Question about Candy AQ130 Front Load Washer
How to use the dryer of my Candy Aquaviva 1300 please?
Hi, I have just moved into a new house and this washing machine/Dryer was already there, I can use the washing part no problem but when it comes to the dryer i havent a cluse, There is no program for drying but there is a drying time, when i turn the drying time knob, No light appears i beginning to think it is broke what am i doing wrong, Thanks
  • TwinJeans Sep 12, 2008
    i have the same problem! and i've just moved into my flat and put the washing in and now i can't even open the door even though the washing cycle has finished!!!
    help!!!
    candy aquaviva 1300
  • csamp Jan 31, 2009
    i was given the washer with no instruction & dont know how to use the dryer
Wahing machine works great but a cant work out how to use dryer
Posted on Nov 27, 2008
    President:
  • 1,294 Answers
Click on Candy (below FIXYA ) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you will hv your manual on line. If available that is.
And rate me pl if helped............
Posted on Feb 24, 2008
I CANNOT FIND THE LINT TRAY/HOLDER ON MY CANDY AQUAVIVA 1300 WASHER DRYER. I FIND THE DRYER GIVES THE CLOTHES A DAMP SMELL WHEN DRIED. IS THIS DUE TO LINT BUILD UP?
This is usually located either near the bottom front, possibly behind a plate, or inside the rim of the drum. Check the user manual.
May 26, 2011 | Dryers
Candy aquaviva 1300 no heat while drying
disconnect the unit from the mains supply and remove the lid you will find a thermostat with a red button on it, press this and if you hear a click, problem solved to prevent fault reoccurring always let the dryer cycle finish its self as stopping it early can cause the heater box to overheat.
regards
Ian.
Apr 17, 2011 | Candy Dryers
Candy aquaviva plumbing
NO if it has two inlets then both are used buy a connector to connect both hoses together any diy shop will supply
Dec 20, 2009 | Washing Machines
Candy Aquaviva 1300 washing machine
fabrick condictioner drawer stays full can you help me bernie
May 21, 2008 | Candy AQW130 Front Load Washer / Dryer
Will not drain
Try cleaning the filter as when this gets all clogged up the water doesnt drain thru the pump
Apr 24, 2008 | Candy AQ130 Front Load Washer
CANDY AQUAVIVA WASHER/DRYER
its either the motor or element gone, remove the back of the machine and remove the wires from each component mentioned. try the element first , MAKE SURE U TAPE UP THE REMOVED WIRES BEFORE TURNING THE MACHINE BACK ON , U WILL GET A SHOCK IF U DONT!!!. if it does not trip , then the element is gone. like wise do the same to the motor. just one more item to check is where the mains cable enters the inside of the machine. good luck
Jan 22, 2008 | Candy AQW130 Front Load Washer / Dryer
Door lock , wont light up , therefor wont start washing.
Click on "Candy" (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
You can also go to "troubleshooting" above, you are sure to find some solutions. And dont forget to rate me on this great site.
Jan 07, 2008 | Candy CNW136 Front Load Washer/Dryer
Candy alise 1000 formula stainless
Click on brand name (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Or click on "washing machines" above to find your brand.
Jan 01, 2008 | Washing Machines
Leaking Candy Aquaviva 130
Its called 'The Main Outlet Hose' But you can probably make a fairly good repair by wrapping Gaffa Tape around the hose. Tip! after replacing / repairing the hose tape some padding around it, so it doesnt wear again
Oct 30, 2007 | Candy AQW130 Front Load Washer / Dryer
Candy AQ130 Front Load Washer Logo
1,760 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
