Question about Vizio Televison & Video
When using remote to adjust sound or to change channels sound continues to go to extreme low or high and when changing channels they keep changing in sequence without using remote
  • 712 Answers
This may be because of your personal preferences settings for channels. Try to adjust the personal preferences of each channel according to your wish. Most remotes have the options to set personal preferences.
Posted on Feb 06, 2010
Why does the channel up or down sometimes not work?
It sounds to me like you have a fault in the tuner circuit. I suggest you take it on for service.
Oct 23, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
My viewsonic keeps changing channels which makes it impossible to use. We've unplugged it and everything. once you power it on, thats all it does. it continueusly changes channels. please help
The first thing to try is to see if a button is stuck on the remote or on the TV.
Remove the batteries on the remote and see if that helps. If it fixes the problem, you'll need to replace the remote.
If that doesn't help, look close at the buttons on the TV to see if one is jammed on. If changing channels continually up, then check the channel up button on the TV, if down then check the down button.
Worst case, you might have to take the back off the TV and unplug the cable feeding the external button panel on the TV and only use the Remote (for safety, rememeber to unplug the TV while doing any work on it).
Nov 28, 2013 | ViewSonic N3235w 32" LCD TV
Volume moving on it's own
Either the key/button the TV or Remote is stuck. Just remove the batteries of the remote and try. If same thing continues, do vacuum cleaning of the panel button/switch after switching of the TV, removing the plug from the power outlet. If the problem persists, this might require attention by a qualified service technician.
Jul 11, 2012 | Sanyo Televison & Video
Sounds stop working after about 1 to 2 hours of viewing.
We would be happy to help you with this. The volume levelingfeature that we have sounds perfect for this situation; it keeps the volumelevels consistent between programming and commercials and also prevents drasticvolume level changes when switching between HD and SD programming. The volumeleveling feature is supported by the following receivers: ViP 222k, ViP 612,ViP 722k, and ViP 922; the model number of your receiver is displayed onthe front in the lower left corner. Your receiver needs to be connected by onof the following: composite cable (green, blue, red cables), coax cable (singlecable with metallic tip), HDMI or optical devices that do not support Dolbyaudio.
Start by pressing the menu button on your DISH Network remote control, thenpress the number 6 for system setup then 7 for audio output. Once therehighlight the "Enable" option below Volume Leveling and press select.Once enable exit the menu by selecting done on the right side of the screen.
We hope this helps to get things set up the way you like it. Thanks forchoosing DISH Network!
Phillip Chang
DISH Network Customer Service Representative
Jan 17, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Comcast remote does not work after dark, works just find in day
I have had the same problem I have two bell receivers one in the bedroom and one in the living room, in low light the remote in the living room would work much like yours, but if I took the same remote into the bedroom it worked fine in low light, the second remote responded exactly the same, the problem in my situation was the TV had a light sensor that adjusts the picture depending on the light in the room, with this option turned off. The remote works just fine in low light situation.
Oct 20, 2009 | DISH Network IR Remote Control
Can't get remote to turn on tv it will turn valume high & low but it won't change channels or turn tv on and off. can't manually change channels
Are you using the supplied remote with the TV.
Try Resetting the Remote.
First, remove the batteries from the remote.
Then, wipe the contact surface of the batteries.
Then, press each button on the Remote twice repeatedly.
Then, reinsert the batteries and check whether the issue is resolved.
Jun 15, 2009 | Televison & Video
Need specs and wiring options
  • 105W x 4 Channel Max. Power Output at 2o.gif Stereo
  • 60W x 4 Channel 0.1% THD at 2o.gif Stereo @13.8V (RMS Continuous Power)
  • 40W x 4 Channel 0.1% THD at 4o.gif Stereo @13.8V (RMS Continuous Power)
  • ChannelFlex Crossover
  • Adjustable High-Pass Frequency (50-200Hz, L/R Independent)
  • Low-Pass Frequency (120Hz)
  • Adjustable Bass-Boost Level (45Hz, 0-9dB, F/R Separate)
  • High-Current, High-Speed Output Devices
  • High-Efficiency, High-Energy MOS-FET Power Supply
  • Audiophile Grade Component Selection
  • Intelligent 7-Way Discrete Protection Circuitry
  • Noise Reduction with Low Distortion & Ultra-Low Negative Feedback
  • High-Level Input - Add on Capability
  • Epoxy Composite PCB
  • 2o.gif Stable Design
Each 6 1/2" speaker will see 40 Watts
Each 6"x9" will see 521/2 Watts
Yes your solution is correct. Front wired in stereo, bridge rear.
Dec 29, 2008 | Eclipse Car Audio & Video
CAN'T CHANGE CHANNEL MANUALLY AND REMOTE DOESN'T WORK
Hi again,
Many thanks for the wonderful review and the rating.
Good luck and kind regards.
Thank you again for using FixYa.
Nov 07, 2008 | Sharp LC13B6US 13 in. EDTV-Ready LCD...
Disappearing sound, Low sound, no sound
Unplug the system from the wall and plug in again...It worked for me...hope it works for you too.
Aug 18, 2007 | Bose 3 2 1 GSX System
Televison & Video Logo
220 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
