Question about Whirlpool 24 in. ADP5966 Free-standing Dishwasher
Power Light Flashing - Machine wont Start - Whirlpool ADP5966
Power button light - Flashing - Machine wont start - Have tried other suggestion of selecting an alternative program while holding the Power button without success....Any other idea's...Thanks in advance
  • 5 more comments
  • Scottman1 Feb 21, 2008
    Twice then pause, repeated..Thanks for your quick response.
  • Anonymous Sep 02, 2008
    When I press the function that I want and the start buttom the washer does not turn on. The only fuction light that does come on is the rinse only and the drain selection. I have unplugged the washer and plugged it back in hoping to reset the system and that does not seem to work either.
  • Anonymous Mar 13, 2014
    First when turning machine on programming lights up and then goes off and stays off wont come on using programming button
  • Anonymous Mar 26, 2014
    Also door won't lock. Machine will not operate at all. Have changed bushes
  • Anonymous Mar 27, 2014
    When I turn it on, I select the program and then all what it does is rinse only? After that the start light starts to flashing
  • Anonymous Mar 30, 2014
    Start button fault light is flashing but no obvious fault can be found
  • 49 Answers
This is a fault code. it will flash so many times and then pause.
let me no how many flashes before the pause and i will tell you what fault code it is
Posted on Feb 21, 2008
  • 1 more comment
  • anonymous111 Feb 21, 2008
    you have a water leak fault
    water has leaked into the bottom safe tray, you may have a leaking hose or a blocked drain hose causing the machine to over fill
    the best way to fix this is unplug the power pull the unit out from under bench ( you may have to disconnect the inlet hose and drain hose). then tip the machine back about 45 degrees. you should see water seep out onto the floor, you have now emptied the safe tray. reinstall the dishwasher, checking the drain spigot under sink (where the drain hose connects) for blockages.
    then run the machine as normal if the same fault happens again it means you have a leaking hose or pump underneath.
    best to have it looked at by a tech if this is the case
  • wishmaster46 Oct 26, 2010
    Mines flashes twice pauses then starts again
  • Don8364 Apr 25, 2011
    We had this problem where the start light didnt stop flashing and the machine just stops after draining. We tipped the machine 45deg as suggested by Anonymous111. Water did come out onto the floor, and when we restarted the machine, everything worked. Many, many thanks!
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
Whirpool Dishwasher ADP5966 Turned dishwasher on. Only light that comes on is normal wash light. Start button is flashing when normal wash light is on. On pressing start button dishwasher does not work
Most likely the door switch is not making proper contact when you shut the door or the Start button is faulty. Needs someone to look in the door panel to fix.
Feb 15, 2011 | Whirlpool Dishwashers
The start light is flashing on and off and the programmer wont change to another programme it stays on the normal programme and the dishwasher will not start
Seems to be relatively common. Ma doing one now with that exact problem. If you hold button in for about 10 seconds, it should reset.(switch off then on again to push start.). If same action continues, the electronic module needs to be replaced.
Dec 31, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
My whirlpool dishwasher is flashing 8 times - I pressed and held the start button to reset and then pressed start again, it kicked in and started to fill with water and stopped again - any ideas.
Hello, I have a Whirlpool DWF A10. The machine starts then stops after a short while and the indecator light flashes 7 times. What does this mean? Any body come across this?
Jan 11, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
I have a whirlpool adp951 with a green light flashing
HI,
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode
thank you for using fixya,rate my answer,
vijay
Oct 02, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool ADP 9520
press the start button (which is flashing) for a few seconds and it should start again?
Jun 09, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool ADP5966
just choose another programme setting and hold the start button in for a few seconds. this should solve the problem
Dec 24, 2006 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool 24 in. ADP5966 Free-standing Dishwasher Logo
1,058 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
