Question about Gateway M275 Tablet PC
When I turn on M275 I get power light, hard drive
When I turn on M275 I get power light. The hard drive light and all other lights blink once and fan runs continuously, but no further activity. Tried booting without battery and nothing different.
I have the same M275 tablet and was looking for a solution when I came across your post. I couldn't find a solution so I went over every nook and cranny of my tablet and found my hard drive was not completely pushed in. I pushed it in tried the power button again and it worked! I am shocked because my laptop has been down for a year now. I thought maybe it was a motherboard problem and it was junk. I'm so excited. Anyway all I can suggest is check that the hard drive on the right side is completely plugged/pushed in. I hope that works for you.
Posted on Jul 07, 2010
  • CHAD LAHTI
    CHAD LAHTI Oct 12, 2013
    Again.. do u get any displaly or more important.. any beeps when powering it up? Try the old keyboard mash.. to force a error before the post . If u get into the bios screen that way or even so sort of beep code. These Toshibia sometimes have a problem with the power switches.
The battery light blinks after shutting down my hp elitebook 2730p. Both the hard drive and power lights are off. What would cause the battery light to keep blinking after the pc is shut off?
The same thing has been happening to my tablet lately, as well. However, on mine, that corner of the computer is slightly damaged (from shoving it into my backpack too roughly, i guess). Is your hp damaged? Otherwise, it's probably a hardware problem.
Oct 14, 2010 | HP EliteBook 2730p Tablet PC
Cooling fan keeps running on m275 gateway laptop
If the fan keeps running constantly, it could be a number of things:
- The interior of your laptop could be dirty or dusty. If you remove the bottom cover and blow some compressed air into the case (when the computer is off and the battery is removed) it should resolve the problem.
- The CPU is overheating. Do you have it overclocked? What do you primarily sit it on when you are using it? You may want to think about getting a cooling pad (either powered or unpowered).
- The fan is dying or dirty, and not spinning as fast as it should. If this is your problem, you'll need to replace the fan, but this is the least likely scenario of the three.
Jun 21, 2010 | Gateway M275 Tablet PC
Shows more stored on hard drive than is there. Keeps saying hard drive space running out.
Empty the "Recycle Bin"? Files are not really gone until you empty the contents of the "Recycle Bin". They still take up drive space.
Oct 08, 2009 | Gateway M275 Tablet PC
M275 tablet laptop LCD back light stop working.
it is look like your laptop does not have the light runing on your screen , open the screen and chek the smal part under de scrren is in the midle of screen with 3or2 smal cable on 1 side and 3or2 that difer from brand to brand smal the other side  wich is conected to the light sourece, that is the problem change that part and will be ok.
Jan 16, 2009 | Gateway M275 Tablet PC
Black Screen
pretty sure it's the motherboard.. i'm in the process of replacing mine
Sep 10, 2008 | Gateway M275 Tablet PC
My Gateway m275 tablet will not charge or power up even with it plugged in
At least a 50% chance the power pin inside the computer has been damaged. Taking apart a laptop and getting it back together correctly is a tough job . . . .The part (the power pin) is not that expensive ($ 5-10) but the labor is expensive. If you don;t feel up to the task, have it fixed by a professional and after it''s fixed get a CRD (Cable Retention Device) to keep from damaging the pin a second time.
Jul 28, 2008 | Gateway M275 Tablet PC
M275
If you are unable to install the software it means that you don't have administrator rights.Its due to ntfs permission ,you must install it with login into your account as administrator..just make one more administrator account in safe mode and try whether you are able to do fix the issue or not.
Jul 21, 2008 | Gateway M275 Tablet PC
My m275 does'nt even turn on
The first thing to check for a tablet not turning on is the small sliding "padlock" switch next to the power button. If your computer is off and this sliding switch gets accidentally slid into the padlocked position, your computer will act 100% post mortem.
Aug 29, 2007 | Gateway M275 Tablet PC
Not charging
Sounds like you need a new jack: http://www.laptopjacks.com/product.php?id=Gateway
Aug 23, 2007 | Gateway M275 Tablet PC
Gateway M275 will not botot
try removing the battery and then booting without the battery attached
Jun 27, 2007 | Gateway M275 Tablet PC
Gateway M275 Tablet PC Logo
202 people viewed this question
Top Gateway Tablets & eReaders Experts
ashburton
vojvodabudva
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
