start timing.
3. Make sure the remote is pointing at your device.
4. To cancel the sleep timer, press the power button once or hold down the sleep button until the light flashes once.
Here is a list of the Emerson Universal Codes:
http://www.jumboremotecontrol.com/remote_control_code_list.html
Here is a copy of your manual: http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
Mar 08, 2011 | Televison & Video
Remote code for sanyo tv
there are several. try each one seperate.
1. press and hold setup button until the red light stays on.
2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
3. enter one of the 4digit codes.
note: if the code is valid the light will turn off if it flashes it is an invalid code.
4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
CODES: 0049,0097,0110,0004,0268,0012,0108,0180
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 29, 2009 | Sanyo DS20930 20" TV
I NEED THE CODE FO JVC
CODES: 0060,0026,0197,0069,0160,0247,0923,0012,0065,0067,0141
Aug 28, 2009 | One For All URC-4021 Remote Control
Sentry RMC-10 remote can't 'discover' my tv's code
.there are several codes. try each one seperate.
CODES:1171,0116,0167,0176,0922
Aug 28, 2009 | Sentry SE-RMC10 Remote Control
Need codes for rca remot control have phillps tv
CODES: 0514,1174,0062,0204,0184,0208,0205,0206,0207,0004,0189,0183,0199,0200,0081,1149,1154,0288,0456,0003,0008,0068,0075,0086,0087,0141
Aug 28, 2009 | RCA Universal Remote Control
Stand by led blink 4 times
my tv is FD Trinitron WEGA KV-HA21. when i press the power button it starts but after about three secounds it trips to stand-by and starts blinking four quick succession at intervals
Jul 20, 2008 | Televison & Video
when you press the botton the light comes on then goes off
Jul 19, 2008 | Televison & Video
Sony tv lead light blinks
The standby light should blink in a repeated count separated by a 3 second pause. If you can post the count here, we should be able to provide you with details about the problem circuit and what will be required for repair.
Thanks,
Dan
Jul 14, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
IBM Lenovo ThinkPad R61i Notebook Logo
234 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
