I want to play Let's Ride! The Rosemond Hill Collection, but I have windows Vista, and everytime I want to load the second competition the game stuffs up and the screen goes black. The only way to close it is to shut the computer off via the power button.
SOURCE: Let's Ride Corral Club will not run
To make the all the files of the game compatible to Windows Vista you need to install the game and then make changes to the game exe file.
Some game ".exe" file (executeable file) would let you make changes in
the Compatibility option, whereas older games might not give that
option at all.
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
9. After the game is installed go to the game directory and find the "LetsRide.exe" and click on "Properties" and repeat step no.7
You can delete all the files copied from the CD after completing the installation
The
game files need to be copied to the hard drive because the files on the
game disk would not let you make changes while on the disk.
There
are lot of files that need to be changed in order to get full
functionality and to communicate with operating system and the
hardware, hence there is no guarantee that the game might run even in
cases where you will successfully install an older version of the game
with the above mentioned steps.
The same set of steps can be used for installation of older games installation on Windows Vista.
