Question about Vacuums
Will not suction Checked Hepa filter, hose, and removed brush pan/cover.
  • Philip Gaut May 11, 2010
    Help us to help you - tell us the make and model of the machine!
    Genius:
  • 1,031 Answers
How full is the bag? If equipped with a light, did your full bag light come on?
Posted on Feb 06, 2010
I have changed the hepa filter & made sure the washable filter is clean. I checked the brush & it's working fine. The indicator is still red very little green. Not suctioning good at all. What...
check the suction hose where it bends down to the floor unit,, lots of times dirt,hair and stuff collects there when the filter was plugged up. remove the floor plate ( like you were going to change the belt ) and use a wire coat hanger to run up the suction hose and back out and clean out any debris, also check the entire hose for blockage ( top to bottom ). if this is all clear and you still have little suction - then the problem could be the vacume motor itself and you will need to take the unit into the repair shop and have the motor rebuilt or replaced.
c..
Feb 02, 2011 | Bissell 3920 Bagless Upright Vacuum
Would a clogged hepa filter cause the vacuum to stop picking up dirt? There's suction on the hose when I checked it.
Generally the Hepa filter is a bypass filter in which there is another filter on the unit. Check to ensure that the belt is allowing the rollers to turn the brush. Just suction on the line won't pick up deep dirt unless you allow to sit in place.
Oct 05, 2010 | GE 106585 Upright Vacuum
My hose no longer works no suction buth the vacuume still works how do i fix I checked the hose checked the filters nothing works to get my hose so it has suction.
Check the following after unplugging the power cord from the outlet.
- Check for suction at the back of the unit, after removing the hose where it attaches to the back of the vacuum. If there is NO suction, the machine will need to be taken to a local Service Center for inspection.
If there IS suction at the back of the machine with the hose removed, please check the following:
Unplug the unit from the outlet.
- Check the Pre and Post-Motor filters for debris. Dirty filters can restrict airflow. The pre-motor foam filter is square and located in a pull out tray underneath the dirt cup. The foam filter may be hand washed in cold water with mild detergent. Reinstall the filter when it is completely dry. The post-motor HEPA Media filter is rectangular and located on the side of the machine. Note: The white HEPA Media Post-Motor Filter is not washable.
- Ensure the dirt cup is empty.
- Check the upper tank for build up or clogs.
- Twist the inner cyclone to the left and pull down
- Wipe the inside of the upper tank and separator plate with a
damp cloth moistened with water or mild cleaning detergent.
- Once the inner cyclone is dry, lock back into the machine by
pushing up and turning to the right.
- Put the dirt cup back in
- Check for good suction at the end of the upholstery hose. If there is good suction, make sure the hose is firmly connected to the lower hose on the back of the vacuum. If there is no suction at the end of the hose, check the hose for splits, cracks or clogs.
- Make sure the brush is rotating. If it is not, remove the access plate and examine the brush, and belt for damage. The access panel can be removed by lifting the 4 tabs located at the bottom of your machine. Lift tab 1 then 2-4 tabs to remove the access panel.
CLEARING CLOGS
- Detach the upper hose from the machine. Insert a broomstick into the hose to push any obstruction through to the opposite end.
- Remove the screw from the left side of the lower hose on the back of the unit, and straighten this section of hose by pulling it down or lay the unit out flat, and roll the unit on its side with the lower house towards the top side. Look through the hose for any obstructions. Push a broom stick through the lower hose to unclog.
Aug 12, 2010 | Bissell Upright Vacuum - The Pet Hair...
Low suction
Check the tube that leads down to the brush head for clogging as well as any motor or HEPA filters. If that still shows nothing, take the cover off the brush head (like you're changing the belt) and look for obstructions in there. Usually, if you have low suction on the accessory hose, the problem is with a motor filter, HEPA filter, or a clog where the hose goes into the unit. If you have good suction on the accessory hose but none on the floor, it's usually in the brush head (clog or broken belt) Good luck
Feb 28, 2010 | Dirt Devil Vision Turbo W/Bonus Upright...
Kenmore progressive 360 vacuum cleaner has low suction
Feb 28, 2010 | Kenmore 35912 / 35913 Progressive Upright...
No suction
Feb 28, 2010 | Euro-Pro EP602 Bagless Stick Cyclonic...
Spitting Out Debris
the hose from brush go to the bag need to check for blockage you have to open there hose to clean
Aug 13, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Loss of suction and bag full
Sounds like you still have a clog, either in the hose, drop something down it to see if it comes out the other side. The other place is the dirt inlet by the brush roll. Take off either the top cover or the bottom plate and you can check it out.
Feb 19, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
