Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washing machine agaitates on high speed setting only. Low setting just clicks and barely moves.
    Habit-Forming:
  • 84 Answers
It sounds like your motor is only operating on one speed,either the starter capacitor is gone,a wire broken going to the motor or your motor is gone
Posted on Feb 06, 2010
3 speed fan barely changes speed
You are talking about your blower fan for the air conditioner and heater right? More information will be needed to solve the problem.
When you say it barely changes speeds, does that mean it doesnt speed up, or doesnt slow down? By that I mean, is it "stuck" on low, or high?
Most blower fans run at different speeds through the use of a multi-stage resistor built into the fan switch circuit. Low speed is a high value resistor, medium speed is a low value one, and high speed is the fan running without any resistance.
If your fan is running on high and doesnt seem to want to run on lower speeds, the resistor pack may be failing. If the fan is running on low speed only, it may be that the fan itself is beginning to fail, or that the lubricant in it has gotten gummy.
Dec 07, 2015 | Cars & Trucks
Fix agitator on a speed queen awm290
Is the drive belt in good condition?
Does the machine spin dry?
Is there water leaking from the bottom?
I suggest the gearbox needs to be replaced. Another sign is if the machine is noisy when it is washing (agitating)
Jul 04, 2014 | Speed Queen AWS45NW Top Load Washer
What will cause my Whirlpool washing machine to set on low speed spin cycle?
The machine uses automatic load sensors to balance the load and when you put something in the machine that is big, like a comforter, it knows that it cannot balance that item. So with a front loader it wont spin at high speed because it would be off balance and either damage the machine or the machine would "walk" because of the off balance motion.
Apr 28, 2014 | Whirlpool Washing Machines
All cycles on my washing machine work, but machine will not agitate. What are possible solutions to fix the issue? It is a Hotpoint, top load, model # is vvsr1070daww
The most probable thing causing it to not agitate is going to be stripped/broken agaitator coupler.
The video will show you to take out the agitator and check for a defective agaitator coupler
http://www.youtube.com/watch?v=N26MCQKuXn0
GENE
Sep 05, 2011 | Hotpoint VVSR1070D Top Load Washer
Kenmore 110 washer drum spins with lid open during Rinse/Spin
Slow agitator could be linked to shaft bearings going south. Pull the agitator off and check the block on top of the shaft. With everything turned off, try to turn the shaft. It should turn freely both ways. Other things to slow down the works could be a very worn drive belt from the motor.
The lid switch problem seems to be a wiring short--trace the wiring back from the switch to where ever it ends up (at the timer?). If it winds up at a relay, the contacts may be stuck together. It would be nice to have a wiring diagram--ah well. Don't know if any of this helps, good luck.
Jul 16, 2009 | Kenmore 22422 Top Load Washer
Hunter fan with remote control was 3 speed, now only 2 speed
It sounds like fan motor is okay. There are two motor windings -- one low speed, one medium speed. Low winding gives you low speed, medium winding gives you medium speed, both windings give you high speed -- so I would say if you get high speed, both windings are good.
The remote (the hand held transmitter) controls the speed by raising and lowering the frequency of the current which is 60 cycle coming to the fan ceiling box. If the fan speed -selector switch (usually a pull switch) is set to high, when the remote (transmitter) signals the receiver to change speeds, the frequency of the current is changed by the receiver (the receiver is usually in the fan housing).
Sounds like you'll need to replace the remote system -- these come in sets, both transmitter and receiver, and cost about $30. If you're not experienced with wiring fans, you should get an electrician to do the job.
Apr 21, 2009 | Hampton Bay 24002 Ceiling Fan
How do you remove the agatator on model lsq9549lwo
remove the top of the agaitator, some have a cap some a detergent cup
remove the clear inter cap and o ring
the bolt holding the agaitator can be accessed then with a nut driver
remove the nut and lift the complet agaitator out of the machine
May 16, 2008 | Whirlpool Washing Machines
Washer problem
THE SPEED SELECTOR SWITCH MAY BE SHORTED CAUSING THE MOTOR TO TRY AND RUN ON BOTH THE LOW AND HIGH SPEED WINDINGS. THIS WILL PULL TOO MUCH CURRENT AND TRIP THE BREAKER.
THE MOTOR WINDINGS FOR THE HIGH SPEED COULD BE SHORTED CAUSING EXCESSIVE CURRENT DRAW.
Apr 10, 2008 | Kenmore 22422 Top Load Washer
Inglis Washing Machine agitator not working right
washing machine will not aggitate will do the rest
Mar 27, 2008 | GE WBSR3140DW Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
51 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
